Not a lot of riding going on lately, in the winter I do a lot more work that requires a truck, and even here, it's 25F at dawn so an hour ride is not ideal.
So it's a good season to rebuild bikes. I just moved the EbikeKit motor to a new bike. Actually an old bike, but new to me. Here it is,
- Dogmans commuter V2.0.jpg (102.03 KiB) Viewed 489 times
All the seat, rack, etc was just transfered to the newer bike. This bike has much better suspension including, Alloy suspension forks. Something I never thought I'd do, but after some fiddling around with a couple forks I found one that the motor fits well, and installed it along with dual tourqe arms and c washers from Ebikes-ca. Kid's, don't try this at home. The fit had to be absolutely perfect for me to try this. A complete description will appear in a review of the C washers in another thread.
I have a 48v pingbattery on order, so by early spring I should have some opinions on how the Ebikekit runs on 48v. The motor continues to work flawlessly.
On this install, I tidied up things a bit more. For instance the wiring harness comes like this.
- Wiring before.jpg (80.55 KiB) Viewed 488 times
Actually, you want it that way, so when you install it you can troubleshoot any connector issues that though rare, do happen. After testing, then you can do your own idea of how to seal up things. I live in a dry climate, so I just like to tape em up like this.
- wiring after.jpg (82.86 KiB) Viewed 487 times
Back to the subject of throttles, I have put the full throttle on the bike for a test. I sorta hate it already but will give it a fair try., It would be fine if I always rode full throttle. I find it just a bit harder to keep a steady partial throttle speed on a long run with the full throttle.
I tried to use the thumb throtte, but it did not fit well with my shimano trigger shifters on the new bike. One issue with all thumb throttles is that the spot where the throttle tab is comfy may cause the part where the wire exits to interfere with brakes or shift levers. If you install a thumb throttle in the wrong position on the handlebars, then you get hand fatigue.
