I forgot to post last night (thought I did, maybe I typed it up and didn't save it?) that the motor and controller system worked perfectly after the above mod, no cutouts, however the BIKE sucked.
I suspect someone messed with it, because I had the following problems found when I was leaving work, none of which were a problem when I got there:
--front wheel QR lever was undone and unscrewed several turns.
--front left brake pad was UPSIDE DOWN and loose.
--brake switch on rear was loose, flopping around.
--rear derailer was severely misadjusted, would not stay on a gear.
--turn signal flasher wouldn't engage correctly because the little holder I have it in was crushed.
--headlight wire was pulled off the switch, and the switch itself broken, body pulled off the bracket I'd mounted it on.
--front tire extremely low
--front shock completely airless.
--something else but I can't remember right now.
All were relatively easy to fix or to work around, except the shock, as I can't hand pump it up--the pumphead won't fit down into the well to go over the valve stem. I have to use the electric pump at home for that. The shock does lose a little air each day but I had just aired it up the day before, and when i aired it up after getting home it did not lose any more than normal thru today. So someone probably let the air out deliberately.
Same with the tire, except I could hand pump taht up fine.
Headlight swithc easly bypassed by twisting the wires together. QR fork tightned, brake pad reinstalled correctly and aligned/tightened. Rear Brake switch tightened up. Uncrumpled the plastic holder for the blinker, and it works ok, though not as well as before. I think the bimetallic sheets of the blinker itself are slightly bent or misaligned.
Have to replace the headlight swithc, maybe tonight or tomorrow. I didn't have the camera with me to get pics before fixing everything so I could ride home, so I only have a pic taken tonight of the broken switch.
- DSC06872.JPG (40.69 KiB) Viewed 785 times
What bothers me is that I don't know anyone I work with that dislikes me at all, much less enough to try to kill me (by loosening the front wheel and the brake pad, which could've jammed in the wheel and locked it, with the QR loose).
So that means it was probably a customer, and I don't know any of them that dislike me that much either. Or just some random person that likes to screw around with cyclists or ebikers. But it's in the store, in the warehouse in back. I think if it were out front where everyone can see it it might've not happened, but in the back room there's no one to see, most of the time.
Tonight I put the motro thru it's most severe test so far--the same one that overheated the old 36V version 1 Fusin: riding slowly, 8-12MPH, heavy load on the bike, frequent stops/starts. Had about 72lbs of dog food on the bike--6 on the rear rack on top of the ammocan pack, and the rest on and in the front baskets.
Was not really a smart thing to do, as I could not actually "ride" the bike normallly--any kind of turn was nearly disastrous, and I dropped the bike twice when I lost my grip on the bars. I just stepped off so didn't get hurt, but both times I had to take the stuff off the bike, put it upright against a pole and tie the brake handles down to keep it from rolling, then relaod everything and restrap it down. But I couldn't wait on the food--it was a "get it now or never" super deal, and is why i really like having the ability to haul such cargo on CrazyBike2. I just never know when this kind of thing will come up.
I had to do what I never lke doing, and rode the sidewalks almost all teh way home--only after I crossed Dunlap was I on roads, and that's almost no traffic (one car passed me). 1/8 mile of parking lots, and the rest sidewalk.
Made it home ok, no damage to cargo or bike, other than more scratches and little dings from the fall-overs. Oh, and the CA's button connector somehow got knocked loose in one of hte falls, so I had to open it up and reseat it (not off all the way, just enough to mae the buttons not work).
