Electric hovercraft
Boats, Jet Skis, Kayaks etc., including hovercrafts
evc-motors.eu
Electric hovercraft
Post by evc-motors.eu » May 18, 2014 3:13 pm
Great fun, 45minut flying per one charge
sk8norcal
10 GW
10 GW
Re: Electric hovercraft
Post by sk8norcal » Feb 10, 2015 5:01 am
sk8norcal
10 GW
10 GW
Post by sk8norcal » Feb 10, 2015 5:13 am
mikebikerad
Post by mikebikerad » Mar 29, 2015 12:16 am
not electric but it should be!!!!! Four!
vax
Post by vax » May 11, 2015 12:14 pm
I'm dreaming of hybrid hovercraft.
It would use small diesel (vw lupo 1.2 etc) that powers radial fan and generator.
On the top, there's two big RC brushless motors with propellers. Both motors would be separately throttled and also would rotate 360 degrees.
Also, there would be battery pack for sudden acceleration and short periods of greater speed
Ideally it would be closed like small car with comfortable cabin. Car seats, dashboard etc.
Prototype fabrication https://www.facebook.com/3dflux
mikebikerad
Post by mikebikerad » May 03, 2016 11:25 pm
I would have killed for a hover sled as a kid. The rubber material used on the skirt looks like it would not last long on gravel or rough paved surfaces, anyone know what that is? PVC maybe with a thin Polyethylene patch between the road?
Rusty Mustard
Post by Rusty Mustard » May 09, 2017 11:37 am
Hi all, i've been doing RC hovercraft for a while and pretty soon i'm going to start building a pedal-electric powered hovercraft. So far all my hovercraft have been non-person carrying models, but over the course of several many generations of evolving the plenum, hull, and skirt design i know what i need to do to build one.
Here's one of my models of a skirted craft, i plan to start building something like this that will roll on retractable trike wheels inside the skirt, and when the skirt is inflated by pedal power, retracted flush with the lower hull deck. I'm thinking one of the bigger Astroflight brushless outrunners with a 24" prop can provide thrust while the rider pedals at cadence to provide the lift.
https://youtu.be/7-oTpiiwjVA?list=PLGbZ ... cCy8zQNdTt
If i get to the hardware store this week i'll probably pick up the stuff i need to build a metal frame supporting a wood-foam sandwich double hull.
