The title states it all.
I have been riding this setup for about 2 months now.
Here is the full bike:
Here is my Setup:
Bike: K2 Base 3.0 2008 Full Suspension. I believe
Motor: HS3548 from Ilia on ebikessf laced on 26 inch wheel
Tire: Schwable Big Apple 26x2.15
Controller: Crystalyte 12FET sensorless mod to support CA connector and 74V
Battery: 74V13.5Ah nanotech Lipo Battery (2* 10s) and (3*4.5Ah)
Rack: got it from Performance bike
Performance settings:
30A limit on CA
Top speed so far:
30A - 37-38mph flat
35A - 40-43mph flat
I have not tried any higher since I don't know if my FS frame can handle it.
Pros:
A) at 74V, it sure can pull.
B) 37mph solid at 30Amps limit on CA
C) Full suspension makes ride plush.
Cons:
A) 74V*30Ah MIGHT be too strong for the frame to handle.
B) Since my Lipo setup is really light, it can be really unstable due to wind at high speed. At 50mph downhill, it wobbles more than my other Hybrid bike with 30lbs battery in the rear.
Here are some more images:
Motor setup
battery setup
I just bought 37V4.5Ah Nanotech batteries from HK and wired it up all in parallel/series to get 74V13.5Ah. I decided to use XT60 connectors, but plan to migrate to Anderson due to difficulties plugging and removing XT60 connectors.
balance wires running to the front.
I have not completed this bike due to time constraint. I plan to run these balance leads to the front of the bike and connect 4 CellLog to it to monitor all the batteries
Front view.
Front Suspension. This one is 100mm travel I think. Either way it really helps with the cushy ride. Much better than my hard-tail ebike. I am never going to get another hard-tail ever again. haha
Manitou Rear Air Shocks. Again this helps with the cushy ride.
These tires really help with the cushy ride too due to its wide profile. I switched out my original Kenda WTB tires for these. It really helps on road.
All in all I think this is a good bike build.
A couple of more things to do on this bike:
A) Add Doctorbass's Torque arm so that I can go all out at 3.5KW of power
B) Switch to Lyen's 18FET controller for dead stop starting. Hopefully this also eliminates the oscillation of the sensorless controller
C) Add row of celllog monitor to monitor the Lipo
D) Switch the 74V13.5Ah setup to a 74V20Ah setup. I already have the battery. I just need the time to do it. Maybe carry the 74V13.5Ah in a hardcase backpack?
Now that I have experience with both gear and gearless motors here is my opinion on them:
BMC V3 Geared (1700 miles on it so far):
Noisier, This is due to the gears
Lower torque in my opinion, but maybe that is because I am running 74V vs 51.2V.
Excellent freewheeling.
Require lubricant on the motor after so many miles
More efficient. But that might be because I am running it with less power than the Crystalyte.
Here is the full review of my other ebike:
http://endless-sphere.com/forums/viewtopic.php?f=4&t=29194&p=454556&hilit=Transeo#p454556
Crystalyte HS3548 Gearless(300 miles on it so far):
Silent, though there is a high pitch winding noise at low speed.
Can handle more power.
More torque at startup and at high speed
Less efficient. See explanation above for more details.
If you guys have any questions, just let me know. I will be monitoring this thread.
Best of luck for other people building their ebikes
Here is my Setup:
30A limit on CA
Top speed so far:
30A - 37-38mph flat
35A - 40-43mph flat
Pros:
Cons:
Motor setup
battery setup
Front view.
