ambroseliao wrote:Hey Dogman,
I have this kit and run it on a combination of 6P Bosch Fat Packs and 1S 18AH 12V SLA for a total of 48V.
How much does a 12v 18ah SLA cost? Where did you get yours?
ambroseliao wrote:Reading your signature, what's going on with your 9C that keeps breaking down?
Rifle wrote:....The 9C has been fine, but I'm on my 4th throttle for whatever reason,...... The most recent one was fixed by simply replacing the plastic housing for the male spade connectors on the throttle and motor connections. I can't see anything wrong with the old plastic housing, but replacing it fixed it so I dunno. I've made my own back-up throttle and these connection issues are easy enough to trouble shoot and fix...
mwkeefer wrote:Torker,
I could finish my e-bikekit 9fet infineon thread (started long ago, put off because I've been busy testing various combinations, efficiencies, mods, etc) if you guys want more specific detail - but the info is here on ES, just have to search it out.
dogman wrote:Battery is back to normal. It got unbalanced from riding till cutoff, NOT from anything to do with the motor kit.
dogman wrote:The ping is back to normal now, just needed a couple cycles to get balanced as usual.
The throttles I break off the thumb tabs since I ride with it 100% about 99% of the time. The bike trail has several big dips to let water cross, and sometimes I get both wheels off the ground at 25 mph. So I bust off the tab landing the jump. I just glue on a piece of 1" pvc pipe and make em half throttles.
Return to E-Bike Reviews & Testing
Users browsing this forum: No registered users and 3 guests
