Golden Motor Electric Scooter Hub Motors (Super Integrated)
Postby NeilP » Tue Apr 24, 2012 3:22 am
Any one used or had experience with any of these motors from Golden Motor?
http://www.goldenmotor.com/
Sorry the site wont seem to let me get links to the direct page.
But I am referring to the various 8 12 or 16 inch wheels with built in motors and or controllers
OK, some are rated at 250W.the 8 inch ones, just wondering what they can be pushed to...500? 750/ 1000?
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Re: Golden Motor Electric Scooter Hub Motors (Super Integra
Postby hjns » Tue Apr 24, 2012 4:43 am
sorry, no, I don't have experience with Scooter motors.
(another unanswered post gone.... :wink: )
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby NeilP » Tue Apr 24, 2012 5:21 am
Think you need to start at the other end of the unanswered posts list :wink: only posted that one minutes ago :lol:
180mm disks
100V 20Ah LiPo
NeilP
Postby hjns » Tue Apr 24, 2012 6:29 am
I know...
I looked at the "other end of the thread". The oldest posts are from more than 1 year ago.... I don't think it makes sense to start answering these very old questions, even if I had the time (or the answers). We probably need to rely on the OP's themselves as well, to repost their question in another thread in case they don't get a response within the first XX minutes/days/weeks.
Henk
hjns
Postby Astropower » Wed Apr 25, 2012 1:23 am
Hello,
In Israel sells scooter with Hub motor,
Single motor or dual motor,
Look:
http://www.kooperscooter.com/Upload/Doc ... ations.pdf
Astropower
Postby NeilP » Wed Apr 25, 2012 3:00 am
Have you ridden one? What is the single motor top speed like?
180mm disks
100V 20Ah LiPo
NeilP
Postby Astropower » Wed Apr 25, 2012 3:43 am
Hello,
They us in Golden Motor model: MW12B
But they get 48V instead of 36V, you can see the curve : http://www.goldenmotor.com/hubmotors/hu ... 12cure.pdf
top speed about 21MPH
Astropower
Postby NeilP » Wed Apr 25, 2012 6:17 am
21 mph and 48 volt would be perfect.
I have spare controller here..12 FET Xlyte sensorless could use that.
Anyone know if these are sensolress or sensor motors?.. would prefer sensored for smoother pull off
180mm disks
100V 20Ah LiPo
NeilP
Postby Cheeseboy » Sat May 05, 2012 4:58 am
Hi Neil, did you purchase one?
I am almost certain the 12" MW12B motor is sensored, coming from this post in the golden motor forums
"Oh, and the GM controllers are ofcourse PWM, and the hall sensors inside the motors works at 5V, and delivers 0V to just below 5V out... "
"Phases are 120 degrees."
here is the link:
http://goldenmotor.com/SMF/index.php?to ... 2#msg20632
I've been looking at them for my scooter design (been looking at the 6" one and particularly the 8" Hub24A, which doesn't have any price...) and just emailed them regarding the thinner models.
apparently their email communication isn't great though, so I don't know how helpful they'll be...
all going well I'll have two of the thin 8 inch motors soon, I'll post here about them seeing no one seems to have really tested them yet.
Cheeseboy
Postby NeilP » Sat May 05, 2012 5:26 am
No, not yet.
I have a smallish motor here...154mm diameter inside the spoke flange. I am thinking of trying to lace to either a small kids bike wheel..but spoke hole number issues...or find a solid tyre to fit over the hub motor direct...not sure yet
180mm disks
100V 20Ah LiPo
NeilP
Postby Cheeseboy » Sat May 05, 2012 5:51 am
I've had good results a while back using a strip of Urethane straight on a small brushed hub motor.
got the idea from here:
http://web.mit.edu/first/scooter/#motor
They used 80a Urethane, I used whatever I could get my hands on at the time, I think it was a softer type. It worked well as a tyre, and glues easily to the motor if you rough up the metal surface a bit.
Just an idea, good luck!
motor width is my current issue though, so I can't do that this time...
Cheeseboy
Postby NeilP » Sat May 05, 2012 6:09 am
i was hoping for one of these
http://www.greentyre.co.uk/w6inch.html
180mm disks
100V 20Ah LiPo
NeilP
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: Pediglide, realmattb and 4 guests
