Powering Micro Sub
Boats, Jet Skis, Kayaks etc., including hovercrafts
Re: Powering Micro Sub
Postby nutsandvolts » Sat Jul 18, 2009 8:14 am
nutsandvolts
Postby Submariner » Sun Jul 19, 2009 4:28 pm
Quote:
"I agree, lead is definitely the way to go, as this vehicle can take advantage of the weight. Also, lead acid is often actually better than LiPo in terms of high peak power delivery, where it loses out is weight and capacity, which are not a significant problem for this application.
I also think the Mars brushless is a good option, as again it's weight would be useful and not having brushes is an advantage in a high humidity working environment.
This sounds a fascinating and interesting project. I'd love to see some photos.
Jeremy"
Thanks Jeremy, I'd like to pursue your line of thinking.
I have access to two, brushless, axial flux PMSM motor prototypes that a friend has been developing,
full-time, for a couple of years now. His biggest struggle seems to be the controller.
Can you tell me more about the $22 ones you found in China?
He's recommending 36 volts for my application.
I'm thinking of a total of 48 of the SLA 6-12's I mentioned previously.
So, 6 in series, then 4 of those in parallel (24) for each motor. Times two, totals 48 batteries.
The motors are unique in that they are hollow in the middle allowing me to run a solid shaft from one
through a hollow shaft from the other, counter-rotating, directly to the props!
They would turn ~1000 RPM under the kind of load I'm going to have at speed, so no gearing!
I'd like to run a double (or dual, I don't know the terminology) potentiometer from a common knob
for dual speed control without loosing the safety of double system redundancy.
The motors are a little less power than I'd hoped at 4 kw. ~92% efficient should yield 13 - 14 knots
instead of the 15 knots I was aiming for.
A "momentary on" switch would give me full reverse for brakes (hopefully never needed).
If you personal message me your email address, I'll send you some drawings of my project.
I'm unable to post them for some reason.
Thanks for your interest.
Tom
Submariner
Postby John in CR » Sun Jul 19, 2009 7:42 pm
Submariner,
I thought you wanted no brushes on the motors, so I don't think potentiometers are going to be sufficient control.
I take it that you'll be flying through the water in an always buoyant craft, so wouldn't you rather have the increased maneuverability of counter rotating props on 2 separate shafts? Also, with counter rotating props on a single shaft, the high prop efficiency you're talking about doesn't feel right. Please direct me to something I can sink my teeth into supporting that, because if true wouldn't we see a lot of watercraft with that type of rig?
Lastly, how at those speeds do you "fly" around a cable or line already secured under water? I'd hate to see you in a death trap with no means of escape when you get tangled in something already so common.
John
John in CR
Postby Submariner » Mon Jul 20, 2009 12:43 am
Malcolm,
I only just saw your second edit.
The props are one in front of the other, far aft with a small protective cowling.
You are correct, a great deal of thought, design, calculating, modeling, consulting, evolving, compromising,
prioritising, hair pulling, considering, reconsidering, arguing, debating, conceding, evaluating, pondering,
cataloguing, and repeating have already been done.
That is why I am only looking for electrical help on this forum as I understand it to be a good source.
Thanks for your interest, calculations and comments. I will let you know how things develop.
Tom
Submariner
Postby John in CR » Mon Jul 20, 2009 11:56 am
"Small protective cowling" over the props...At that low speed a Kort nozzle will give you a gain in efficiency along with the protection you want.
Yes, there's lots of electrical expertise around here and they're very generous with their assistance. They'll need more info about your motors, and probably the best section to post the specific questions is in the Technical forum, which isn't restricted just to ebikes. There's more activity with all the guru's there.
Personally, I'd like details about your motors including price, because I will be looking for motors very soon to power an electric catamaran.
John
John in CR
Postby dragonfire » Tue Jul 21, 2009 8:31 pm
Not to disencourage you or something, but please also take your time to have an underwater emergency exit strategy if something fails.
Just reflext what you would think of others if reading stuff like ( unaltered complete string excerped from your post above):
"I have access to two, brushless, axial flux PMSM motor prototypes that a friend has been developing,
's"
Statements like these not only smell but allready taste like as if "fail" was to occure, and you don´t want to have this several feet below the sea´s surface with no plan b not reliant of strategy a.
As for emergency batterie power with no need to get maintenance charge and outstanding power density check into reusable Silver-zinc (Ag-Zn) batteries from like saft, this is military stuff but on public avail ( allthough costly).
dragonfire
Postby Submariner » Wed Jul 22, 2009 11:47 pm
Here is some inspiration for Jeremy and Drunkskunk who I am still hoping to hear back from.
I've corresponded quite a bit with Cliff Redus the designer/builder of the R300.
He's still in sea trials and semi-retired with way to much time and money on his hands.
He must have $200 to $500 K into this sub, WOW.
http://www.psubs.org/projects/123768492 ... bmersible/
Cheers, Tom
Submariner
Postby nutsandvolts » Thu Jul 23, 2009 12:14 am
nutsandvolts
Postby dragonfire » Thu Jul 23, 2009 6:36 am
amazing videos, what a great vehicle.
as for the price of such builts,i believe it an be had cheaper. the father of a loose friend family of my parents built a 17 x 3.5 x 5 meter steel boat in his friggin garden. it took him over 10 years but lesser than 40k dollars total cost ( including engine and everything interiour and installation) at actual costs as he was doing most of it on himself. another 15 k dollars had to be paid to finally get it transported into the water and anoter lump sum for the homologationing of the ship but: if doing most stuff on your own or have a social environment with machining capabilies on cheap avail it can be done at a price competitive with nicer kit cars, even moe in the times of the virtual bays as for parts sourcing.
dragonfire
Postby fechter » Thu Jul 23, 2009 8:08 am
I don't think I would really trust a $22 chinese controller for a project like this. I would suggest at least a Kelly controller or perhaps a Curtis or Sevcon industrial strength controller.
fechter
Postby Submariner » Fri Jul 24, 2009 9:54 pm
Looks like we lost Jeremy, I know he's busy.
fechter: I don't intend to use the $22 controllers from china but I was interested in Jeremy's comment on them
and to know more about them. I'm learning.
dragonfire: I don't intend (nor am I able) to spend that kind of money, or have that kind of complexity. K.I.S.S
nutsandvolts: Don't over credit the personal sub guys. They don't do a lot of "cruising around". They're mostly
into going down for a while and coming back up.
john in CR: I've researched nozzles thoroughly. They only work at high thrust and low speed. I have neither.
In my situation they would produce more drag than benefit and have a negative effect. What more info would
they like on the motors? I tried posting on the Technical forum as you suggested, it's not possible, it is
reference only. FYI this is not the ebike forum it's the electric vehicles discussion forum. I thought it the
most appropriate place to post after reviewing the options as this is a vehicle as are airplanes and space craft.
I have plan a, b, c, d, e, f, g, h, i, j, k, l, m, n, o, p, and q at this point, but thanks for your concern.
The potentiometers are intended to direct the controller. None of this should be brushed, it all needs to be
ignition protected, no sparks. Please, what should I be using? Do the research on low thrust, contra-rotating
marine propeller drives and let me know if it still feels wrong. It's not one shaft, it's two (see thread).
Malcolm: In reviewing your calculations I believe you were assuming 12 volt batteries, mine are 6 volt.
Although Seadoo or troling motors may seem atractive they have lots of shortcomings for my application.
vanilla ice: I think I missunderstood your question, you tell me. Are these batteries appropriate?
Submariner
Postby dragonfire » Fri Jul 24, 2009 10:39 pm
since you brought up the "no spark" point: will the batteries be stored in an airtight/ gastight compartment in which this rule ( no spark) won´t apply but the problems of gassing out batteries have to be somewhat taken into consideration ? as for the 22 $ controllers, i am plenty sure they will not serve this safety feature by a certainity you should require of it if i am guessing right for the (obvious) reasons when using pressurized oxigen in the capsule.
dragonfire
Postby Submariner » Sat Jul 25, 2009 11:37 am
dragonfire,
No, the no spark rule must apply throughout the vessel.
There will be no pressurised oxygen on board, other than the ~20% found in air.
Tom
Submariner
Postby Malcolm » Sat Jul 25, 2009 3:06 pm
Submariner wrote:Malcolm: In reviewing your calculations I believe you were assuming 12 volt batteries, mine are 6 volt.
My mistake, my estimates were based on 12V batteries not 6V, so for a 6 kWh pack based on your existing batteries that would be 8 banks of 10 batteries wired in parallel.
The 3 kWh requirement I gave was a guesstimate - so I have a few questions myself, just to try and get a better idea of the performance and capacity requirements:
Where does the 10 kW peak requirement come from? I imagine you've already done your own power calculations, but just to double-check.
What would you consider a comfortable lower cruise speed and have you calculated the power required to maintain this speed?
Why does your friend recommend 36V? Is that to suit his own motors, or is there some other reason? Producing 10 kW from a 36V system naturally requires more current than from a 48V system. This in turn means more motor heating (proportional to current squared). Heat build up over the course of an hour could become uncomfortable in a confined sub.
I'd echo what others have said and suggest going with a known reliable combination of motors and controller, running at the highest voltage you feel safe with.
Why the need for spark-free equipment? Is this just a general safety requirement or a consideration for the lead acid batteries?
(dragonfire: divers don't use pure oxygen as it becomes toxic even at shallow depths, though they do sometimes use slightly increased oxygen levels for relatively shallow dives). How spark-free does it need to be? Does this extend to all switches?
Malcolm
Malcolm
Postby spinningmagnets » Sat Jul 25, 2009 3:14 pm
I must agree. Do not bring pressurized oxygen any where near the vessel. Should a salt-water leak occur in the separate and sealed battery compartment, a relief valve should vent overboard to allow the poisonous/flammable gas to leave.
It might be wise to add a pressurised air-bottle and a Lithium-Hydroxide filter to absorb CO2, they dont take up much room.
spinningmagnets
Postby Submariner » Sat Jul 25, 2009 7:52 pm
The no spark rule seems a prudent safety measure to me. I don't know how spark free it needs to be but 100%
comes to mind. Does this create a big hurdle? I have electrical knowledge but limited practical experience.
This machine is incredibly simple and relys little on electronics accept for the drive train.
I agree with the proven equipment concept 100% but what is desirable with these motors is at 36 volts they turn
1000 RPM. The builder (who has a formal electronics education and carreer) feels 36 volts a safe limit for a
submerged, salt water, confined space. They are also hollow in the centre allowing a solid drive shaft to run in a
counter-rotating hollow shaft to each prop. No gearing. It's a very attractive scenerio. I am a very cautious man,
father of a three year old and would certainly do a LOT of testing and proving before going this route, but I
have to investigate it. I will be in a 1/2 inch plywood box within the sub. The exhaust cabin
air that vents on each partial or total ascent, will vent past the batteries and motors. To vent the batteries
seperately is not physically possible. The best I can do is keep them down stream. Also, I will be breathing from
a SCUBA regulator, with a mask, for safety (CO2, H2, flooding, etc.). My seawater temperature is 9C (47F) outside
of a 1/2" fiberglass hull. Also, the prop hubs will likely be aluminum or steel and there could be additional hull
cooling if necessary. Eight banks of ten batteries is beyond my present design limit (space and weight). As you
can appreciate, change one thing in a submarine (or submersible) and you change everything. Kind of like a
jigsaw puzzle. Yes, my power reqirements have come from calculation which I am very confident in.
Power has a cubic relationship with velocity in a sub. So, 4 - 5 knots would be a low end speed expectation
and would use perhaps 1000 watts. I think your 3kw was a very reasonable guess, 2kw/hr may even be closer.
Needless to say, I will be very conservative in my initial sea trials which will likely last a long time
(i.e. many trials). These motors are 4 kw so I loose a knot, no big deal. 14 knots vs 15.
dragonfire (on a PM) feels these SLA's are too thin plated to withstand the loading I'm proposing.
It sounds like if I want to use these batteries, I may have to tone down the power demand and loose
some top end (max speed) or at least some duration at full throttle...
Tom
Submariner
Postby dragonfire » Sun Jul 26, 2009 4:03 am
the pm you reffered to wasn´t sent by my, but the author is right nimh won´t serve the power output yu want on a small physical footprint. nimh may be an option, but lifepo4 seems the best choice if it comes to safety with high storage density and good capabilities to be overcharged and discharged.
but there are good sla chemistries out there, too, the 12-12´packs accept twice the peak output of the 12-7/9 cells.
Panasonic LC-RA1215P ( 12v 15ah, ) and it´s outstanding characteristics ( burst discharge per cell 195 amps, 6-9 yrs lifespan, certified for medical devices...) seem to be suitable. 3s4p of them in parralel should suffit. Panasonic seemingly also has nice stuff in the smaller 12v-7ah/9ah seize:
The Panasonic UP-RW 1245P1 . Allthough no mentioning about lowest advised voltage or maximum charging currents, a certified discharge rate of 268 watts/ 10 minutes per batterie sounds promising, alongside with 6 yrs lifespan and the fact that these are permanently charged at 15 volts in the epsu-systems they are designed for. these have a internal resistance below 10 ohm i believe. maybe a 2s5p setup of the 12-15 ´s and a booster pack hooked up in series to each bank consisting of one of the 1245P1 ´s to get your 36 volts and have both high discharge capacity and stable basic power ?
edit for safety:
a plywood box is not airtight. seal that up and only open this box when charging the batteries to allow them gassing out. if you ground your voltage to the water make sure that the cabin is opened and gassed out, same with the battery box, before lifting it of the water.
since you use a glass-fibre hull you can carry a cutter with you to allow for an escape exit if you get caught in a net or cables or whatever else may stock you when doing dives in canyons or whatever (so no explosives needed to split a steel shell).
if you are not too deep this should work, even with the rapidly altering compression states- but some emergency flooding valves to ramp such an emergency escape smoother can´t hurt.
also , check into oxigen generators like used in airplanes, they have to be replaced periodically but are still good. these heat up pretyy well when used, but they are small and can get you some emergency air pressureinto the cabin in case of a leak.
dragonfire
Postby Submariner » Sun Jul 26, 2009 10:28 am
Pardon me dragonfire, my mistake, it was drunkskunk's PM, I apologize.
I'm really just looking to power the sub not redesign it.
I'm on this forum for electrical and electronic advise as this is not my forte. I realise this may overlap into
overall design, but I can sort that out. You're going to have to dumb down the terminology/jargon in your
posts if I am to get much from them. I have had some electronics education so I know the basics but am
by no means up to date nor conversant as the majority of participants here.
I do appreciate your efforts, it's a shame to see them go to waste.
Thanks, Tom
Submariner
Postby dragonfire » Sun Jul 26, 2009 12:02 pm
not a problem if you are unsure about how to set the batteries up:
all batteries will spark when grounding is there and they are hooked up to the device. this may also occure if grounding is interrupted due some event, so make sure the batteries are sealed if your air coudl react with it.
the batteries themselves, you´ll want a 24 volts controller than can take 36 volts safely and go up to 45 volts cause that´s where the following setup will be at if fully charged:
2 12v15 ah batteries in series ( ="S"), 4 of them in parralel (="P"), this adds up the voltage of the batteries if in series and the ampere-hours (durability) in parralel.
then you´ll have a 24 volt setup.
you mentioned you would like to have 36 volts allthough the designer pointed towards 24 volts, so you will use this extra-power only to "boost" in streamings or whyever.
you could also have a look int 6 volt cells with equal ampere´s this will double the boost time.
this leds to the booster pack setup, connected in series (so it will increase the voltage) of each of your four parralel 24 packs. this pack ( connected by a switchable ( due current demand of throttle) schottky diode) will have lesser ampere-hours as it´s only one batterie compared to the 2x12 volt packs for regular operation, but they deliver their volts and also ampere´s faster than the 24 volt setups chemistry and thereby prolonguing the operating time of this pack cause they deliver faster on all load conditions ( cause of this you will want the switching diode and it should be a schotky cause it´s simple and does not allow reverse charge of the 24 volts pack to the emptied booster pack) and thereby keep the distressment of the main pack thus reducing peukert effect and general draw so you will prolongue your operating time per weight of batteries and still have the advantages of a 36 volt setup when needed without the paermanet load on batteries required for regular 36 volt operation.
as for controller, i´d recommend to get a 25-5000 ohm controller ( "5k ohm" ) and throttle cause you can add on nice little e-bike and scooter gimmicks like cruise control and also this will draw the batteries by modulation on current needed and not voltage available, alowing for a better control and also saving on battery lifespan. and you could use that to allow switching to the booster pack not in manual or by a releais/ diode but a mosfet or thyresistor setup, but this is non-needed complication for the first setup atrempt if improvements on details are scheduled as ongoing progress in the built touched water several times.
i´d also recommend a balancing wire in between both banks.
dragonfire
Postby Malcolm » Mon Jul 27, 2009 4:52 am
Hi Tom
Thanks for the info. Yes I can see there are big advantages in using the hollow shaft motors your friend is building. 36V also makes sense for low prop speed. Motor cooling may be an issue, but if you keep the prop shafts as short as possible you should get some useful seawater cooling. I'd recommend testing the new motors with an industrial quality controller such as the Sevcon that Fechter mentioned, and which I linked to earlier. You'll need one for each motor if it works out OK.
Assuming a 36V system and a useful pack capacity of 3 kWh (which again means a rated capacity of 6 kWh for lead acid):
6 kWh divided by 36V is roughly 168 Ah, so you need a 36V pack with a capacity of 168 Ah.
To get sufficient capacity with your existing 12 Ah batteries that would mean six banks of 14 batteries, which would mean a lot of connections and a lot of possible failure points. I'd suggest looking instead for some good quality 6V or 12V batteries of sufficient capacity that you only need to use three or six batteries in total. It may take some looking around to find batteries of the correct form factor to fit in your available space, but I have seen large capacity deep-cycle batteries in a long, slim case – just can't find the link right now.
For switching and isolating the battery pack from the controllers, I'd recommend a pair (for redundancy) of enclosed heavy-duty contactors, such as the EV200 (ebay item number 200363534803).
What else do you need to know?
Malcolm
Postby dragonfire » Mon Jul 27, 2009 11:09 am
this much energy would suffit to drive 1 hours at speed as it seems, and industrial controllers ( forlifts ?) seem a good idea, too. you wouldn´t wan tto rely on chniese untested and unmatched controlelrs for that, due the lots of handcrofting there may be differences in internal resistance or even parts/ wires even if both are of the same batch.
as fro deep-cycle sla s, if they don´t have to be slim there are fairly big car batteries with 12v and up to 180 amps each easily available, looks like a non-stacked 10 cell design so these shuld be rockstable even in after several cycles and without balancing ( given the idea the recharge will take place with one charger and each cell after the other one)
dragonfire
Postby Submariner » Mon Jul 27, 2009 11:50 am
Thanks Malcolm, that's great. Unfortunately, I am constrained by dimensions with the batteries.
My space is small and tear-dropped shaped with the widest point being 16 -20" (not yet finalized).
A huge advantage of the batteries I have is their size, 2 X 4 X 6 inches. I am able to fit them in above
and below my prone position. I'm thinking I need to alter my speed objectives. More steady state
1000 watt cruising and less (if any) full throttle time. Maybe when these batteries are toast
I can invest in some high power density "wonder batteries" eluded to earlier in the thread. The R300
of Cliff's (web-site posted previously) uses deep-cycle, 6 volt, golf cart batteries. He's got the space
but not the performance. Ha, neither do I now that reality has set in.
Maybe I need to go back to the drawing board and look at a larger diameter vessel that has room for
those big batts. The second largest contributing variable in submarine speed is diameter, how big a whole
you need to open up through the sea. The first of course is velocity. These motors are about ten inches in
diameter so the shafts end up being about two feet long. Although, I could flood the shaft area.
How do you feel about the 48 vs 36 volt safety issue?
My contingency plan, should I flood, is to beach, which should be feasible as I'll be operating in shallow water
near the beach, so long as I still have propulsion. Now this would be at full throttle with "sealed" electronics.
If flooding is too rapid then it's evacuate with the scuba tank and lose the sub to the shallow ocean floor for
subsequent recovery. Motor flooding will be delayed but inevitable. The battery terminals would likely be the
first electrical component to see salt water.
The long slim SLA I know are 2.2 volt, single cell units about 150 pounds each. We used 7 of them in series for
solar powered, mountain top earthquake sensors here.
Thanks for all the info Malcolm, I really appreciate it.
Tom
Submariner
Postby dragonfire » Mon Jul 27, 2009 1:42 pm
solar charged seismic sensors have a far lower charge and discharge current than your project, having 6 x 6 volts in series and many in parralel will require balancing both on charge and discharge, since this endevour will require many connect diodes you will have to have a active balancing system cause the exact resistance in between these diodes will vary a little. you´ll run into the more complications the more cells/ batteries you use.
as about the design, will the batteries be positioned at the bootom of the submarine to keep it balanced that way or is there a way the battery box can be placed as a seperated section ( full or half-moon diameter of the sub) in between rear engine and passenger zone ? this way the battery bay could bring some additional strengt to the scelleton and also be tightenen (airtight9 more easily, allthough most of the sparking will be done at the controlelrs if anything is mounted right i believe (?).
As for sealing this all up, there is another thread in the forum about a guy who wants to make his hubmotor (in a wheel9 watertight. what kind of bearing (-s) will you use on your driveshaft, what lubes ( since not all have access to fat of whales or other exotic crap) help to keep the driveshaft rotating in a solid bearing and stillseal the water ?
dragonfire
Postby Malcolm » Mon Jul 27, 2009 3:43 pm
Yeah I know, it's a bugger having to compromise on a design you've tweaked to near perfection :) If you could just distribute your own body mass in the spaces that are left over after fitting batteries, motors and air cylinders it would be much easier ...
OK, just for comparison, if you were to go straight to lithium batteries, you could roughly cut the volume in half and cut the weight to one third.
To give 3 kWh of useful energy you would need a 36V 100 Ah pack (lithium can deliver much more of its rated capacity than lead).
This could be made up of twelve 3V cells http://www.evcomponents.com/ProductDeta ... DLFP100AHA, each measuring 145×220×68 mm and weighing a total of 43 kg.
The drawback is that you would need an electronic battery management system – a circuit board(s) with connections to each cell that makes sure individual cell voltages do not go too high or too low. These can be bought off the shelf, but obviously add to the cost and would require waterproofing.
As far as safety is concerned, I don't think there's a big difference between 36V and 48V, but I don't have any experience in underwater applications so if anyone thinks otherwise please jump in. A brushless motor should run underwater without problem, although it naturally won't do the bearings any good. If you keep the electrical system simple I don't see any reason why it shouldn't carry on running when flooded. You will lose some power through electrolysis at the battery terminals, but I wouldn't expect it to be excessive. (I remember producing some very noxious fumes when I played about electrolysing brine as a kid, but if you're wearing scuba gear that's not a problem.)
Malcolm
Postby Submariner » Mon Jul 27, 2009 4:12 pm
Hi dragonfire,
I have no intension of using those 2 volt batteries, I was just sharing what I knew (not much) with Malcolm.
They are what I'm familar with, what I've worked with, what I know and have wired, metered, carried, slung by
helicopter, etc. So, the batteries I have are 3 cells each, as you may already know, and there sure would be a
lot of cells once all wired up. I had no intension of using diodes at all.
I've been trying, again, to get some drawings posted to give a better idea of what I'm doing, but this old Mac
(10 years) just doesn't want to cooperate with this forum. So, I'll have to tell you instead. No, the batteries
are not on the "bottom". This is a very unconvensional sub, it is asymmetrically balanced. What I'm after is
jet fighter performance and handling, or at least as close as I can get. I have an extensive background in scuba
(instructor, construction, rescue, even logging, etc.) and am completely bored with it. I have 83 hours on a
private pilots license from when I was a kid and thought I wanted to be a helicopter pilot. I have both
motorcycle and car racing experience. I have a Mechanical Engineering Technology diploma from 1983.
Plus a wack of other crazy experience. The batteries were to be placed above and below my prone position
creating zero intrinsic stability, no righting moment, zero inherent stability. This makes for crisp roll response,
driver control and manoeuvrability. Again, I tell you all this in order for you to better understand my intensions
not so you can redesign or "improve" on it. I've been working on this concept / design for over a year and have
done a lot of research and development. It turns out I should have done a little more on the powering issue
first. I thought I would be okay with what I had.
Because this is a delayed ambient pressure design, it's very difficult and complicated to isolate the batteries
from the cabin. Complicated is not good in my design, it relies heavily on simplicity. (My wife laughs at this one,
she says, "The words simple and submarine do not belong in the same sentence". She makes a good point but
I beg to differ.) I can however direct air flow, so I'm keeping the batteries downstream of the controller and
my mouth. Although I am breathing from a scuba regulator, in the event of an air supply failure, I will have to
breathe the cabin air for a while. There is no conning tower, the only way in and out of this thing is on the
trailer, accept in emergency, but that means losing the sub to the ocean floor.
Thanks for your input though dragonfire, I do appreciate it.
Tom
Submariner
Next
Return to Electric Watercraft
Who is online
Users browsing this forum: No registered users and 1 guest
