remf
I'm surprised that the Pipistrel Panthera Electro - the first plug-in four seater aircraft - hasn't been mentioned here yet but it is certainly impressive looking & sounding, much like all their other mogas models like the Virus, Sinus & Taurus. Cruise speed & range are obviously not that of the regular Lycoming IO-390 powered Panthera - 202 knots vs 118 knots for the Electro version & 1025 NM vs 215 NM for the Electro.
On the full IFR panel there are three functional areas: the upper back-up/annunciator area, the PFD/MFD area and the communication stack. The avionics are gathered around a Garmin G500 series PFD/MFD synthetic vision screen and the new Garmin GTN series touch-screen Flight Management Systems. It features a full-airframe parachute rescue system, which was specially developed to allow deployment at both low and high speeds, as well as at low altitudes.
More interior room than a Cirrus, costing around €400,000 and available later this year, it seems the *only* hinderance to mainstream acceptance is the very limited range and limited power. Pipistrel have made the battery packs swappable and therefore able to leverage advances in cell technology to increase the range in future.
Motor output 145 kW / 195 hp
Stall speed (flaps extended) 109 km/h / 59 kts
Stall speed (flaps retracted) 118 km/h / 64 kts
Manoeuvring velocity (Va) 248 km/h / 134 kts
Turbulence penetration (Vb) 324 km/h / 175 kts
VNE 407 km/h / 220 kts
Typical cruise speed (TAS) 218 km/h / 118 kts
Climb rate at MTOW 5.7 m/s / 1140 fpm
Take - off run 385 m / 1265 ft
Take-off distance (50 ft obst.) 700 m / 2300 ft
Landing distance (50 ft obst.) 570 m / 1900 ft
Range at cruise speed, >400 km / 215 NM
4 people aboard (incl. 45 min reserve)
Service ceiling 4000 m / FL 130
