teklektik wrote:Will this allow setting Max Power in Watts instead of just Max Current in Amps?
Voltage sag and normal discharge can make a current-only spec a bit sub-optimal in 2.23. Having the CA do the math on the fly could keep performance up while resources are being depleted.
justin_le wrote:
Like this: ?
(don't you tell me it needs one more digit)
justin_le wrote:(don't you tell me it needs one more digit)
justin_le wrote: ...Like this? ...limiting the watts certainly makes the most sense.
Doctorbass wrote:Did you ever thought about including a programmable BEEP piezo alarm option we could setup for ex low SOC alarm etc?
Doctorbass wrote:justin_le wrote:(don't you tell me it needs one more digit)
I can count 7 more free digit on the 2nd line.. leaving enough space for displaying 90 000 000 000Watts (90 Gigawatt)![]()
Doc
Doctorbass wrote:The second one.. ( reserved for a Top secret project!)![]()
justin_le wrote:Doctorbass wrote:Did you ever thought about including a programmable BEEP piezo alarm option we could setup for ex low SOC alarm etc?
I think we need to be careful making sound noises ... it's unlikely that the idea of a piezo buzzer would make it into the design!
Doc
teklektik wrote:There are so many well-considered improvements - it's the re-evaluation and evolution of past designs into a tidy cohesive product instead of a patchwork of odd features that really makes this effort impressive.
justin_le wrote:And finally to give more of a soft start feeling to the ebike, and especially to reduce gear and clutch failures in geared drives, there is a throttle output rate limit that regardless of all other settings puts a firm clamp on how rapidly the throttle output of the CA can change...
Some people like the instant kick of an instant throttle, while others find it disconcerting and prefer the power to ease in smoothly, and so with the rate limit this can be set to the user's preference.
teklektik wrote:(Just thinking here...) It might be nice if the rate could be made to apply only (1) in throttle-up direction and (2) when the minimum throttle setting in the last second was less than 5% according to other configured throttle voltage criteria. This would make the throttle ease on only from dead start or when attempting to re-engage the clutch from a coasting episode (I think...)
justin_le wrote:I think we need to be careful making sound noises. Certainly my tendency is to want to smash electronic devices that beep at me, so it's unlikely that the idea of a piezo buzzer would make it into the design!
tfahrner wrote:justin_le wrote:I think we need to be careful making sound noises. Certainly my tendency is to want to smash electronic devices that beep at me, so it's unlikely that the idea of a piezo buzzer would make it into the design!
I hear you there, but you know what kills a lot of systems in these here parts? Leaving the system powered on when unattended. Arguably unsafe, and quiescent draw sucks the batteries dry. I'd favor a 10-minutes-no-activity "nagger" alarm.
justin_le wrote: ... Ramp down is still instant. If it's not this way then yes it's disconcerting when you brake, or stop pedalling in PAS mode, and it takes a while before the assist dies off.
justin_le wrote:
As for 2, I'm exploring a different idea that would maybe address this pretty well. ... it could rapidly move the throttle up to a value ... It's fairly high on the to-do agenda to try this out.
Return to E-Bike Reviews & Testing
Users browsing this forum: No registered users and 5 guests
