FalconEV 19" triangle bag.
Re: FalconEV 19" triangle bag.
Postby JoramsWeapon » Sat Mar 31, 2012 1:22 pm
nonlineartom wrote:he would do well to start selling a new version of the falcon EV bag which is split into two halves, hung over the top bar like a pannier sort of bag, but maintaining the same internal volume as the falcon EV split in 2 parts with a semi-rigid inwardly facing panels. Each side having 50mm space width wise to accomodate pretty much any LiPo pack.
He could sell that shit for $70 and people would buy it....
....anyone know some good manufactures?!
Indeed he could. If Hi-Power Cycles would restock their large bags I'd be buying them for certain, between them and FalconEV they are the only ones to produce a quality canvas bag with the dimensions we need. I was emailing one of the owners of Hi-Power Cycles and they will not be stocking the big bags for some time...
If they charge $100 for a bag of your description it would sell, but lets not give them any ideas :roll:
JoramsWeapon
Postby neptronix » Sat Mar 31, 2012 1:44 pm
buy direct from HPC's supplier and avoid the markup over retail that they add.
https://www.revelatedesigns.com/index.cfm?fuseaction=store.catalog&CategoryID=1&ProductID=5
They're in stock too.
But if you do have a full triangle, do yourself a favor and get the falconEV bag. It is the biggest and sturdiest thing out there.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby ohzee » Sat Mar 31, 2012 1:58 pm
I am still loving mine been packing it full of 12 6s 5000mah batteries with no problems once I loosened
stress on the top bar. once i changed my packing lower as nepro suggested it's working out great.
ohzee
Postby shorza » Wed Apr 18, 2012 11:30 pm
I don't suppose these bags could stretch to fit 3 4s hardcases side by side?
5 inches?
shorza
Postby neptronix » Thu Apr 19, 2012 12:07 am
You very well might be able to if you remove the casing.
You can fit 12S side by side, as it is.
I'm ordering a 3rd bag soon.
I seriously base my eBike builds on this bag from now on.
neptronix
Postby sflorlando » Fri May 04, 2012 1:20 pm
Heres a little doodad that I put together.
It consists of some mounting brackets, 1 inch aluminum tubing and also some aluminum u channel.
It simply sits on the top frame
and heres it on the bike
not 100% done yet, need to figure out a way to keep the bottom supported.
Ken
sflorlando
Postby ohzee » Fri May 04, 2012 1:22 pm
Wow nice. How does that work with your legs ? So you have 2 bags right one on each side ?
ohzee
Postby sflorlando » Fri May 04, 2012 1:30 pm
I need to move it up just a few inches. One bag per side.
sflorlando
Postby teklektik » Fri May 04, 2012 3:27 pm
sflorlando wrote:It consists of some mounting brackets, 1 inch aluminum tubing and also some aluminum u channel.
Very clever. :)
Where did you obtain the plastic mounting brackets for the round tube?
teklektik
Postby neptronix » Fri May 04, 2012 6:38 pm
One thing to know is that most of the battery weight should rest on the bottom, or the top straps end up tearing off.
Holding 10-20lb of battery in a vibration prone environment is tough.
I'm interested in seeing how this pans out.
neptronix
Postby nonlineartom » Sun May 06, 2012 10:25 am
neptronix wrote:One thing to know is that most of the battery weight should rest on the bottom, or the top straps end up tearing off.
Listen to this guy ^^ from my experience I have torn the seem where the canvas meets the zip by having the some load carried by the top straps. Not good. Mine is now a patchwork of repairs and reinforcements.
On mine I use a peice of 12mm ply, epoxied it to another peice at 90 degrees to make an L shaped bracket which clamped onto the seat tube with a 34mm exhaust clamp. That acts as a shelf clamped to the seat tube with the front resting on the down tube. All the weight of the battery is taken by the wood. Doesn't look too messy either.
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
nonlineartom
Postby nonlineartom » Sun May 06, 2012 10:27 am
inside the bag I've got a plastic licence plate and used a heat gun to bend it a bit to match the curve of the bag to make a rigid floor and front that the controller screws onto. Stops everything bouncing around inside and gives a rigid surface to mount to as a removable insert
nonlineartom
Postby nechaus » Tue Jul 03, 2012 7:55 pm
I Finally got this bag.
IV managed to cram x8, 5s, 8 ah in it.
I can add a booster pack to the outside of the bag inside the stretchy stuff
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby ohzee » Tue Jul 03, 2012 8:03 pm
Yea I still use mine almost daily and love it.. still no problems on my end just been extra careful to not support from top straps.
Glad you finally got it.
ohzee
Postby Sacman » Tue Jul 03, 2012 8:11 pm
So the LiPo bricks are okay and not banging on the bottom bar?
These look great, I'm really gonna have to get one and give it a try.
Sacman
Postby ohzee » Tue Jul 03, 2012 8:18 pm
The bag itself is pretty stiff in the bottom and other then taping my 8 6s 5000mah cells together It's been a non issue for me.
ohzee
Postby neptronix » Tue Jul 03, 2012 9:33 pm
Never a problem! That padding on the bottom is very tough stuff.
There's plenty of room in the bag for you to add a lil' extra padding if you feel like it though.
neptronix
Postby Sacman » Tue Jul 03, 2012 10:35 pm
Cool... thanks. So do you have your LiPo bricks just sitting in the bag bare or do you armor them up with anything?
I'm thinking of getting the bag for my off-road ebike so I'm thinking I'd better armor the batts up.
Sacman
Postby neptronix » Tue Jul 03, 2012 10:51 pm
There are some pics early in this thread..
But initially i had added some extra foam padding, now i just run them bare.
But to be honest, my bike has kind of a tapered flat bottom tube where the batteries sit on. That helps.
neptronix
Postby Kinni420 » Wed Jul 04, 2012 9:16 pm
off-road = beating up a battery that costs 50 bux minimum. throw some padding in there, you don't want them moving much and a big crash could ignite your expensive kit/bike on fire. regardless if it comes with padding or not you should be protecting your investment with a cheap fix.
I used foam, anti-slip futon mattress stuff, duct tape, electrical tape, and hobby cut-board fully wrapped around each battery. Added foam and cut-board to my pack too. About 6 dollars total investment. Now i don't worry about anything but breaking that wire coming out of the rear axle.
"It has a lithium cracking station. We may be able to adapt some of its power packs to our engines." Spock, season one, episode four. 1966....How right he was.
1996 Marin Palisades Trail, 9C 2810R DD 40A controller Magura full twist throttle 18s2p 29 mph @ 23 wh/mi
1970 Cook Bros single speed beach cruiser prototype serial # 1 (for sale $100,000 frame only)
Kinni420
Postby Trackman417 » Thu Jul 26, 2012 7:56 pm
I personally think that 12 4S hardcases packs in this bag will be absolutely beast! :mrgreen: Guys, just get ready for the ultimate solution. Who needs padding with hardcases lip packs? Duct tape and this frame bag is all I need to get my bike up and running. Get ready to be amazed.
Just a quick question on what andy's PayPal address is? Please and thankYou! :mrgreen:
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
Trackman417
Postby Lemlux » Tue Aug 07, 2012 1:26 pm
I took a new Falcon EV bag to a marine upholsterer yesterday to have the edge band that is parallel to the ground expanded to 5 1/4" all around. All of the expansion will be on the left hand side and will not interfere with the zipper, the pouches, or the velcro straps. I'm expanding on the left side only because my 153mm wide bb has 30mm+ of its 40mm extra width on the left side. The combination does not appear to interfere with my pedalling strokes.
I chose the 5 1/4" edge band width because 3-cell wide 40152s 5Ah Headway packs are 5.04" wide. If I'm lucky, I'll be able to fit a 16S grouping inside. If not, I may have to place as many as 4 cells as near the triangle as possible. I plan to reinforce the bag with a 1/8' thick (1/4" overall thickness as extruded) 5" wide aluminum fashioned mainly from 3 sections of this 36" long door threshhold purchased from Home Depot:
http://www.homedepot.com/h_d1/N-5yc1v/R ... reId=10051
1 section of the 5" wide aluminum will run most of the 11" length of the seat tube edge and 2 sections will be fitted to both surfaces of the bottom edge (downtube and across to the seat tube). I'll connect these 3 sections with a pair of 4" long door hinges that cost only $1.00 @ at Harbor Freight.
These 3 articulated, hinged aluminum reinforcement sections will be slid into the bag and will be easily removable.
Lemlux
Postby Lemlux » Tue Aug 07, 2012 1:43 pm
Let me add in 1 minor rant. I haven't even used the bag yet and the Falcon EV rubberized logo has already smeared over the surface of the bag where it was folded for shipping/storage.
Lemlux
Postby Sacman » Tue Aug 07, 2012 7:55 pm
Lemlux wrote:Let me add in 1 minor rant. I haven't even used the bag yet and the Falcon EV rubberized logo has already smeared over the surfacde of the bag where it was folded for shipping/storage.
Why advertise the Falcon brand logo anyways?
Rub it all out with some black shoe polish. :wink:
Sacman
Postby neptronix » Tue Aug 07, 2012 8:14 pm
Sacman wrote:Why advertise the Falcon brand logo anyways?
bwa ha ha, does that actually work? i don't like having the logo there either.
neptronix
PreviousNext
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: NeilP and 5 guests
