StandUp Scooter with CVP transmission
Re: StandUp Scooter with CVP transmission
Postby Astropower » Wed Apr 04, 2012 3:06 am
After lot of work
Astropower
Postby Astropower » Wed Apr 04, 2012 3:09 am
different side view
fit Perfect
Astropower
Postby Astropower » Wed Apr 04, 2012 3:12 am
Done
Astropower
Postby Astropower » Wed Apr 04, 2012 3:14 am
Complete 1
Astropower
Postby Astropower » Wed Apr 04, 2012 3:16 am
Complete 2
Astropower
Postby Astropower » Wed Apr 04, 2012 3:30 am
Now, the original scooter chassis have problem with wide wheels,
so i made some changes,
looks ugly now, becasue it not finish yet.
I will Update soon...
Astropower
Postby agniusm » Wed Apr 04, 2012 4:41 am
This is looking fabulous. great work mare. what kind of speeds/range you expect? I am just finishing my stand-up scooter project, meduza project. was wanderin if you could throw in a link for dc-dc converter. also how much was the motor/controller combo? cheers, nice project, thumbs up
agniusm
Postby Astropower » Wed Apr 04, 2012 6:12 am
Thank you for your reply,
the maximum speed is about 42.5Km/h (26.4MPH) in theory.
it will depend finally on the total weight.
simple calculation.
the range i hope it will be more then 40Km (25 miles).. and again, i will know for sure only after real test drive.
but for sure, In low speed or hills, i will save a lot of energy compare to the normal scooter in the market, thanks to the transmission.
about the DC to DC, this is the item that i bought :
http://www.ebay.com/itm/DC-DC-Converter ... 3a68fb8c0f
this is the controller:
http://www.aliexpress.com/fm-store/3138 ... -s-EV.html
about the motor, i dont have information on the web, it cost me about 150USD.
Thank again for your support.
Astropower
Postby Astropower » Thu Apr 05, 2012 1:46 am
Hello,
Yesterday i build caliper device.
Astropower
Postby Lebowski » Thu Apr 05, 2012 2:28 am
cool stuff :D nice project !
Lebowski
Postby sk8norcal » Thu Apr 05, 2012 6:27 pm
interesting...
where r u gonna mount the battery?
a Ezip 750 scooter would make a nicer donor vehicle for 12" wheels,
it comes with front suspension fork...
sk8norcal
Postby Astropower » Sun Apr 08, 2012 4:58 am
Hello,
I connect the motor now.
Astropower
Postby Astropower » Sun Apr 08, 2012 5:10 am
For: Sk8norcal
Yes, Ezip, Very nice Scooter,
i think about different stand up scooter, you can see in my pictures,
i think in this way, I have better controlling on stability, also in this way i can put big capacity of batteries more easily, (i have 51.2V@15Ah),
after i finish in the future i think i will add some suspension for front wheel.
Astropower
Postby Astropower » Thu Apr 19, 2012 8:07 am
Helle everyone,
I add some pictures for update,
i made a test ride after i program the Hub, and it is work great, lot of fun.
Next stage, to build two seats with spring suspension for comform.
Astropower
Postby fechter » Thu Apr 19, 2012 8:24 am
Nice work!
I'm interested about the motor. It looks like a nice size.
I found riding a stand up scooter with feet off to the sides difficult. You may want to make your foot pegs more like running boards and have them go the length of the deck so you can easily change your foot position. Usually you need one foot ahead of the other to maintain your forward/backward balance. If you depend on the handlebars, they better be really strong. Low speed cornering will take some practice too.
Personally, I'd put a seat on it. It could be easily removable.
I rode something similar years ago:
SF ev hillclimb5_800x600.jpg (110.21 KiB) Viewed 511 times
fechter
Postby SamTexas » Thu Apr 19, 2012 9:16 am
Nice work Astropower. If I had your patience and metal work skill, I would have built the whole frame from scratch.
SamTexas
Postby fechter » Sun Apr 22, 2012 10:57 am
Where did you get those tires? They look like they would be great on my scooter.
fechter
Postby Astropower » Sun Apr 22, 2012 3:11 pm
Hello,
12-1/2x2.75 Heavy-Duty Knobby Tread Electric Scooter and Dirt Bike Tire, 65PSI
You can find them on:
http://www.electricscooterparts.com/tires.html
Astropower
Postby fechter » Mon Apr 23, 2012 8:29 am
Astropower wrote:Hello,
Excellent! Thanks.
fechter
Postby Astropower » Mon May 07, 2012 1:30 am
Hello,
Some updates.
Astropower
Postby Astropower » Mon May 07, 2012 1:34 am
3 stages for finish this toy.
1. cleaninig the frame
2. painting
3. connect all parts.
And drive.
Astropower
Postby Dave-s » Thu May 17, 2012 2:18 am
Hi Baruch,
Nice scooter. Is it running yet?
Where did you buy the motor? And where did you get the batteries?
You should checkout tncscooters.com, he ships to Israel (except for motors), and has good prices.
Did you have any problems with customs when you got these parts?
You should hook up a battery management system (BMS), or at least an LVC (Low Voltage Cutoff) to protect your batteries.
I have many scooter parts, so if you need something urgently I can lend you the part until you order it from abroad.
Dave-s
Postby Astropower » Sun Jun 17, 2012 2:02 am
Hello all,
i just continum with my build now. i was too busy.
as i told you, i start with painting,
this is after painting, need to dry. also i connected aluminum legs ped (BMX style).
This the front end back light, LED 10W for front, 1W LED for rear.
Frame after dry.
I make mix between Black color with Metalic Silver, to create Dark metalic Gray.
Second picture of frame
Battery:
My cells are 16pcs of 15Ah Headway 40152. total 53V.
All the BMS are waste of money, not reliable, and do not do the work properly And with them you can get stuck in the middle of the road without a logical reason, and I do not want it to happen.
so, in order to save the life time of this cells, i need to add some components.
1)to balance cells, i was order 16 units of balance boards. it balance with 1400mA, (in BMS board it about 85mA to 150mA). the balance is only when i charge !.
2)to protect over discharge or short cells output, i add Fuse of 50A.
3) to protect low voltage, my controller cut the power off when the voltage is 41.5V, and for me, to know when my batteries are low, i add some device, from the RC toy world,
this device, for 8 cells, so i connected 2pcs, it can programmable, when voltage below then 2.7V, of some of cells. it start to make alarm.
start to assemble all:
soon, test ride results.
Astropower
Postby mistercrash » Sun Jun 17, 2012 11:54 am
This thing is very cool. Nicely done sir, luuuuuuv it!
Is it ready yet?
mistercrash
Postby ohzee » Sun Jun 17, 2012 12:34 pm
wow that is one awesome ride.. very impressive.. Love to see some video of it in action.
ohzee
Next
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 3 guests
