dudevato
Just found this site and joined.
The pics are of my 3rd solar only boat. It's 16ft and has 6 panels each rated at 130watts. The framework is 1" EMT. Power are 2 30lb thrust MinnKota motors. The panels are wired in parallel for now. Speed is determined by switching on 1 or 2 or 3 panels to each motor. I will have an option to switch on all 6 panels to one motor for a cloudy or sunrise/sunset condition.
The outrigger is 9 1/2' and breaks down for transport. It will be fitted with a sand chair and umbrella I've a pair of watt/amp/amp hour etc digital gauges that will let me keep an eye on things. I rigged up a one of a kind Speed-O out of a lawn mower wheel. I made jigsaw cuts in it then Shoe Goo'd fender washers in place. I mounted a $10 kid's digital bicycle speed o meter to provide some speed figures. I'm sure this can be calibrated with the use of a GPS. I put this together to keep track of figures as I mess with different props and wiring configurations, etc. The sheet metal cover is Necessary as the first unit I made was Very Loud and Splashy.
I'm looking forward to hearing any and all comments. I started a Yahoo Group called LittleSolarBoat you might want to check out.
Most members are using solar in conjunction with a battery but not Me
https://groups.yahoo.com/neo/groups/LittleSolarBoats/info
O heck, I don't see how to attach pics, 'maybe I need to be here a while before I can. I've lots of pics of my boat on the Yahoo site. Gary in northern California
