etwow battery replacement
tung256
Post by tung256 » Nov 29, 2017 10:50 am
my etwow stand up scooter battery is no longer holding charge after 300miles. i dont remember charging it more than 30 times, thought the battery life would be much longer.
anywho, where can i get a new battery? EVEN better, how to DIY it with normal Turnigy lipo? i dont want to depend on proprietary battery packs. please help
MrDude_1
Re: etwow battery replacement
Post by MrDude_1 » Dec 19, 2017 2:09 pm
disassemble.
if its 18650 cells... great. tons of options.
if its lipo pouches, either measure for replacements, or figure out what you can fit in the stock box.
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
tung256
Post by tung256 » Dec 21, 2017 1:12 pm
for now, it's range is 1/3 of when i first got it. so instead of 12 miles range, i get about 4 miles.
i also noticed it charges up to "full" in 1 hour instead of about the original 3hours. what does that mean? maybe 2/3 of the cells are damaged and the BMS is smart to skip those damaged cells?
Buk___
Post by Buk___ » Dec 21, 2017 1:50 pm
Could be just one bad cell. Bad cells have lower capacity, so they fill up and reach HVC faster, leaving the good cells way under charged.
Only way to know for sure is break the pack down and cycle test each cell.
