Sabvoton User's Guide (unofficial) [sabvoton.wire.bike]
Get real world experience and user feedback on the electric bicycle products.
alec
Post by alec » Dec 22, 2017 6:58 pm
Hi everybody,
I've started an unofficial Sabvoton User's Guide at http://sabvoton.wire.bike
I'll be constantly updating it with new information.
Please feel free to critique, contribute content on or leave any other comments here.
:idea: Update log:
Code: Select all
v.0.9 12/22/17 - Initialization
:arrow: If you like or appreciate this content, please donate any amount of money to the Cancer Research Institute.
❝ With great power comes an even greater PG&E bill.
12kW+ Greyborg, Cromotor V3, SSC96150
sabvoton.wire.bike [unofficial user's guide]
wire.bike [personal projects]
ridethelightning
Re: Sabvoton User's Guide (unofficial) [sabvoton.wire.bike]
Post by ridethelightning » Jan 13, 2018 6:24 am
a good start to a neat and tidy guide there.
I have just purchased a 200A version sabvoton svmc72200 (M), and having only used the adaptto system till now, need to get my head around it.(paticularly using the cav3, programming etc)
i got mine through QS recently(september 17)came with usb cable. am i right in thinking that ill need to buy a new usb cable thing for it or have they sorted that by now?
cheers
RTL
alec
Post by alec » Jan 25, 2018 2:50 am
cheers
RTL
Sorry for the very late response! Been busy here as of recent.
And no, you'll probably be fine considering you have an M! They're standard with RS232 during that era... if you're lucky. You never know! I think we both know the best way to find out... hook 'er up! :D
matt912836
Post by matt912836 » Jan 31, 2018 9:15 am
Hey alec, i ran into your guide looking for help with my sabvoton, very helpful so far. I have one of these controllers:
The (M) indicates it's a newer model conpatible with Bluetooth, correct?
Can you provide any input on how to set one of these up for Bluetooth? The guide says you need both the dongle and USB cable to program the dongle correctly but doesn't go into further detail. Any further help on how to do this? This also means you never need to hook up the controller to the computer, just the dongle right? I don't have access to a computer right now so if I can program the dongle easily at a buddies house without having to bring the whole bike that makes it a lot easier.
matt912836
Post by matt912836 » Feb 11, 2018 2:51 pm
I'm trying to wrap my head about using the HC-06 in place of a dongle. Never touched an arduino before so while it may be a simple concept its all new to me (at the same time learning how much Im missing out on, an arduino can add so many functions in an ebike). My goal is to reprogram my sabvoton solely through my android. I don't have access to a computer directly right now, and In the sabvoton guide it states you need a serial to usb cable to program the hc06 via AT commands to work with the sabvoton. Shouldn't I be able to do it with just the HC-06 alone? Wire it to a USB cable, connect it to the sabvoton to power it on, then connect to it via Bluetooth on my android and just reprogram it with the same AT commands through a bluetooth terminal? Or is changing the baud rate/name not possible while using bluetooth to connect to it? Any input? I can pick up an hc-06 locally in NYC so the faster I can get it running the better.
Newbeast
Post by Newbeast » Feb 12, 2018 8:22 am
Amazing work mate! been trying to figure out how to get my sabvoton controller running for 3 months now, your a true hero. just bought a JBtek USB to RS485 on express delivery, but have no clue what cables i have to plug into it lol. waiting eagerly on updates! :D
matt912836
Post by matt912836 » Feb 13, 2018 11:18 am
Got my hands on an Hc 06 and serial usb cable. I sent all the commands to the hc06 from terraterm on windows as the guide says to set the baud rate name etc... everything saved ok. When I connect the hc06 to the sabvoton and run the app, the app says unconnected and does nothing... any help? I assume the app is supposed to automatically connect when you open it? as there seems to be no way to establish connection. The one button in the corner does nothing. swapping the tx and rx pins on the hc06 to the sabvoton does no help... restarting the app many times and nothing. any advice? If I short the pins on the hc06 and talk to it through a bluetooth terminal I get an echo of what I sent, so the bluetooth is receiving and sending data... also when I connect to it through the bluetooth terminal the red light stops flashing meaning something is connected, when I run the sabvoton app the red light stays flashing meaning nothing has tried to connect to it and it's ready to be connected to...
UPDATE: seems like the hc06 is hooked up properly to the controller, I'm able to connect to it and change parameters through the windows app. I guess it's true that the android app just sucks bad... someone needs to develop a good mobile interface for this controller! it has so much more potential
There seems to be another app other than the SVMC app, there's one called MQCON found here.
http://www.mqcon.com/menu/downloads.html
Has a lot more functions similar to the windows app.. still can't get this one to work either though :?
E-Zero
Post by E-Zero » Feb 19, 2018 5:35 am
Although mine is a 96150 I think you might help.
Was working fine, I had to disconnect the motor for maintenance and now error 25 is on. Tried everything, even reset to factory default but nothing. It shows 2v only but the battery is full...
Help will be welcome!
ridethelightning
Post by ridethelightning » Feb 20, 2018 10:05 pm
i have been working on my 72200 and got it working but when a friend fired it up for a test, it seems to have bbqd the fets. i suspect the halls combo was not saved correctly somehow
does anyone have any advice about spares/support for sabvoton?
i have made a thread about it here-
https://endless-sphere.com/forums/viewt ... =2&t=92954
