knightmb
The same bike from the SLA distance test using a NiMH battery pack instead.
Original Test Done Here: http://endless-sphere.com/forums/viewtopic.php?t=44
Bike Stats
Test Conducted 12/15/2006 @ 10:30AM
Environment Stats
Rider Stats
The day for this test run was sunny and clear. It was cold, so that might affect the test somewhat because the batteries lose some power when they get cold. But since it sat in the garage and it's such a short drive to the park, I ruled out the cold being a major factor, especially once I start driving around because that will heat up the batteries anyway. If anything, the cold weather would keep the motor and controller cool, so less resistance for the power to the motor.
I put on my coat and gloves because I knew this was going to be a cold ride. I started on laps around the park from the 1 mile marker (just like last time). The bike uses an instant start controller, so away I go for many laps around the park. During the ride, speeds stay steady between 16 and 18 MPH. The ride was very straight forward and the cold weather made the park a ghost town. Less people to avoid so it was easy to go full throttle the entire way. I had no problem going up and down hills.
It was a very comfortable ride, here are the results.
Test Ride Results:
Bike Stats
- Bike Weight: 64 lbs
- Tire Pressure: 53.5 PSI both Front and Rear Tires
- Batteries: (1) 24 Volt @ 12AH NiMH Battery Pack, Full Charge
- Battery Age: Purchased 3/24/2005
Environment Stats
- Weather: Sunny
- Winds: N 7 MPH, Gust on Occasion
- Temperature: 56 F
- Humidity: 54%
- Barometer: 29.98
Rider Stats
- Gender: Male
- Weight: 170 lbs
Test Ride Results:
- Total Ride Time: 53 Minutes
- Max Speed: 18.7 MPH (30.1 KPH)
- Level Top Speed: 17 MPH (27.4 KPH)
- Average Speed: 14.1 MPH (22.7 KPH)
- Total Ride Distance (unassisted): 12.5 Miles (20.1 Kilometers)
