John in CR wrote:Lock,
Thanks for sharing but I'm sure Jeremy as well as myself want to build electric boats that are useful.
Jeremy Harris wrote:The canoe I'm planning to build is the Selway Fisher Raven on this site: http://www.selway-fisher.com/Opcan16.htm. It's a ply, stitch-and-glue, open canoe. It seems to need around 40 watts or so to travel at 3.5 to 4 kts. It's maximum hull speed is about 5 kts, but it would need around 200 watts to reach it. My plan is to build a cruising boat that I can use to travel inland waterways and lakes at normal paddling speed, hopefully with some solar cells to augment range and allow charging when not moving.
The finished canoe should look like a scaled-down version of a typical Victorian electric river canoe like this one:
Make the hull in the clip longer and it's likely to go faster on the same 200W. I'm looking at building a 1000-1500lb cat that can handle another 1000-1500lb of passengers, and is sturdy enough to be comfortable 30-40miles out in the ocean, and will achieve 6-7 knots (the high end of trolling speeds for sailfish, marlin, tuna, and mahi, which a prevalent here "in season") using only 1200-1500W.
John
BMI wrote:Hi to all you guys who are interested in large electric boats.
I thought I would post some info on an e-boat project here in case anyone is interested.
I am in the middle of a project where we are converting a 50 foot racing catamaran to all electric drive. This will be the most technologically advanced electric boat in the world when it is finished due to the advanced battery diagnostics and monitoring capabilities. It will be powered by three 5kW Power Pod retractable electric motors. We are just waiting for the motors to arrive from the US any day now. The 48V 240Ah battery bank is already at the boat yard waiting to be installed.
The boats' batteries will be recharged by solar panels, back-up diesel generator and re-generation (when the boat is under sail power in strong winds).
The boat has been entirely stripped out now in preparation for fitting of batteries, motors and all associated electrics.
I will be happy to provide updates as to progress if there is interest here. There will be a full featured article appearing on this electric boat in at least two major boating/alternative energy magazines which will show to those involved in the boating industries what is currently achievable with regard to electric boat technology.
John in CR wrote:BMI wrote:Hi to all you guys who are interested in large electric boats.
BMI, yes definitely keep us posted on progress. Out of curiosity, did you slip a digit on the battery capacity, because that's only 11kwh of capacity, or 45 minutes of runtime with the three 5kw motors at rated capacity? For the 10m cat for which I'll soon kick off construction, my back of the napkin capacity plan is 15kwh. That is without any solar panels in the budget. What is the maximum output expected from your PV panels under optimum sun?
John
Lock wrote:Beauty boat BMI! Who was her designer please (Shuttleworth?) Will you still be racing her? I understand the daggerboards as max. efficiency for racers, but if I were cruising her I would move to centerboards... (old Tornado sailor here)
tks
Lock
tks
Lock
John in CR wrote:Lock wrote:Beauty boat BMI! Who was her designer please (Shuttleworth?) Will you still be racing her? I understand the daggerboards as max. efficiency for racers, but if I were cruising her I would move to centerboards... (old Tornado sailor here)
tks
Lock
Lock,
Before installing any daggers or keels, look into Anti Vortex panels first. Less surface area so less drag, require no more draft than the hull itself, more effective because they reduce the water vortices that create drag and wake. Look at Bernd Kohler's work he has generously shared in the links on the right half of the page at http://www.ikarus342000.com/Looseends.htm
BMI,
Since it's a refit not a build, I assume that for the PV panels you aren't going with the ones that can be built right into the deck and walked upon. That's the route I'd love to go, if it wasn't so darn expensive. ie a craft covered almost entirely in PV above the waterline would be great. Add in about 1000lbs of lithium batteries, reefable wingsails for more efficient sailing with improved maneuverability (including reverse under sail), plus a nice size wind turbine for battery charging without sun or the need to be under way, and then you've got a near ideal boat.
I assume you plan to use BMI lithium cells. What is special about the BMS mentioned in your first post?
John
Lock wrote:Gawd I love that Solar Sailor. Hadn't checked their site for a long while now. Nice to see developments and growth (apparently) in the offing for them. Didn't see any pics of the "real" Solar Sailor at first, just computer renderings of future stuff, so my fav Solar Sailor pic:
Lock
John in CR wrote:I'm looking at building a 1000-1500lb cat ....another 1000-1500lb of passengers ...sturdy enough ...comfortable 30-40miles out in the ocean, and will achieve 6-7 knots ...using only 1200-1500W.John
Lock wrote:John in CR wrote:I'm looking at building a 1000-1500lb cat ....another 1000-1500lb of passengers ...sturdy enough ...comfortable 30-40miles out in the ocean, and will achieve 6-7 knots ...using only 1200-1500W.John
...been thinking about this. I know you mentioned wing sail (was sorry Walker was never able to make a go of his)... but 2HP approx for the electrics seems a little optimistic. Just thinking of tidal races and ocean currents where ya need a few knots across the bottom just to keep up with the water headed in the opposite direction! Especially in light airs. Or if you want to tow somebuddy or something... fight a fish? Hopefully your topsides will be super smooth too ta keep down the windage... Dick Newicks boats always had very "slippery" topsides:
http://www.jumpcut.com/view/?id=570EB9864F4711DB9FA92EF149F8C96D
BMI's "Room With A View" also looks pretty slippery...
tks
loK
BMI wrote:The boats' batteries will be recharged by solar panels, back-up diesel generator and re-generation (when the boat is under sail power in strong winds).
Users browsing this forum: No registered users and 1 guest
