Ebay Kit DIY 36V rear drive 15a/hr LifePo4
Get real world experience and user feedback on the electric bicycle products.
Postby JoyRiddin » Mon Apr 04, 2011 11:24 am
I was in search of my first ebike conversion kit. After much searching for a complete electric bike conversion kit, I decided to take a chance on eBay DIY since the offers there were more than $300 cheaper for comparable kits from any dealer. The bike that I converted is a Jamis Explorer 2. It has front suspension and the riding position is more upright than your typical mountain bike. After much internal debate I settled with the following combination, a “36V 15AH LIFEPO4 Lithium Battery electric bicycle bike” from daoji666 and a “36V 500W ELECTRIC BICYCLE ENGINE REAR CONVERSION KIT” from yescomusa. This conversion kit advertises approximately 18mph or 30kph. With the battery choice I made I am hoping to get approximately 20 miles on a full charge. Although I would like to go a little faster, from what I have gleaned on the forums and from testimonials, as speed increases the range decreases on a disproportional decline. I also read that the life span of the battery pack increases when you do not completely discharge the pack. Since I work approximately 6.5 miles from my house and wanted to make a complete trip with out having to charge at work and I am 6’3 and 250lbs, I also figured that these were not the variables used in the manufacturer’s equations for determining range or speed. They probably use more liberal figures that help their final numbers.
First about the kit, it is a complete setup. It includes, grips, rack, battery bag, thumb throttle, brake levers with cut off switch, complete rear wheel and controller. The rear wheel is double walled aluminum with heavy duty spokes and comes with the tire mounted. The grips are shorter than the originals and look fairly cheap but they still function well. As I already had a Topeak QuickTrack mtx luggage rack, I had no intention of using their rack or bag which are not of the highest grade and heavy but adequate. This might translate to sturdy but I won’t be testing to find out. The brake levers are fine except for the fact that my brake levers and shifters are one piece and can’t be replaced. Integrating the cut off switch into my existing levers is also not possible. I could rig a magnetic switch on the frame next to the brake cable but I decided to leave the cut off switch out of the equation as the thumb throttle is easy to release before applying the brake. I am an avid motorcyclist and have many years, over 25 but don’t tell anyone, with powered cycles. Without dissecting the controller I can’t speak to its build quality except for it appears to be constructed out of aluminum and the screw on end caps were bent a little. The wires exiting the case had been encased silicone to prevent moisture from entering, a nice touch, but there in no apparent grommet for fray resistance. I hope this does not become a problem. I did have an issue later, so see the testing section for details.
It was the proverbial kid at Christmas scenario while waiting for the components to arrive. The kit from yescomusa came in about a week as advertised while the battery took the slow boat from China and arrived in approximately 3 weeks also as advertised. Installing the wheel and electronics was not particularly difficult. The hardest portion was deciding where to mount the controller. I knew that it needs air for cooling as in Maryland where I ride it gets around mid 90’s to 100 in the summer. I settled on the frame beneath the seat post facing forward, for the controller, just below the top frame. Since I received the kit first, I decided to put it together ahead of the battery. It took me approximately three hours from unboxing the components. Some of that was head scratching trying to understand which of the components I was going to use. The first problem was that the electric hub was a five gear cassette and my rear derailleur was set up for a 7 gear cassette. The second problem was the thumb throttle travel interfered with my shifter. A bit of creative positioning and some wire ties fixed it. The axle was a very tight fit, but it went on without too much of a problem. The after securing the rigging and checking for smooth operation of the brakes and derailleur off we go for a quick non powered ride. I was surprised that I did not notice any significant drag without being under power until I hit approximately 18 mph at which point it became much more apparent but still an acceptable ride.
The battery is quite a brick and fits my luggage rack well. Both the battery and BMS came encased in duct tape, you have to be impressed with that, and has an attached battery management system. There is no specification sheet that comes with the battery or BMS so it’s specifications have to guessed at. The supplied charger states that it is a Lead acid charger which gave me cause for concern, however, after much research it appears that lifepo4 can be charged with the supplied charger. When I tested the charger the output voltage was 46v. I concerned as I have many LiPo packs which are extremely delicate. During the first charge I closely monitored the process and it cut off automatically at 42.5v. I will have to assume this is the battery management system at work. I disconnect the charger and let battery management system do its thing for a while and it balanced the pack to 40.5v. Then rinsed and repeated until maximum charge was achieved. All appeared to be well. The instructions, which are very poorly written, suggest that you do not leave the charger connected for longer than 9 hours. This has to be a good idea. After connecting the battery to the bicycle and going for a very short ride, it chose to rain for the next three days of course, I was quite impressed. The speed was exactly as advertised, some where between 15.5 and 18.5mph with no peddling and 18.5 and 21mph with light peddling. I have a steep hill to climb in my neighborhood, which it powered up with only light peddling from me in top gear and I was still doing 14mph at the top. After the rain finally stopped I went for a real test run. I planned a 15 mile round trip and left with a smile on my face. After stopping at some friends houses to show off a little, I ran into my first problem. The fuse included in the motor kit had jarred loose from bouncing around and the power kept cutting off. The fuse was developing a char from being loose, so I took it out of the loop and replaced with a better fuse holder. On the next leg the power cut off again and I found a cold solder joint on the battery connecting plug as well, time to re-solder. At least the peddling with out power is still just fine.
All in all I could not be happier. I recommend going over all the solder joints prior to first run and replacing the fuse and holder with a higher quality set. With that being said, I have approximately 45 miles on the setup and my commute to work is so nice. I used to have to change my cloths as I would get extremely sweaty. Now the ride is just a pleasure as I cruise past the backed up traffic. The bicycle is just so quite and smooth. I have estimated at the range at 21.66 miles with me peddling lightly most of the time. After 6.5 miles it takes just under 1.5 hours to full charge. This is a 3amp charger and a 15 amp/hr battery, so I estimate at 21.66 miles on the low end. I definitely recommend this for a commuter but not for a speed junkie.
JoyRiddin
Re: Ebay Kit DIY 36V rear drive 15a/hr LifePo4
Postby wesnewell » Tue Apr 05, 2011 3:32 am
Since they were the same price, $227.90 shipped, I got the 48V 500W model. Using 14S lipo pack, I can get up to about 27mph w/o pedaling. Darn good considering I'm ~270lbs. But I replaced the thin 1.75 tire with a 2.15 not long after testing it. Very happy with mine too.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby Kent » Wed Jun 08, 2011 9:11 pm
Nice write-up. I was wondering now that several months have gone by, how has your kit held up? Any issues?
I bought a similar e-bay kit around the same time-36 v, 500 watt front. I wish I knew then what i know now thanks to this forum. Should have bought the 48 volt version for the same price and should have mounted the controller on the exterior instead of in the battery bag where it overheated and fried. Also the cheap Chinese rim has taken a beating with our Vermont potholes. Wires are under sized and the plastic connectors not weather proof. But love the smooth, quiet motor. Already thinking 72 volts of course.
72 V, (2x36v, 11.5 ah) Cellman, 40 amp, Jamis Hardtail w/ turnsignals, brake lights, headlight
Only by setting an example of good road manners and public courtesy can we convince the general public to take the electric bike seriously as a transportation option. Stay off the sidewalks. Stay in your lane. Obey traffic laws!
Kent
Postby wesnewell » Thu Jun 09, 2011 3:19 am
I've had mine since Feb. and put over 1K miles on it now without any problems.
wesnewell
Postby kentlim26 » Mon Jun 13, 2011 7:10 pm
My ebay Kit, from conhis , now i run 4100km+ over .. i hope to do 10,000km ( my goal), my is 1000watts kit, 48v. max 1599watts, full throttle if necessary, or slow down if i spot something. The performance is Very good, like the top speed it has maintain like 50km/h +, troque, other things remain the same. it is very difficult to UP more speed i don't want to notice any other vehicle user. when i bought from them, it cost usd250.00 with express shipping. 3days arrival at door, the only problem i encounter is the troque arm problems... it is very hard to get it right, making the wheel to stay the same position after every trip. now problem solved.
fun ebike, i like it very much.
cheers
kentlim
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Return to E-Bike Reviews & Testing
Users browsing this forum: No registered users and 5 guests
