Found some XT wheelz in my shed...New Build Time!
psychotiller   10 kW
Post by psychotiller » Apr 24 2014 8:26pm
Tearing my shed apart looking for baby stuff (another one on the way) and I found 2 sets of wheels. XT all terrain wheels and a set of 100mm slicks. Before I knew it I had gathered up a deck, some randall 180's, bearings, and a wheel pulley.
It took some time to mount a mount bracket to the randall because I made my mounts to fit Caliber trucks, but with a little filing it actually turned out to fit more solid.
I'm going to need to order a few things, but it should be riverbed bound in a couple of weeks.
ghetto 4bot2.jpg (100.5 KiB) Viewed 7898 times
Here's the newest iteration of the Ghetto4Bot:
Ghetto4Bot Enclosure.jpg (127.98 KiB) Viewed 5334 times
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
torqueboards   100 MW
Re: Found some XT wheelz in my shed...New Build Time!
Post by torqueboards » Apr 24 2014 8:31pm
I just got a pair of those too. They are pretty huge. Have you used them yet? I still need to mount my pulleys. I need to mount some pulleys on it and give em a try.
DIYElectricSkateboard.com Electric Skateboard Kits
psychotiller   10 kW
Post by psychotiller » Apr 24 2014 8:36pm
I mounted a wheel pulley today but I'm thinking I may want more teeth..(used a 32) What are you going to use?
I just want to jib around with this board so I'm not looking to break any speed records.
I'm using:
2x6s, tacon bigfoot 160, probably going to order another mamba monster2
builds:
torqueboards   100 MW
Post by torqueboards » Apr 24 2014 9:01pm
I was going to put a 40T or something.
jabberwocky   10 µW
10 µW
Post by jabberwocky » Apr 24 2014 10:09pm
I actually have an ancient powell peralta longboard with a set of these on it. While preparing to build my eboard I pulled it out of storage and checked it out, and the wheels look like they could have something mounted easily enough. My recollection of them is they are heavy and slow to get rolling, but pretty unstoppable once they are.
psychotiller   10 kW
Post by psychotiller » Apr 24 2014 10:16pm
jabberwocky wrote:I actually have an ancient powell peralta longboard with a set of these on it. While preparing to build my eboard I pulled it out of storage and checked it out, and the wheels look like they could have something mounted easily enough. My recollection of them is they are heavy and slow to get rolling, but pretty unstoppable once they are.
I remember how sluggish they felt pushing as well, unless i was on a downhill dirt trail. What I hope though is that it wont be noticeable with a few horsepower. :lol:
builds:
torqueboards   100 MW
Post by torqueboards » Apr 24 2014 10:23pm
Here's mine. These pulleys weren't really made for them it was made for the ABEC 11 wheels but the lines almost line up perfectly, luckily.
psychotiller   10 kW
Post by psychotiller » Apr 24 2014 10:34pm
torqueboards wrote: Here's mine. These pulleys weren't really made for them it was made for the ABEC 11 wheels but the lines almost line up perfectly, luckily.
Is that 5mm htd? If mine feels gutless can I buy one of those from you? What are you running on your motor pulley? 18?
builds:
LEVer   10 kW
Post by LEVer » Apr 25 2014 12:51am
The XT wheelz also made a smooth one:
http://xtwheelz.com/index.php?main_page ... da291d0254
E-glide sells a pulley for the smooth one. They call it Goodyear Drive Gear:
http://e-glide.com/electric-skateboards ... rts/wheels
I can lend you mine to see if it fits. Its 5m htd.
torqueboards   100 MW
Post by torqueboards » Apr 25 2014 1:54am
I'd like the original gear too but it looks like it's being held on by a bearing. Those I'm pretty sure won't fit on longboard trucks.
psychotiller - yeah, they are 5mm htd - pm me if you still want.
Hrmm.. Probably won't try it in a few days but I'm curious to see how they ride. They are some pretty heavy wheels though.
psychotiller   10 kW
Post by psychotiller » Apr 25 2014 2:47am
Pediglide, thanks! We'll have to check that out. I just ordered those 6"wheels too. There is definitely going to be a riverbed board very soon.
Torque, they are pretty lumpy wheels but I have to say this board doesn't feel very heavy with them on it.
builds:
drmacgyver   100 W
Post by drmacgyver » Apr 25 2014 12:15pm
psychotiller   10 kW
Post by psychotiller » Apr 25 2014 1:17pm
drmacgyver wrote:Anyone know anything about these?:
http://e-glide.com/electric-skateboards ... set-detail
Those are huge! The only experience I have with tires that size was on an MBS Blade I had. Those were 9" though...Heavy. Turned out to just be overkill. Used to race the mountainboards and most people stuck with 8" because the swing weight on the boards was so heavy with the bigger tires/wheels. I wonder what those each weigh?
WRS Years 076.gif (65.79 KiB) Viewed 8663 times
builds:
drmacgyver   100 W
Post by drmacgyver » Apr 25 2014 2:16pm
Oh snap! Hard to tell from the website. I'm getting so impatient looking for a solution for pneumatic tires! Thinking about getting 97mm flywheels in the meantime, which should solve the problem of rough roads and a need for increased speed
psychotiller   10 kW
Post by psychotiller » Apr 25 2014 3:54pm
drmacgyver wrote:Oh snap! Hard to tell from the website. I'm getting so impatient looking for a solution for pneumatic tires! Thinking about getting 97mm flywheels in the meantime, which should solve the problem of rough roads and a need for increased speed
I ordered 4 of these yesterday to check out. Seemed like a good deal.
http://www.accesscasters.com/6SPNGBS-6- ... Wheel.aspx
Here's a pic of the XT board right now while it waits for an ESC and Batteries:
ghetto 4bot2.jpg (131.91 KiB) Viewed 1713 times
builds:
drmacgyver   100 W
Post by drmacgyver » Apr 25 2014 4:45pm
Looks great! Love the shape of the deck and the low profile of all the guts. Where did you get the wheel adapter for those casters?
psychotiller   10 kW
Post by psychotiller » Apr 25 2014 8:11pm
drmacgyver wrote:Looks great! Love the shape of the deck and the low profile of all the guts. Where did you get the wheel adapter for those casters?
Adapter? Nothing yet. I'm going to make something.
builds:
Jan Christian   100 W
Post by Jan Christian » Apr 27 2014 5:04pm
sizes on wheels is here. http://e-glide.com/electric-skateboards ... comparison
psychotiller   10 kW
Post by psychotiller » Apr 27 2014 9:00pm
Wow! Look at the ridiculous weights of all of these e-glide boards...I never realized they were that heavy. (and insanely over-priced too!)
builds:
psychotiller   10 kW
Post by psychotiller » May 02 2014 10:09am
When I mounted my motor bracket to this randall 180 I set the angle to hopefully work with a drop-through.
I have a ton of clearance under the bracket with the larger wheels and perfect clearance between the deck and the motor bracket. As far as wheel bite goes? Seems pretty close but I loosened the trucks all the way and pushed around on it today without an issue. I'm stoked on this build!
drop through xt2 (1).jpg (74.12 KiB) Viewed 8427 times
drop through xt2 (2).jpg (79.85 KiB) Viewed 8427 times
builds:
psychotiller   10 kW
Post by psychotiller » May 11 2014 12:44pm
Here's a video of a test run.
https://www.youtube.com/watch?v=yDDayvxVdnU
builds:
psychotiller   10 kW
Post by psychotiller » May 11 2014 11:10pm
2014-05-11 20.41.54.jpg (128.08 KiB) Viewed 8300 times
Cast resin lined battery bag with velcro strips.
builds:
Hummina Shadeeba   1 MW
Post by Hummina Shadeeba » May 18 2014 10:58pm
Best video of an electric board I've seen. Smooth n quiet. Did u use the brakes at all?
It's got its own spot in the garage...it deserves more room
I haven't read the thread yet.
And the mounts are awesome I think..other than the extra pulley
psychotiller   10 kW
Post by psychotiller » May 18 2014 11:56pm
Hummina Shadeeba wrote:Best video of an electric board I've seen. Smooth n quiet. Did u use the brakes at all?
Thanks. I dont think I used the brakes at all except for when I came back up my driveway.
builds:
papertriping   10 W
Post by papertriping » Sep 25 2014 1:33pm
Those wheels look epic! I've been wanting to ask-
What are they called?
how do they ride?
where can one buy wheels like these?
Pls do tell
|Pen E-Board| Smallest E-board ever| http://endless-sphere.com/forums/viewto ... 35&t=63223
