Trampa EMTB Dual Motor "No-Wind"
nowind   100 W
Post by nowind » Nov 10 2014 3:31am
Hi Everyone,
my name is Jenso from Germany.
I´m a Kite and Kitelandboarder, have some Rc Knowledge and working as a Millingmachineoperator.
So i decidet to build up an EMTB based on my excisting Trampa Kite board.
Started with one Motor Rearleft, then a second on diagonal Frontright, and at the moment Dualrear Setup.
I think its most fun with the rear drive, drifting and carving and so on
Using parts from RC i had still left from my RcCars :
Hobbywing 150A ESC
Spektrum DX3R
Hyperion Duo Charger
New parts are :
2X SK3 6374 168kV
6S2P 5800mAh ZippyCompact
Using a 4mm Chaindrive with 6mm pitch.
The gear Ratio is 4.15
Milled Aluminium Motor mounts from 10mm 7075-T6
Tracked the Speed via mobilephone gps about 30kmh, more then enough for offroad i think.
Set the Timing from the ESC to the max, now its really nice directly driveable.
For sure from deadend you will notice a bit cogging but not much, see the video.
Not really sure if it will being better with shorter gear ratio from 5:1 or 6:1, maybe its more a "sensorless motor" problem. What do you think?
I get really into the EMTB Stuff and i LOVE IT
THX to the ES Forum, many great builds and loads of knowledge up here!
Best Regards
Jenso
https://www.youtube.com/watch?v=zjZafqj ... e=youtu.be
torqueboards   100 MW
Re: Trampa EMTB Dual Motor "No-Wind"
Post by torqueboards » Nov 10 2014 3:45am
Awesome machine work! Welcome to the forum and thanks for showing! Not as much MTB's lately.
DIYElectricSkateboard.com Electric Skateboard Kits
furp   100 W
Post by furp » Nov 10 2014 11:13am
Great mounts, nice and simple! When you go back to dual rear drive, link them with a rod for stiffness. I don't know if it could actually be a problem, but the cutouts in your mounts will decrease the strenght and only offer very little weightsaving, so when not linked, like in dual diagonal drive, they mitght bend over time. Or they might not :) I just know that beetbocks removed those cutouts from his kit to increase durability (but his plate is only 6mm thick).
Good choice on the chain, I think I got the same ones!
OBone   10 mW
Post by OBone » Nov 10 2014 11:51am
Very well made.
Helps to have access to machining equipment
Mondays. What a silly way of spending 1/7 of your life
nowind   100 W
Post by nowind » Nov 11 2014 6:37am
ThX man, glad you like it.
Yes Life is easier with a cnc (-;
Have the same thought about a rod between the motormounts.
Made one yesterday, maybe will mount two more of these to ad more strenght
Here its mounted:
Jan Christian   100 W
Post by Jan Christian » Nov 11 2014 7:58am
If that stiffening rod is too close to the motor it will generate eddy currents...
benj   100 W
Post by benj » Nov 11 2014 9:20am
Beautiful!! I want one :)
furp   100 W
Post by furp » Nov 11 2014 4:03pm
Nice one! Will aluminum generate eddy currents? I have n clue, but I always thought you would need a conductive material for that, like hendo using copper plates.
amberwolf   100 GW
Post by amberwolf » Nov 11 2014 4:20pm
Aluminum *is* conductive, and yes it will generate eddycurrents.
furp   100 W
Post by furp » Nov 11 2014 4:44pm
Well, I was right then: I have no clue. Was just wondering why hendo uses copper plates then.
nowind   100 W
Post by nowind » Nov 11 2014 5:01pm
Hey man,
wow ok thats new to me thats aluminium have an influence on the magnetic field of the motor.
I thought the motormounts itself are full aluminium and attached direct to the motor so i dont mind.
Now i´m really confused, because i have had a short ride today and must stop after 15minutes cause its started raining.
I charged the batteries and wondered that only 30% left, normaly after 15minutes there are at least 50-55% capacity left.
I thought it was in cause of soft ground and much full throttle.... mmmh do you really think it caused by the rod?
I measured 7mm space between motor and rod, is it too near?
Made a second rod today which i wanna mount under the other rod, now i´m not sure !!!
BShady   1 kW
Post by BShady » Nov 11 2014 7:28pm
Really nice build!! I love the trampa boards from the start and the mounts look amazing.
Got a couple of qu:
Is your top speed of 30kmh measured on road or off-road.
How much does your board weight?
I though or outrunners the timing is suppose to be low not high?
Are you useing the 6s2p 5800mah for both motors or is that for each motor?
How many ESCs are you useing?
Lol that's a lot of qu!!!! Amazing build!! EMTB is the way to go!
amberwolf   100 GW
Post by amberwolf » Nov 11 2014 9:09pm
As long as the metal isn't in the magnetic field it doesn't matter. it's only if it ends up there that it makes a difference, and even then only if it's moving within the field (or the field is moving past it). If you want to see, you could use an IR imager, and then run the unit for a while, and see what gets warm.
You could also use an IR thermometer, tha tjust tells you the temperature fo the spot you point it at, and carefully move it around to see what parts are at what temperatures.
If there is any warmth generated on the questioned areas, and they are not actively being warmed by hot air from teh motor, or radiated heat, then it would be induced heat by eddy currents.
You could also probalby measure the magnetic field strengths and see about how far it goes from the motor, and if it intersects the areas, but I dunno that would be worth the effort of figuring out how to do it and setting it up.
Basically any metal moving isnide a magnetic field will create a current within the metal. That's how a generator (or regen braking) works. The coils cut thru the magnet fields, and generate a current in the wire.
You can even take a powerful enough magnet, and move it around in circles on a piece of metal (aluminum, etc) and heat the metal up by the induced currents, but doing it by hand with the magnets you'd typically have laying around probably won't be that noticeable.
nowind   100 W
Post by nowind » Nov 12 2014 2:20am
BShady wrote:Really nice build!! I love the trampa boards from the start and the mounts look amazing.
Got a couple of qu:
Hi BShady
I meassured it via Handy GPS on a gravel path. But that was one of the first test with only one motor.
Sorry no balance here i dont know, will tell you soon.
My knowledge is that this big outrunners used with high timing. Maybe some experts up in here can tell us the truth (-;
First runs i used lowest timing and if i hit the trigger hard the motors lost it sync(cogging), after setting max timing its much better, the driving is more direct. It felts the motors have 30% more power with full timing. The Temperature increase about 10 degrees.
I am using 6S2P with overall 11600mAh for both motors, runtime normally at least 30 minutes if you go hard on triggger.
I am using two Hobbywing 150A ESC connected via Y-Harness
Hope that helps
amberwolf wrote:As long as the metal isn't in the magnetic field it doesn't matter. it's only if it ends up there that it makes a difference, and even then only if it's moving within the field (or the field is moving past it). If you want to see, you could use an IR imager, and then run the unit for a while, and see what gets warm.
Hey Amberwolf,
thx for elaborate answer. It make sense. Unfortunately i have no IR device at the moment, i lost it on weekend during riding the EMTB (-;
I need to buy a new one. To detect if there is a influence i will do the following:
I will do testruns of 10 minutes today with nearly equal terms and conditions. First one with the Rod, second one without, maybe a third one with the second Rod i milled last night. I´m really excited what will happen.
If i get it right my logic tells me that the amount of eddy current depends on the mass of the metal material in the magnetic field of the rotor?
So i could think about to machine the braces(rod) much lighter (-; isnt it ?
Better would be using more distance for the rods, but that means new motormounts...
But first i will test it like i described.
will report...
Have a nice day
BShady   1 kW
Post by BShady » Nov 12 2014 1:03pm
How tight do you make your bindings?
Mine are pretty loose but not sure if I should make them tighter.
nowind   100 W
Post by nowind » Nov 12 2014 5:18pm
BShady wrote:How tight do you make your bindings?
Have a look here, cant explain better :
https://www.youtube.com/watch?v=ObNSURYIj9E
nowind   100 W
Post by nowind » Nov 12 2014 6:00pm
I tryed to evaluate today if there are any side effects from my rods like eddy currents or not.
I run three times the same track (same distance) in the same time (10minutes) and measured the left capacity of the batterie.
First run without any braces and second run with two of my rods. It was exacty the same amount left in the batteries.
But by both runs i need more then the last times.
So i started to check the board and recognized that one tire has really low preasure, insteads of 50PSi less then 20PSI.
After refill all tires made the third run and had left 10% more capacity in the batterie. So guys check your pressure,
Highspeed loged via GPS increases about 3kmh .... now 37kmh.
Decided to machine the Rods again to remove all material which is not necessary.
Now they look a bit more badass and i hope any left eddycurrents are minimized.
Hope they are no secret eddy currents wich destroy my motors!
Also rebuild the both driven Hubs with wider spacer to get more clearence between the sprocket and the tire.
Because i recogniced on the inner wall of the tire traces from the chain.
Must using longer screws now too.
Inox M4x60MM Countersunk with 12mm spacers give me 3mm more clearence now.
Greetz
nowind   100 W
Post by nowind » Nov 25 2014 9:15pm
Good weather last days, so got some new video footage.
Have a look on my youtube channel :
https://www.youtube.com/watch?v=9Xt_FsB ... e=youtu.be
mortifiedMORTY   10 mW
Post by mortifiedMORTY » Nov 25 2014 11:40pm
It's definitely fast! this is awesome
BShady   1 kW
Post by BShady » Nov 26 2014 12:56am
Dude insane carving???!!!! How do you carve that good?
nowind   100 W
Post by nowind » Nov 26 2014 3:04am
mortifiedMORTY wrote:It's definitely fast! this is awesome
Yes it is, 35kmh not sounds much, but it felts much faster standing on the board!
BShady wrote:Dude insane carving???!!!! How do you carve that good?
Thx BShady, i´m driving everyday since 3 weeks (-;
Also using the softest Trampa Dampas (yellow ones) this helps too.
furp   100 W
Post by furp » Nov 26 2014 8:35am
Man that Trampa Board looks nice.. Looks way lighter than my heavy Vault one. Not to mention the great motor mounts.
BShady   1 kW
Post by BShady » Nov 26 2014 9:39am
Why level deck stiffness do you have? And do you feel any wobble at high speeds?
benj   100 W
Post by benj » Nov 26 2014 10:18am
Hey nowind, nice video. From the youtube description it seemed to hint you might be thinking about selling this as a kit? Is that a possibility?
Also - do you snowboard? If so, how does this ride feel compared to that?
made_in_the_alps_legacy   10 kW
Post by made_in_the_alps_legacy » Nov 26 2014 10:53am
+1 benj :wink:
Would you please also tell us some electrical consumption numbers on flat at a given average speed ?
We aren't many to sustain 35+ kph average speed, so if you could have a try in this range, that would be great :twisted: :twisted:
(it's to feed our "battery range" topic :wink: )
