PowerVelocity controller review
Get real world experience and user feedback on the electric bicycle products.
fechter
Re: PowerVelocity controller review
Post by fechter » Dec 23, 2017 2:15 pm
I like the aluminum angle heat spreader. I considered doing the same thing on mine but did sort of an external version that attaches to my frame.
Powervelocity.com
Post by Powervelocity.com » Dec 23, 2017 4:21 pm
I think I got the original idea of using the aluminum angle from you Mr. Fechter and suggested that to the OP. I never got to implementing it but ElectricGod did. The idea of making the whole frame the heatsink is even more appealing but that doesn't work on all frames.
ElectricGod
Post by ElectricGod » Dec 25, 2017 10:33 pm
madin88 wrote:
Dec 23, 2017 2:51 am
I guess this would only make sense regarding the first versions as far as i could see?
My 12F controllers have already the larger case and larger wires. But a smaller case with improved heat path would be nice but it's not an issue...
I change out the phase and battery wires on all the 12 fet controllers...new or old version.
ElectricGod...it's a joke...don't take things so seriously folks!
XB-502 Moped:
https://endless-sphere.com/forums/viewt ... 0#p1222730
Currie scooter:
https://endless-sphere.com/forums/viewt ... 7#p1227407
ElectricGod
Post by ElectricGod » Dec 25, 2017 10:35 pm
How? Did you file off the fins to make the head spreader side of the controller flat? I guess an external bracket mounted to the heat spreader screws would do the trick too.
XB-502 Moped:
Currie scooter:
ElectricGod
Post by ElectricGod » Dec 25, 2017 10:39 pm
Vadym...
I suppose if you could match the frame tube shape with some kind of aluminum block, then you could mount the controller direct to the frame as a heat sink. Water bottle bolt holes might be a good place to mount.
XB-502 Moped:
Currie scooter:
amberwolf
Post by amberwolf » Dec 26, 2017 12:12 am
Matching to the frame tube would be specific to each frame model, and on hydroformed frames (and many curved frames) specific to the exact location on the frame it is mounted on. For some of the round-tube frames that use "standard" tube sizes, a few different mounts could be made, but there are several diameters used for those tubes.
Makes it impractical to do a production run of such mounts for the general consumer. :/
If they were being built for a run of a specific frame / bike, that'd be different. :)
If you don't worry about surface-area of direct contact for best thermal transfer, I suppose a single wide (large diameter) curve could be made, so it would sort of cradle most tubes, and then use thermal transfer pads to help fill in the gaps on all the frames they dont' match curves of.
ElectricGod
milliohm meter comparison
Post by ElectricGod » Dec 26, 2017 8:29 pm
I received the 4 wire milliohm meter today. There was no doubt in my mind that it was going to outperform the 2 wire meter. I zeroed the meter and then measured a random precision shunt and it was pretty close to dead on. That was exactly what I expected.
People think I was stupid for buying the 2 wire meter. They completely missed the reason why I bought it. So anyway...
I didn't buy the 2 wire meter expecting it to have the precision of a 4 wire meter. I was never under that expectation. I just wanted to see if it was "good enough". Why buy a $100 meter when a $40 one can do what you need? Not everyone needs to measure down to 1 or 2 milli ohms. Lots of folks don't even need to measure down to 1 ohm. For people needing better than 1 ohm and down to .03 ohms, well the $40 MESR-100 with the factory test leads will do just fine for them. Once I have the Kelvin clips that will make it a bit better than it is now. I think .01 ohms will be doable reliably. The crappy alligator clips it came with are not exactly spectacular. So depending on what you are looking for, It may very well be "good enough". It just depends on what you need. It definitely measures resistance in or out of a capacitor so that's proof that while it may have been built for use on capacitors, it also serves other low ohm uses equally well. With the factory alligator clips, I wouldn't rely on it for measurements lower than about .03 ohms. We will see about using Kelvin clips. I'm sure they will help in getting better results.
So then...like I've said all along...the results will be the results and here you go! I used the same shunt on both meters. Of course the 4 wire meter was close to dead on, that was never in doubt or anything I ever questioned.
I will label 10 AOT290's 1 to 10 for this test. I'll arbitrarily pick 10 mosfets from my "stock".
1. The first test will be to bias the AOT290's to 10 volts on their gates and measure Rds with both the 2 wire and 4 wire meters and the newest component tester which measures Rds.
2. For the second test, I'll measure a resistor to put in series with source to drain and measure voltage drop across the mosfet and the resistor. The gate will still be biased at 10 volts. I'll use the same 10 volts for measuring Rds. The current through the resistor will be the same current flowing through the mosfet. Once I know the voltage drop across the resistor, V=IR will tell me the current through the resistor. That same current and the voltage drop across the mosfet will tell me its Rds. This will make a nice double check of what the 3 meters directly measure for Rds.
3. The final test will use the same test set-up as number 2, but the gate voltage will be increased slowly. According to the AOT290 spec sheet, the mosfet gate threshold voltage is supposedly a minimum of 2.9 volts and a maximum of 4.1 volts and typically at 3.5 volts. This is the value that I have seen to be widely different from the spec sheet on my component testers. I have not been able to test Rds previously for obvious reasons, but I will use the 4 wire meter to measure Rds at the minimum, typical and maximum threshold voltages. I will also put a mosfet in a couple of component testers to see what they measure for the threshold voltage. This test will be to prove that what my component testers measure is in fact accurate or not for this spec.
That ought to settle any questions about AOT290 mosfet consistency or lack there of and whether an inexpensive component tester is a contemptible POS like some folks think or a worth while and inexpensive test tool. The results will be the results...as always!
Since I have 25 brand new, never been pulled from the antistatic packaging IXYS IXFP180N10T2 mosfets, I'll do the same tests on them. We will see what happens! I'm also thinking of doing the exact same thing on some TI mosfets, but I would need to buy them first. I have some IRF4110's that I bought on ebay a couple of years ago and a bunch that came from digikey I think. I've kept them separate the entire time I've had them. It might be interesting to see if my ebay mosfets are as good as the digikey ones. With all of these tests, I'm looking for consistent results between the various test methods and the test tools and that the mosfets really work according to specs.
XB-502 Moped:
Currie scooter:
ecross
Post by ecross » Jan 02, 2018 11:47 am
Hello,
thanks for show your 12 to 24Fet Controllers.
For my next Bike/Trike I`m looking for a 15 to 20kw Contoller. The 24Fet Controller is really interesting for me. Also a variable Regen is welcome, do you have ever test Regen or var. Regen on your Bikes? The new 120V Fets are also good step into the right way. Less Ri and some more Voltage for saefty is good.
BR
NC 2805 mod.
H4080 mod.
4503 mod. 4504 mod.
LiIon Sony, Sanyo, Panasonic
Siemens 2000W travel charger
ElectricGod
Post by ElectricGod » Jan 02, 2018 12:30 pm
Hello,
BR
The 24 fet controllers use the IRF4115 mosfet which is a 150 volt part. I've run mine at 36S or 147.6 volts. Variable regen is coming soon. Probably by the time you are ready to buy, it will be ready to be sold. Vadym is a mad genius with what goes into the telemetry modules. I'm waiting for 2 of the latest version right now. They include variable regen. Without the telemetry module you get fixed regen. IE: Set it at some level and it's always at that level. It's just a personal opinion, but the telemetry module is sooo worth it and comes with a great app for your phone. The new module also includes dual temp sensors. One is internal to the controller and the other is external for things like battery or motor temps.
XB-502 Moped:
Currie scooter:
ecross
Post by ecross » Jan 03, 2018 5:37 am
Hello,
BR
Hi,
I`m ready to to buy. Please send more input from the new telemetry modules. Some app for phone are also welcome. Do you use also the 120V version from the 24 Fet controller?
NC 2805 mod.
H4080 mod.
4503 mod. 4504 mod.
ElectricGod
Post by ElectricGod » Jan 03, 2018 9:04 pm
Hello,
BR
Hi,
The 24 fet controller comes in 150 volts max only. I'm not sure what you are asking.
No telemetry modules yet...maybe by the weekend.
XB-502 Moped:
Currie scooter:
ElectricGod
Post by ElectricGod » Jan 04, 2018 2:54 pm
Jan 03, 2018 9:41 pm
Currently, 24F is offered in two versions:
- 150v version
- 120v version with Toshiba mosfets
I am also working on the third version. It'll be more capable in terms of amps and the price will be a bit higher.
Didn't know you did a 120 volt version.
So the new version will be 100 volts and use TI mosfets or possibly AOT290's?
XB-502 Moped:
Currie scooter:
Powervelocity.com
Post by Powervelocity.com » Jan 04, 2018 3:12 pm
It's been in the product description for some time:
http://powervelocity.com/index.php?id_p ... er=product
But I'll make separate descriptions as specs and price will be different now.
- 150v version
ElectricGod
Post by ElectricGod » Jan 04, 2018 4:38 pm
- 150v version
Yup...sure is...just never read it through.
Voltage operating range 24-100v, 36-120v or 70-150v
XB-502 Moped:
Currie scooter:
ElectricGod
Post by ElectricGod » Jan 08, 2018 7:01 pm
I got the new telemetry modules On Saturday. I haven't had a chance to try them out yet.
XB-502 Moped:
Currie scooter:
madin88
Post by madin88 » Jan 09, 2018 1:47 pm
does it already feature two thermistor inputs (for controller and motor) with throttle roll back?
Powervelocity.com
Post by Powervelocity.com » Jan 09, 2018 1:57 pm
Two temperature inputs are there, as well as throttle control. The roll back will be a matter of adding a line of extra code in the software (will be pushed as an update pretty soon).
ecross
Post by ecross » Jan 13, 2018 4:11 am
Hi, very good news! I`m ready to buy. Please send ASAP more infos. My new Motor and new battery are ready!
NC 2805 mod.
H4080 mod.
4503 mod. 4504 mod.
