Freshair
See that the old sk 6374 had a 10mm shaft, which was changed to 8mm with the updated sk3 6374. Just curious to know if there are any low kv motors roughly the same size as the 6374 with a 10mm shaft out there? Only thing that I have found with a 10mm shaft is the rotomax 50cc, but that beast is 80mm in diameter and far too much for what I'm working towards.
Any help would be appreciated
