This fully charged episode on electric planes is pretty interesting. There are even more advantages of electric over hydrocarbon in planes than in cars (e.g. electric doesn't require oxygen, not rotationally sensitive, etc.). It's amazing that his current prototype is designed get to 20K feet faster than a modern jet fighter.
Note:
Regarding the "beat a jet to 20,000' altitude", there was a little qualification there that was easy to miss. They were qualifying that stating that both aircraft were sitting on the ground with the engines off. The fighter jet would take a minute (I think they said 90 seconds) to get the engine started and the temps stabilized before it starts the takeoff roll. All that time, the Electroflight is gaining altitude. Many modern fighters have more than a 1:1 power to weight ratio while in full afterburner.
High Performance High Powered Electric 300+mph Racing Plane
Best Wishes!
Mitch
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Two examples are Chevy Volt and Nissan Leaf packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
Mitch
The cells are rated conservatively by GM at 7.8C, Yabert's tests of Volt packs on the DiyEv car forum suggest a higher C rate, 15+ C!.
$1,400 plus $360 freight. Still over $1k less than new lead!
Re: High Performance High Powered Electric 300+mph Racing Pl
Similar idea and specs to the Siemens powered electric Extra 300. http://www.siemens.com/press/en/feature ... omotor.php
- 10 kW
No power loss due to density altitude is a great feature of e propulsion. Biking at 8 or 9 K in Idaho, it is appreciated. The peddler can't say the same unfortunately.
No power loss, but aircraft power requirement still increases with 1/square-root of air density,* and cooling might become an issue especially at takeoff when runway density altitude is exacerbated by summer heat and you want full motor power available. One presumes that adiabatic lapse rate would make cooling loss due to low density less of an issue once airborn.craneplaneguy wrote:No power loss due to density altitude is a great feature of e propulsion. Biking at 8 or 9 K in Idaho, it is appreciated. The peddler can't say the same unfortunately.
*Power requirement is related to true airspeed, while aircraft performance depends on indicated airspeed, which is where the sqrt factor comes into play.
An impressive display of aeronautical trivia, but irrelevant to the discussion...
