KMX Cobra
Re: KMX Cobra
Postby Ypedal » Wed May 09, 2012 8:00 am
heh heh.. was telling the neighbor last night we need to get video making.. not very impressive at only 48v, but at least we can make a before and after comparison ! 8)
Weather is going to suck pretty hard for next few days but hopefully on the weekend we get some clear skies.. got a reply from Lyen last night, controller will ship soon.
Must also order some lipo.. that's a today plan.
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Re: KMX Cobra
Postby bdc43 » Wed May 09, 2012 8:46 am
Would have loved to join you and your neighbour on your test ride but I was stuck recharging my pack from a ride the night before (got home late so didn't have time to charge before heading to bed). Hopefully I can join you guys on the weekend (if the weather holds). :D
bdc43
Re: KMX Cobra
Postby Ypedal » Wed May 09, 2012 9:22 am
alrighty...
I just ordered 6 of these to get started with, first time ordering nano's. :
http://www.hobbyking.com/hobbyking/stor ... duct=20548
:D
Ypedal
Re: KMX Cobra
Postby Tommy L » Wed May 09, 2012 4:27 pm
Ypedal wrote:alrighty...
:D
:) :) :) \\m//
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
viewtopic.php?f=4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy L
Re: KMX Cobra
Postby Ypedal » Thu May 24, 2012 9:20 am
UPS guy arrived this morning !!!!
:D
Ypedal
Re: KMX Cobra
Postby Ypedal » Thu May 24, 2012 9:22 am
All 6 cells , in all 6 packs are showing 3.810v to 3.820v on arrival !!!... 8)
Topping them all off as i type this..
Ypedal
Re: KMX Cobra
Postby Ypedal » Thu May 24, 2012 12:25 pm
4 packs ballance charged, at 1C ( 4.5 amps ), and discharge at 100v from a portion of my lightbulbs at 5.25 amps, while the last 2 packs ballance charge.
I also received my Lyen 18 fet controller.. more on that shortly ! 8)
Ypedal
Re: KMX Cobra
Postby Ypedal » Thu May 24, 2012 1:14 pm
An honest 4ah ! ( From 4.5ah cells ) from cycle 1.
I dont like to deep discharge packs, but it's the only way to know what's in there and prevent an overdischarge on the road.. weakest cell dropped to 3.455v at the 4.0 mark all others at 3.5xx wich is just awsome. 8)
Ypedal
Re: KMX Cobra
Postby Ypedal » Thu May 24, 2012 1:16 pm
pack remained cool ( room temp is 23c , comfortable vacation weather !! ) .. up to the 3ah mark, and slowly got warm to 4ah when i pulled the plug.. outside pack temps 36c
Ypedal
Re: KMX Cobra
Postby Doctorbass » Thu May 24, 2012 2:56 pm
Ypedal wrote:pack remained cool ( room temp is 23c , comfortable vacation weather !! ) .. up to the 3ah mark, and slowly got warm to 4ah when i pulled the plug.. outside pack temps 36c
Great!!
I guess you feel really happy now 8) :wink:
Just to let you know, the lithium cells dont like to be discharged too low because of the heat that they produce when at the end of discharge when their RI is increasing. But the nanotech are very low RI compare to other lipo cells so no worrie about low discharge to 3.00V. You will not reduce their cycle life by discharging them to 3.00V... it will only happen if you leave them too much time at low or high state of charge.. ex 3.00V or 4.20V
:wink:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Re: KMX Cobra
Postby Tommy L » Thu May 24, 2012 3:45 pm
Ypedal wrote:I also received my Lyen 18 fet controller.. more on that shortly ! 8)
:) I ordered my 18Fet4115 from Edward a few days ago. I can't wait! :)
Which 18fet did you order? and 8) on the Nano's!
Tommy L sends... \\m//
Tommy L
Re: KMX Cobra
Postby Sacman » Fri May 25, 2012 2:14 pm
Ypedal wrote:An honest 4ah ! ( From 4.5ah cells ) from cycle 1.
Your capacity should increase with a few more charge/discharge cycles.
IIRC most people are getting slightly greater than 5ah on the regular 5ah Turnigy cells.
And you're using the NanoTechs (supposedly higher grade cells)
Sacman
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:18 am
I dont run a BMS on any of my packs, so i always stay well above available capacity on any given ride.. in this case.. 4ah is the " quit using throttle and pedal " mark ! :lol:
So finally, yesterday, out with the old !!
Ypedal
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:24 am
I love working with aluminum, light, easy to cut, drill and bend..
Cut a piece and bolted it to the controller..
Then using the existing holes in the frame that were available for the cable mounts ( that broke during assembly ) ..
I try to always add some tape between brackets and frames, keeps things quiet and protects paint..
Ypedal
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:26 am
Going to be a short run between the motor and controller.. 8)
Ypedal
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:30 am
Changed the half-grip twist throttle for a thumb type, with 100v 60+ amps on tap i really dont want accidental power usage... :shock:
So i drilled a hole at the bottom of the steer tube and fed a guide wire ( weed wacker line ) to fish the throttle cable thru from the top of the tube, cleaner look. 8)
Ypedal
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:34 am
And then back to the kitchen workshop area, got the throttle cable extended (was 18" too short to reach the controller.. argh..
sorted out the motor/controller phase hall wire combo colors .. tested the 3 speed switch.. all working !!..
Today i assembled the 6 nano packs for 18S 2P fun, and i just ordered another 7 packs from the china warehouse (the US warehouse was out of stock.. ) it will be 24s 3p (100v 13.5 ah ) when all the packs get here.
Ypedal
Re: KMX Cobra
Postby Tommy L » Mon May 28, 2012 4:17 pm
Hi YPEDAL!
Going orange......
The Great Canadian Kitchen Party!
Tommy L sends..... \\m//
Tommy L
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 4:47 pm
Ok... Just got back from my first ride using the 18fet at 18S ( 72v ) and aprox 60 battery amps showing on the Standalone CA !!!
Hell yeah this is FUN.... I predict tires and brake pad life are going to be short lived.. ( on grass or dry dirt it breaks traction and fishtails real nice.. )
Pictures to come, got the battery pack solidly mounted, no more vric vrac rattles !!!..
Also on the agenda, figure out how to enable and use Regen on these things.
Ypedal
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:12 pm
backtracking a bit..
earlier today, cut some ABS plastic pieces...
Since i only have 6 packs at the moment, i'm running 2 in parallel ( 2P ) and then 3 of these in series for a total of 18S , 2P..
Using clamps, i applied pressure to the packs then with filament tape secured them tightly together in pairs.. then stacked them 3 tall staggered..
Looks sketchy, but for testing purposes , it works.. having learned the hard way i no longer waste time making everything perfect prior to road tests... nothing worse than spending hours shrink wrapping , zip ties, etc... only to find out you got a problem and have to tear it all up ..
Ypedal
Re: KMX Cobra
Postby Ypedal » Mon May 28, 2012 9:19 pm
Rats nest..
So last thing i did before parking it for the night ( after searching the forum for info on using regen.... ) is dig up a gutted e-brake lever switch, hooked it up to the e-brake ( black / yellow ) line, only problem is that this switch is button-pushed disabled vs the other type i need.. so i had to hold it down to use throttle..
one word to describe this... " AWSOME " !!!!....
Get rolling 50+ kph, hit the switch and the trike slows down generating 10 ~ 12 amps, nice smooth, no brake pad wear but yet strong solid braking action down to 10 kph or so.. love it..
Tomorrow, pre-charge resistor, contactor, and mounting of 3 speed switch.. also swap SA ca for a DP unit..
Ypedal
Re: KMX Cobra
Postby Doctorbass » Mon May 28, 2012 10:57 pm
You will love the regen braking Ypedal! :wink:
I adjusted mine to be able to brake just enough to make drifting a little bit wich is more fun for the turn!!
Once you will get the 150-200A phase current YOU WILL be amazed!!
The seat push you like a bomb splash would!!!... It's pure BRUTE force !!
I bought 5-6 rear 20" tires to burn this summer 8)
i'm glad you really appreciate your trike!!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Re: KMX Cobra
Postby Tommy L » Sat Jun 09, 2012 6:45 am
This thread died too fast!
YPEDAL..... Video Video Video..... don't make me go to orange!
I got my 18fet 4115 programmed last night and tried it out no load :)
88.9kph on 115v nom pack. Hoping to hit high 70's kph and looking forward
to having regen! :)
I will post more video soon.
So .... Update?
Tommy L sends.... \\m//
Tommy L
Re: KMX Cobra
Postby Ypedal » Sat Jun 09, 2012 11:47 am
Oh this is far from done !!
I have gotten regen braking to work, and as Doc stated, IT"S FREAKIN AWSOME !!!!
I rigged it up to a brake lever on the left side handle, as delivered by Lyen it's set just about perfect, at high speeds it will create a big enough brake effect to cause the tire to skid just a tiny bit, off-road it's a blast !!
Got the pre-charge resistor with a switch as well as a 200 amp contactor, but since i'm waiting on the 6 additional packs to arrive, the pack voltage will change so everything is jimmy rigged temp for now..
should have taken camera along last night, was out at the ball field, pea gravel trail, hilarious.. neighbor on 2 wheels could not follow me around turns without washing out.. :twisted:
Ypedal
Re: KMX Cobra
Postby oatnet » Tue Jun 12, 2012 3:01 pm
(( Ypedal: ** hack and slashed content to reflect cleaned up thread 8) )
...Anyhow, Y, I am enjoying watching your progress.
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
PreviousNext
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: No registered users and 4 guests
