yescomusa.com (GM) 48V 1000W rear motor kit
Re: yescomusa.com (GM) 48V 1000W rear motor kit
Postby kmxtornado » Mon Oct 10, 2011 3:22 pm
Okay, moving back to the specific kit purchased by the OP, I have a newbie question.
What's the difference btw the watts? Higher means faster....which means uses the battery more quickly? Or does it mean the range is better? Or does it mean the torque is better? Sorry, I'm researching as much as I can but I gotta start somewhere.
I'm totally new and considering an ebay kit too since there's such a craze about it and I'm not all that hardcore about e-biking...yet at least. If you could recommend something to me, that'd be awesome. I started a thread with all my specs (e.g. my weight, expected range, etc....): http://endless-sphere.com/forums/viewtopic.php?f=3&t=32668&p=474570#p474570 Please comment there if you have a chance or answer my quick question here since it's somewhat related to the Yescomusa kit.
I'm on their website now...and it's pretty cool that the kit really does come fully loaded. It even comes with a headlight and bungies to hold the battery pack. But it looks like the battery has to be purchased separately as the OP already mentioned.
- My very first e-bike conversion ever: http://endless-sphere.com/forums/viewtopic.php?f=3&t=32668&p=474570#p474570
- Build Blog (more detailed than the above thread): http://e-bikeconversion.blogspot.com/ (20mph)
- Ultra mini folding bike upgrade (in-progress): http://endless-sphere.com/forums/viewtopic.php?f=3&t=33471 (12mph > 18mph)
- Recumbent Tadpole Trike completed Aids Life Cycle ride from SF to LA: http://kmxtornado.blogspot.com (27mph flats)
- Catrike Speed (in process)
kmxtornado
Postby smorse1 » Sun Oct 16, 2011 2:13 pm
I chose the 1000 watt based on this thread.
I have 23 pounds of SLA 9ah and it has really exceeded my expectations.
I can go 25 mph on level paved road.
Its on a crappy walmart mongoose, so i have a wish list, of course.
I'll run the SLA until they die, but i am certainly in the market for new batteries.
So:
New batteries/charger
Upgraded controller
New bike with disc brakes
Cycle analyst
48v 1000w YesComUSA rear hub.
Started with walmart Mongoose rescued from dumpster, looking to move to a better fitting Trek 820 recently purchased at a police auction for $11.50
smorse1
Postby smorse1 » Sat Nov 05, 2011 5:13 pm
I gotta say - the customer support from Yescom is pretty good - the charger burnt up on me after about 3 uses and they sent another out, no questions asked and with super fast shipping.
smorse1
Postby seascan » Sun Jan 20, 2013 12:49 pm
Hi. I have a yescomusa 48V rear motor kit.
Is it normal for the battery level LEDs to remain lit no matter the position of the red button? If so, is there a way to install an on/off switch so the connections is completely disconnected?
Thanks!
seascan
Postby wesnewell » Sun Jan 20, 2013 1:07 pm
Yes, it's normal. Two different functions. If you don't like the lights, you can simply unplug the 2 wire connector to the controller or put a switch on one of the wires.. It serves no other purpose.
You should be unplugging your battery from the controller when not in use.
Last edited by wesnewell on Sun Jan 20, 2013 1:08 pm, edited 1 time in total. View post history.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby seascan » Sun Jan 20, 2013 1:18 pm
Thanks wesnewell. I will install a switch.
seascan
By the way, what does the red switch do?
seascan
Postby wesnewell » Sun Jan 20, 2013 5:53 pm
In disables the motor/controller. Out is normal operation. A kill switch if you want to call it that.
wesnewell
Postby veloman » Sat Feb 09, 2013 4:50 pm
I picked up the 48v 500w kit. It did 32mph on 63v loaded last night. I am using an EB309 infineon at the moment (4110 fets). It is slightly louder than a 9c, but it's not a bad noise, not like a geared motor.
I like the speed of the winding, sort of middle of the road. Decent torque and decent top end.
Other than missing a rim strip, I am quite impressed at this kit for the price. The rear rack is a hefty steel folding type. Easily 3-4lbs. The motor phase wires at 18awg are small! Maybe I'll upgrade them in the future if I run more than 30amps on this.
Last edited by veloman on Sat Feb 09, 2013 4:52 pm, edited 1 time in total. View post history.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby wesnewell » Sun Feb 10, 2013 11:36 am
That's a lot faster than I got my 500W kit to on 14s. It topped out at ~ 25mph iirc carrying my 275 lbs on a mountain bike. Acceleration was a lot better when I upped the amps to ~45A max.
Last edited by wesnewell on Sun Feb 10, 2013 11:37 am, edited 1 time in total. View post history.
wesnewell
Postby RLD70 » Mon Feb 11, 2013 7:09 pm
Ill post this here along with two other places as to finding out what to do about this:
Well the motor is here and I dont think the bike frame is well suited for this motor. The axle barely fits into the rear dropouts and trying to stretch the back frame isnt really all that easy either, lol. After a few trials with the batteries I believe I finally got the pos/neg the correct way. Now there is a problem, the wheel will turn when cranking and all but when I try to use the throttle the wheel wont move and when it does move just a tiny bit, it appears to be trying to go in reverse. Any suggestions?
RLD70
Postby chisixer6 » Mon Feb 11, 2013 8:06 pm
You might be trying to put on a road bike frame 130mm width as oppose to mtb 135mm. With the motor just inching along or reverse, sounds like you might need to play with the 5 halls wire(really 3 since you dont need to mess with red and black wire, just the yellow, blue geen), you might need to switch the 3 thicker phase wire around too. there is an excel spreadsheet around here somewhere, that will make it easier.
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Postby RLD70 » Tue Feb 12, 2013 12:38 am
chisixer6 wrote:You might be trying to put on a road bike frame 130mm width as oppose to mtb 135mm. With the motor just inching along or reverse, sounds like you might need to play with the 5 halls wire(really 3 since you dont need to mess with red and black wire, just the yellow, blue geen), you might need to switch the 3 thicker phase wire around too. there is an excel spreadsheet around here somewhere, that will make it easier.
Actually its not necessary, I found the problem and corrected it. There were 2 wires that werent in their respective connectors but they are now and the bike has a top speed of 29.5 so far, lol. Thanks for your help though.
RLD70
Postby RLD70 » Sat Mar 16, 2013 10:36 am
wesnewell wrote:In disables the motor/controller. Out is normal operation. A kill switch if you want to call it that.
I actually believe that it is for the PAS system that the controller seems to be wired for. The sensor is even listed in the manual.
RLD70
Previous
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: No registered users and 4 guests
