Hi everyone,
I've recently been toying with this idea I had. I was looking at a couple of human powered hovercraft, that is, powered by the hovercraft driver pedalling, like this very impressive one here: http://steamboatwilly.org/ , and this UH plan here : http://www.hovercraft.com/content/index.php?main_page=index&cPath=5_38 .
According to Wikipedia, an adult of good average fitness averages between 50 -150 watts cycling power output for an hour of vigorous exercise. So as you can probably guess, I was wondering if it would be possible to swap the pedal power for electric power. To me it seems that there is no obvious reason why not, but maybe I am missing something. Yes you would add weight with adding an electric motor and batteries, but perhaps this could the same weight or lighter than the pedals/gears/chains.
It seems absurd, but if we take 100 watts to be the required power, then a fairly small and cheap model aircraft motor, and a lightweight lithium battery, could supply that power.
What do you folks think? Thanks for any replies. It seems incredible that a 100 watt motor could hover a human, when most 1 person hovercrafts use a few horsepower, but maybe this is a result of the extremely lightweight design of these human powered hovercraft. Also, there are model aircraft motors that can far exceed 100 watts power.
