dbaker wrote:Knuckles,
Is that a 9C in the video? How did it like 4.5 kW? What was speed at WOT?
Dave
etard wrote:Nice, I will be looking for one of these 6 FET's you speak of. Is Keywin the seller of these, or are you selling them??
Thanks fr all the detailing pics, nice to be able to look at the inside of something before purchase.
Knuckles wrote:
6-fets = 25 amps
12-fet = 50 amps
ball park prices (less $$ if you are INSANE!)
deVries wrote:Knuckles wrote:6-fets = 25 amps
12-fet = 50 amps
Can the shunts be modded on these two with more solder/wire to carry more amps AND not fry something on the controller?
What can these handle for so called burst amps before doing any shunt mod? How many seconds are "burst amps" anyway?
Thanks!
Knuckles wrote:Well I finally got it all together. I re-flashed the MCU and set the amps to 50A.
When the LEFT e-Brake alone is slightly pulled (BK to GND is shorted) the throttle will allow variable regen.
When the RIGHT e-Brake alone is slightly pulled (EBS to GND is shorted) the controller shuts off.
When BOTH e-Brakes are applied the controller applies max regen to a stop.
-Knuckles
liveforphysics wrote:Knuckles- For a given motor do you know what the current through the FETs has in common for the following examples?
50v 75amps
100v 37.5amps
150v 25amps
It's all exactly the same current loading through the FETs.
The difference is simply that the 150v rated FETs will be making about 3-4x the heat.
Be careful rating controllers by battery current values, as you know two controllers both pulling 25amps at 150v, one driving a 5302 and one driving a 5306, the controller driving the 5302 would have 3x the FET loading.
Likewise, if the motor's being powered aren't needing the additional RPM potential (like in the event of direct drive hubmotors where aero drag meets power limits), then running at a higher voltage only makes for plenty of additional liability and more controller heating with no advantages.
Knuckles wrote:
Good? Bad? Ugly?
Return to E-Bike Reviews & Testing
Users browsing this forum: No registered users and 3 guests
