Review: 90 Degree Valve Step Extension
Postby Kingfish » Wed May 11, 2011 8:22 pm
Review.
  • Bought from Amazon on 5/2/2011; query
  • Manufacturer: Pacific Dualies
  • Color: Chrome.
  • Size: Standard automotive; Schrader.
  • Cost: $13.14 USD per pair, with free Super-Saver shipping (combined with other orders)
  • Shipping: Received quick enough (meaning I didn’t note it; probably on 5/9/2011).
  • Related ES Thread: None; I don’t recall discussing the issue before, although it is related remotely to the Epic Battery Bag Story since this is the assembly that created the need.
Begin:
After I built my epic battery bag there developed a new and tiresome issue with trying to pump up the rear shock which over time requires periodic recharge. Due to the angle of attack with the air fixture relative to the shock and with the placement of the rear of the battery bag, it made from a frustrating experience when trying to mount the shock pump.
I researched the option to use a 90° elbow; possibly someone has written about it already though I don’t precisely recall. Anyway, I finally got around to fetching this unit. It comes as a pair, appears to be well-made, and has a nice chromed cap.
Installation was fairly easy: Unscrew the existing cap off of the shock, and then screw the matching end onto to the nipple. All the air in the shock exhausted in the process, and when the mating was completed the joint appears wobbly. I quickly noted that the unit did fix well within the close confines and was pleased that it did not rub against the battery bag in a manner of extreme deflection. Additionally I could easily reposition & rotate the stem out of the way for normal stowage.
Re-inflation with the little shock pump took some time; perhaps I might have been better off with a normal tire pump. Regardless, I was able to recharge the piston to the desired pressure and all appears good and well. The mounting went without much ado and was very convenient. The chrome cap was affixed to the end, and there appears to be no leakage.
Conclusions:
Time will tell if this device keeps its’ seal. I’ll post usage feedback when it is available.
9 Stars out of 10.
~KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9634 miles-to-date, 4144 as 2WD.
Kingfish
1 GW
1 GW
Re: Review: 90 Degree Valve Step Extension
Postby docnjoj » Thu May 12, 2011 9:20 am
I use a similar device except with a 45 deg extension on our 20" ebikekit wheels as the distance to the filler is too little for a pump to attach. Works fine for me and my wife for front or rear power wheel!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby Kingfish » Sat May 21, 2011 2:06 pm
Update
This device does leak: They’re fine in a static environment, but I found that on a good jaunt that they slowly leak if bumped. It was good for about 25 miles and didn’t notice a thing, but after a while the bike became pretty spongy. Given that my present commute is lengthy I decided to remove it.
Therefore I would downgrade the score to 7 Stars out of 10 with a caveat:
    The device should work well so long as there is no physical contact with other objects during use.
Slightly deflated, KF :roll:
Kingfish
1 GW
1 GW
Postby docnjoj » Sat May 21, 2011 3:41 pm
They can easily be attached to the pump so they don't have to stay on the wheel. Our don't seem to leek and the stem can be rotated out of the way towards the centerline of the wheel.
otherdoc (highly inflated :wink: )
docnjoj
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: No registered users and 4 guests
