bobmcree wrote:the motor is from china, they are not imported currently. ...
-bob
bobmcree wrote:the motor is from china, they are not imported currently. the Cruzbike is sold as a complete bike or a kit that can be mounted on most suspension mt bikes. the frame they use is a generic taiwanese aluminum unit.
-bob
bobmcree wrote: the particular controller i have is by ananda and is potted. it was an evaluation unit and has adjustable power limiting..
The7 wrote:bobmcree wrote: the particular controller i have is by ananda and is potted. it was an evaluation unit and has adjustable power limiting..
The stock controller from My AL1020 is also Ananda (24V 15A) which was working OK with 36V.
It is then upgraded with 20A X-controller which can work from 24V to 48V battery for AL1020.
bobmcree wrote:this motor was one of several sent here for evaluation. i don't have an exact part number and there are no numbers on it. friends who have taken them apart love them;
fechter wrote:The toothless planetary gear is interesting. Any idea how force is maintained on the rollers? What happens when the metal wears down a bit?
nemo wrote: From what I saw inside:
I think that the force is maintained on rollers by clever mechanical design when the motor spindle(shaft?) in the middle is one firm point, 3 wheels can shift a little bit and engage themselves against barrel on the outside , again a firm point.
It's done by using needle bearing inside the 3 wheels with not enough needles.(img7973) so the wheels doesn't stay centeredhere.
fechter wrote:Thanks, I see now. It's hard to see in the pics, but the rollers are offset slightly. This works similar to the roller clutch on a Currie drive.
TylerDurden wrote:Very intriguing planetary system! Are the rollers solid metal, or are they composite with nylon?
I tried to find more info on that type of drive, but no luck yet.
Bob: have you got a link or another address?
TylerDurden wrote:
Carrier -> Green = Planet CARRIER
Case -> Blue = RING gear
Planets -> Red = PLANET gears
Axle -> Purple = SUN gear
The7 wrote:For nemo's TARN motor:
The SUN is the input.
The CARRIER is stationary.
The RING is the output.
Talked with a good friend of mine who is in mechanical engineeing/profession yesterday.
He commented that the teethless planetary gear has shorter life and lower efficiency than the teethed one.
The7 wrote:]
I also found that MC33035 3 phase IC driver, common in many controllers, has max voltage of 40V. That's max rating. Not recomended which is 10-30V.
bobmcree wrote:The7 wrote:]
i don't know where you got the 40v spec but it is incorrect. the absolute max rating according to the datasheets i have for the original motorola part used in the kollmorgen controllers i have been using for years is 30v and i know for a fact that several people have blown them at 36v.
do you have a data sheet showing a 40v rating?
nemo wrote:bobmcree wrote:The7 wrote:]
here:
on page 3
http://www.onsemi.com/pub/Collateral/MC33035-D.PDF
Vc30,Vcc40V...can you explain? Thank you
Return to E-Bike Reviews & Testing
Users browsing this forum: No registered users and 4 guests
