Finally got error codes from BMC (red LED on controller PCB):
1. Continuously ON: Everything is normal
2. To glitter twice: Braking issue
3. To glitter three times: open circuit or wrong component value between Sense Resistor and LM358
4. To glitter four times: issue of mosfets at low circuit
5. To glitter five times: issue of mosfets at high circuit
6. To glitter six times: issues of 60/120 degrees or motor HS sequence
7. To glitter seven times: over current, too long Sense Resistor Wire, too low setting voltage for short circuit protection
8. To glitter eight times: low supply voltage
9. To glitter two times more quickly: Throttle is not released or over voltage of output of throttle
10. To glitter three times more quickly: lock rotor protection on ( motor is locked )
11.To glitter four times more quickly: disconnection of phase wires
12. To glitter five times more quickly: over temperature protection on
When issues occur, LED will glitter for some times as indicated above and glitter again at regular intervals.
