K2 kickboard mod with 3kw rc outrunner
Postby exco » Thu Dec 19, 2013 11:20 am
I missed out on sharing most of the build process / thoughts / obstacles on my last build (GNG middrive) and thought I'd try to get it right this time ;-)
The idea is in my head for a while now. If the motor arrives this year ... which it won't ... it could be done soon. (or later)
Bought this for 37€ on ebay
Put bigger rubber tires on it:
and was amazed finding out you could stil buy all spare parts for cheap here.
I will probabl even get air tires if I can find 110mm ones - because that's the size of the rubber ones (initally there were 80mm PU on it) - and I already had
to slightly modify the break for the wheel to fit.
I also got some busted Makita 2.5Ah, 18 V LiPo packs on ebay (paid more than I'd like to admit) ... ~50€ for 6 packs.
Those sat around for half a year having tried to revive them - and cutting the dead cells out.
Now I made this Frankenstein pack to get them balanced.
I will use my unliked bmsbattery smart bms with the pack later.
Because I'm too lazy atm to program an Attiny I just bought a servo tester for 50 cents and added a horribly expensive 20€
push potentiometer to it.
Motor will be the el cheapo Aeolian-C6374-10-KV170 motor.
ESC quite possibly from Alien Power.
That's it for now.
Suggestions?
Last edited by exco on Mon Dec 30, 2013 8:25 am, edited 2 times in total. View post history.
K2 kickboard build thread (63mm, up to 3kw) | cad files on github
Backfire LRS build thread (GNG "450W" mid drive) | cad files on github
exco
Re: K2 kickboard mod with 3kw rc outrunner
Postby sk8norcal » Thu Dec 19, 2013 4:19 pm
sk8norcal
Postby exco » Sun Dec 22, 2013 3:09 pm
Thanks. Those look nice - and I already researched a bit beforehand.
After my 3rd iteration the CAD looks like this:
First parts:
CAD files: Github
exco
Postby exco » Fri Dec 27, 2013 8:16 pm
More parts...
Motor mount with slots for belt tensioning:
Back plate - old and new. The brake will be reused.
Wheel adapters (where the bearings were before) mounted with set screws (and holes drilled into the axle).
Mounted together - belt pulleys also fixed with set screws (and holes drilled into the axle)
Put together for first tests:
I still need to program the controller - and buy the appropriate one from alienpowersystems.com after this one goes up in smoke (probably tomorrow)
and build some suitable battery pack.
exco
Postby exco » Sat Dec 28, 2013 10:22 pm
"gas pedal"
no name controller "100A" sky wing
with 18x FDD8896 N-Channel Mosfets
First motor test
and first test run with the el cheapo controller and 6S LiPo:
Guess the motor mount isn't holding up to the torque ;-)
electronics fixed with good old blue tape
no load rpm 1295 ... at 4.2V*6*170rpm/V *12 / 40 = 1285 rpm ... sounds legit
Yields in 1295U/min * 11cm * pi / 100 cm/m / 1000 m/km * 60 min/h = 26.85 km/h @ no-load ... or estimated 26.85 km/h * 0.8 = 21.5 km/h.
The controller will do 7S - so without going for a better controller I could do ~25km/h or ~35km/h @10S.
Last edited by exco on Mon Dec 30, 2013 8:26 am, edited 1 time in total. View post history.
exco
Postby torqueboards » Sat Dec 28, 2013 10:58 pm
Nice ESC. Does it also have braking like a car ESC? How are you programming it?
torqueboards
Postby exco » Sun Dec 29, 2013 8:12 am
torqueboards wrote:Nice ESC. Does it also have braking like a car ESC? How are you programming it?
Yes, it has 3 braking modes. No ABS though ;-)
Programming is a real pita - with the throttle and audible feedback from the motor:
exco
Postby torqueboards » Sun Dec 29, 2013 4:55 pm
Awesome, thanks for the photos. Which brake setting do you use? Are you only using motor braking or do you use the brakes on the kickboard?
torqueboards
Postby sk8norcal » Mon Dec 30, 2013 1:26 am
exco wrote:Wheel adapters (where the bearings were before) mounted with set screws (and holes drilled into the axle).
cool build,
where u get those wheels?
sk8norcal
Postby exco » Mon Dec 30, 2013 4:36 am
torqueboards wrote:Which brake setting do you use? Are you only using motor braking or do you use the brakes on the kickboard?
I used "soft brake" for testing to save the belt because my motor mount wasn't sturdy enough and it would already cause belt slip.
I plan on using a higher brake setting after building a sturdier motor mount.
Also I plan on re-attaching the rear brake - at the moment it doesn't have any mechanical brakes.
sk8norcal wrote:cool build,
Thanks.
I got those on ebay.
exco
Postby made_in_the_alps_legacy » Mon Dec 30, 2013 9:53 am
exco wrote:Programming is a real pita - with the throttle and audible feedback from the motor
3 shorts bips followed by 3 long bips then 3 shorts bips --- :lol: I know what u mean and wish u good luck for a carefull programming - your build deserves it :wink:
Postby exco » Mon Dec 30, 2013 9:56 pm
I redesigned two parts today - the motor mount proved to be way sturdier:
(upper: old - 4mm, too small cross section, lower: new - 5mm)
I weakened the other part (unfortunately no pic) too much because I tried to get a better line for the belt.
The belt was already worn down to ~25% teeth remaining - but it still had a lot less slip with the sturdier motor mount and
so the acceleration/deceleration was way better. The front wheels were even lifting off the ground a few times with
the lighter guys.
Also today we got to test the kickboard out on the "parking lot" and the cumulative distance was about 2.5 kilometers and
afterwards I could charge 2600mAh into the 6S battery pack.
~ 2.6Ah * 24V = 62.4Wh aka ~ 25 Wh/km
I have no idea if those are good/realistic figures ... I will attach a volt/amperemeter later.
This would limit the travel distance to about 5km.
The attractive figure was the top speed though ;-)
Looks like 22 km/h to me ;-)
I made some videos - which unfortunately all suffer from horizontal video syndrome *darned*.
I need to check if someone else made some good ones.
exco
Postby exco » Sat Jan 04, 2014 8:56 pm
Some more pictures:
I still haven't completed the 3p6s 18650 battery pack - and I also need to measure the Wh/km and top speed with 7s ;-)
exco
Postby exco » Sun Jan 05, 2014 9:21 pm
So for now I think this build is complete.
I should still put an AT5 belt and pulleys on it after this 10mm T5 belt snaps (it's already worn down a lot).
This is the first time I actually did sth. for myself with the lasercutter at our hackerspace ...
These are insulator rings for the 18650 cells
The complete pack
and even completed in shrink wrap (I bought for my ebike build over a year ago)
Fits quite nice imho
The top speed is now 27km/h and the measured energy consumption is 13Wh/km.
exco
Postby exco » Mon Mar 10, 2014 8:12 am
some more pics of the kickboard evolution:
T5 10mm (left) vs AT5 16mm pulley (right)
worn down belt vs new one
old bent 8mm shaft vs new hardened one - is still a hack ... should get a larger diameter than 8mm
pressing the adapters into the rims
process of removing the old ball-bearing
press-fitting new pulley (in addition to 2 grub screws)
^^ somewhen I need to build a new shaft with additional bearing on the opposed side of the pulley to counter the pulley load
view of the completed rim-adapter-shaft
Fully assembled ... again ;-)
exco
Postby kkEdlund » Tue Mar 11, 2014 6:31 pm
Wow, this is probably the coolest build I've seen on this site. I actually signed up here to get help with a K2 kickboard build, but it was too challenging so I gave up and did a normal longboard. After seeing this, I think I will have to go back and finish the scooter now.
Awesome job on your build!
kkEdlund
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: BadWolf, CSN, kfong and 5 guests
