jojothedog
- Joined
- Apr 21, 2012
- Messages
- 15
Hi,
This is my first E-bike. I needed something to go to work and back because gas prices are getting ridiculous where I live in Ottawa, Canada. I started to research conversion kits and eventually settled on Golden Motor's Magic Pie 3 from Gary at Goldenmotor.ca. Gary has a reputation of being one of the better ebike dealers as I discovered in my research and I have to agree 100%. He was great to deal with, answered my emails within a day and shipped everything out and I got it within 3 days. I was concerned with torque and hill climbing ability because I have knee issues and should not be peddling and the MP3 was supposed to have good torque for a non-geared hub motor.
Got my kit in and installed it. Spent a night doing it. Takes some effort getting everything just right on the handle bars because of the thumb/finger actuated gear changers I have but I got it all to fit. Had to trim my grips down about an inch but still plenty wide. Everything seems to be of decent quality... time will tell but it all seems solid. The rear wheel was trued really well and fit into my mountain bike frame nicely. It's a very strong robust feeling rim. The wiring loom is all connectors and it made for a clean and easy install as far as wiring goes. A supplied washer and each side of the motor with the 6-speed freewheel I ordered and it all slipped right in and was centered. I had to grind the flanged part of one of the axle nuts because my rear derailleur is so close to the axle. I only have to take it down about 2 millimeters though. Luckily I have a bench grinder that made this easy.
The bolts from my disk brake were too long and touched the aluminum backing of the internal controller and bound the wheel from moving. All I have to do is find shorter ones or grind mine down a few millimeters but I didn't bother and will install it at a later date. I found the regen braking combined with the front brakes felt good anyway but I will definitely install the rear disk at a later point. I am not certain why but the brake lever that was supposed to be the rear brake doesnt engage regen. It might be a controller setting but I can not get the software from their site to install. It's a problem with their install package they are aware of as I have seen other posts about it but they have not corrected the problem. I'll continue to try and get it to install. If anyone knows if getting both levers to start regen is a controller setting let me know please.
I ordered the panier rack that allows the batt pack to slide in and lock on to to prevent theft but I ended up using a rectangular tackle bag I found at Canadian Tire to house the battery. It's perfect for me because the less it looks like an e-bike the better. I don't want to attract unwanted attention and I prefer the stealthy look anyway. At some point I will buy some saddle bags to hang on either side to hide some of the motor as it really catches people's attention. The GM 48v10ah batt pack fits into it easily and there is plenty more room inside for a rain suit and lunch ect. There are zippered pockets on all 4 sides as well. I just tightly bungee it to the rack and it's mounted solidly enough that way. It has a shoulder strap as well which is important because I need to be able to carry this into the office for a charge without everyone seeing a massive battery and charger. So many ignorant people who love to complain about anything and everything.
The cruise control is really nice! I have only gone 16km so far but I already know I would really miss it. Not sure why but having my thumb stretched out to hold the throttle in place is something I can live without. It's just so much more relaxing to set the cruise control and just ride along. I get to 42kmh on flat ground and it pulls my 100kg body up the hills I encounter no problem at around 30kmh. Power and torque wise the motor is everything I imagined. I just need to remember this is not a motorcycle, I have two of them, and that it really doesn't need anymore power for my needs as a commuter bike. I have nothing to compare it to though as this is my first e-bike but I do know that I would not want less torque than I have now. I know there are people who mod or swap controllers to get more amps but I don't really feel the need to do that at all. It does everything I ask of it very well and leaving it alone will ensure better longevity and batt/distance efficiency which is important to me.
So far I am impressed. I'll report back as I spend more time with it.
