yet another KMX Cobra build with xlyte 5405
Postby wojtek » Thu Apr 05, 2012 3:21 pm
here we go, some pictures..
https://plus.google.com/u/0/photos?tab= ... 5616262337
got a second hand KMX cobra [as new] and installed battery case, i got it below 10EUR and it perfectly accomodates 2x 6 22v5ah turnigy packs, being compact lightweight and quite strong. However i will have to waterproof it.
i also changed crankset to a high quality 2speed one with 140mm long crank arms. this will be better for my knees and give more clearance between battery case and legs
[i still have some of those cranks if anyone interested]
Next to do is to connect the packs to create 88v 15ah..
WIRES AND CONNECTORS
http://www.endless-sphere.com/forums/vi ... 31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 SOLD
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Re: yet another KMX Cobra build
Postby cbr shadow » Fri Apr 13, 2012 11:35 am
Looking forward to hearing about it!
cbr shadow
Re: yet another KMX Cobra build with xlyte 5405
Postby wojtek » Fri Apr 13, 2012 2:42 pm
thanks!
has anyone already tried 54xx with lyen controller please?
according to Edward as below, but if someone has already made it working, i would highly appreciate the confirmation [never know if Kenny used the same colouring for this batch ;)
Lyen Controller to Crystalyte motor wire color lining:
Controller: Motor:
HALL:
Yellow Yellow
Green Blue
Blue Green
PHASE:
Yellow Blue
Green Green
Blue Yellow
wojtek
Postby Drunkskunk » Sun Apr 15, 2012 11:38 am
[quote="wojtek"]
quote]
Have any of those that will fit a 100mm bottom bracket?
Monster Bike:http://endless-sphere.com/forums/viewtopic.php?f=6&t=38667
Drunkskunk
Postby wojtek » Tue Apr 17, 2012 2:35 pm
100mm is a long one..
no it wont fit im afraid. but fits perfectly KMX trikes ;) and i guess any other pretty standard frames
Drunkskunk wrote:
wojtek wrote:[i still have some of those cranks if anyone interested]
quote]
wojtek
Postby wojtek » Tue Apr 17, 2012 2:39 pm
wojtek
Postby Ypedal » Wed Apr 18, 2012 12:33 pm
should post pictures here.. google+ sucks balls.... and ends up with broken links when the forum goes thru changes.. :wink:
.. i may be interested in them cranks !!!
ES site status page:
Ypedal
Postby Deutch420 » Wed Apr 18, 2012 1:38 pm
wojtek wrote:thanks!
Controller: Motor:
HALL:
Yellow Yellow
Green Blue
Blue Green
PHASE:
Yellow Blue
Green Green
Blue Yellow
That is the color combo that worked on my 5403
GM Rear, Drill mod. 12FET Lyen @ 45A, 24s2p 100v 10ah LiPo. 1999 Mongoose = 49MPH.
Crystalyte 5304 rear 18FET lyen @ 80amps, 24s4p 100v 20ah LiPo. Kona Dawg = 52mph
Crystalyte 5403 rear 18FET Lyen @ 80amps, 24s4p 100v 20ah LiPo. Phasor frame = 58mph 100%, 62mph 120%
Deutch420
Postby Brentis » Wed Apr 18, 2012 1:50 pm
Ypedal wrote:should post pictures here.. google+ sucks balls.... and ends up with broken links when the forum goes thru changes.. :wink:
+1
What, I gotta sign up/in to see. :cry:
*Edit* second link opened for me :wink:
Brentis
Postby wojtek » Wed Apr 18, 2012 4:22 pm
i thought posting pictures were not advisable as many times they were dead after some time :)
yes the cranks look good + 140mm arm lenght gives you more clearace for placing bigger battery box in front...
wojtek
Postby wojtek » Sat Apr 21, 2012 5:40 am
today i changed the front tyres.. put Maxxis Snyper 2.25
i will be also changing the rear tyre to MTB
and also worked on mudguards ...
This is my off road setup with bigger clearance.. the cornering is not great but i will see how it goes. I only did few rounds with it today as the weather sucked.
But i have a feeling that Steintrike Mungo sport cornered better, not only because of 18/20 inch wheels but maybe because of front suspension and i found it easier to put my weight on sides..
maybe pushing the seat forward be good idea but i already have the boom max forward and if i push the seat forward the distance to the pedals will be too short...
Im planning to get also a set of 16/20 inch tyres for road riding.. one day!
momentary switch for regen to be installed here
wojtek
Postby wojtek » Sat Apr 21, 2012 1:49 pm
wojtek
safety flag with LEDs on tadpole trike
Postby wojtek » Sun Apr 22, 2012 8:32 am
today installed the safety flag with led lights from ebikes.ca
+ additional rear light attached to TA..
wojtek
Postby wojtek » Sat Apr 28, 2012 9:59 am
first longer test with my KMX!!!!
mostly flats
with the replacement Crystalyte 24-72v 35a controller, at 44v nominal.
5405 behaves like sleeping beauty, very delicate, slow, gentle, quiet, totally cold after 40min of WOT but getting around 350-400W on WOT on flats in 26inch rim.. No issues whatsoever!
the axle thread luckily was only in the beginning of the end of axle [around 1 cm] and i think it was a human mistake rather than the manufacturing [someone just damaged the thread by forcing the bolt incorrectly]
hope to avoid other issues some of you have.
the cornering is unforgiving and unpredictable... comparing to FS Steini Mungo but i still need TIME to learn it. obviously 20/26inch will never corner but for reasonable riding it is perfect.
time for 16/20 inch setup ;)
this beast is great! if it keeps performing as it is, it will be my favourite ;)
Now time to do some offroad from from i can see, calling KMX trikes mountin tricycles is a joke! :twisted:
wojtek
Postby wojtek » Sun Apr 29, 2012 10:26 am
test run
5405 in 26'' rim and 2.5 hookwarm tires
turnigy 30c 50v30ah
crystalyte 24-72v 35a
max speed 33 kmh at around 300-370W / +100W against the wind
i think it is pretty efficient
motor at start: 22C / after finish [1h ride on flats] 28C
wojtek
Postby wojtek » Sat May 05, 2012 3:53 pm
another test run:
75,4v [66v nominal 66v30ah cells]
48-48.5kmh max at 1100-1200W on flat [depending on wind]
same xlyte 24-72v 35a controller
wojtek
Postby wojtek » Thu May 10, 2012 1:07 pm
update:
1. change the placing of CA
2. shimano saint disc brakes [incredible stopping power!]
3. chain derailleur [clean]
4. pre-charge resistor with 125A switch
5. side battery box waterproofing [with bike rubber innertube..]
still to go:
1. new powerful controller
2. welding another side box handles
3. installing regen braking button [when 1 is done]
4. reverse gear switch [when 1 is done]
5. wheel block switch [when 1 is done]
wojtek
Postby cbr shadow » Fri Jun 15, 2012 3:40 pm
Looking good! Any updates?
cbr shadow
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: horrorlv and 3 guests
