Superglue for Brushless Motor -----+++
robert333
Hello, do you know a good brand of glue superglue powerful for brushless motor ??
Mine is damaged and I would like to fix it.
Thank you in advance !
Here is what it is:
https://www.youtube.com/watch?v=oSveMpL-UE4&feature=youtu.be
That's a good question. If it were me, I'd probably try either Loctite or JB Weld. I'd probably try Loctite Red (271) first to see if it worked. I've had a lot of luck with it in this kind of situation (although I've never tried it in your specific type of problem with a brushless motor). If that didn't work, I'd try JB Weld. With JB Weld, I'd scuff up, or even groove, the two surfaces to provide more for the glue to grip to and resist rotation.
I would not advise JB weld. People suggest it but no one mentions it has iron filing in it. It may not help with the performance of the magnets if you were to reattach them with it.
You could maybe try this loctite 410. I've tried jb weld in the past and have had no luck. After applying the jb it wants to run everywhere because of the iron in the resin. Red loctite has a high operating temperature so if you can get it to work that would be ideal. You could also try loctite 410 which is an instant adhesive as well, but the max operating temperature is only 225F, not sure what temps you're running at.
Loctite 40: http:http://www.all-spec.com/Catalog/Adhesives-Sealants-Tapes/Adhesives/Cyanoacrylate-Adhesives/135444-30769?gclid=Cj0KEQjww7zHBRCToPSj_c_WjZIBEiQAj8il5JY0OzvOrz1IWI4MZj8eGg7wipP1iPyZ-L2ZYuzjRDgaAgGw8P8HAQ
