hi-powercycles wrote:Wow! Nice test dirtdad! You beat me to the punch! I will be doing some testing of my own this week and it will be fun to compare notes! How do you like the Infineon controller?
GGoodrum wrote:Like many here, I've run my 5304 on my Townie at 72V/85-90A, with no problem. One other thing that will be interesting, will be to see how well these new composite gears hold up, after you two have had a chance to put some hard miles on the 600W motors.
-- Gary
The BMC has stronger pull in the range of say 20-30mph. They 5304 has more acceleration power at 30+. Most of the time in regular riding I do not feel a big difference.
The BMC phase wires are just too small to handle this kind of power for any significant amount of time and put it at a disadvantage. I am guessing they are 16 gauge? They ARE silver/teflon, and the harness coming off the motor is about 2 feet long and I have not shortened it. At the bottom of the big hill climb they were warm to the touch. By the top of the same climb, 1/2 mile later, the were too hot to hold on to. I think heat and resistance were a big factor on the hill climb.
voicecoils wrote:GGoodrum wrote:Like many here, I've run my 5304 on my Townie at 72V/85-90A, with no problem. One other thing that will be interesting, will be to see how well these new composite gears hold up, after you two have had a chance to put some hard miles on the 600W motors.
-- Gary
What's your opinion on the continuous power handling of the X5, Gary? 6.5kW is impressive, but can it be sustained?
If so, I doubt the 600W BMC could handle the same. Still, for most eBiking applications I don't think such power is necessary![]()
I'm quite interested in long term reports of the gears as well!
Microbatman wrote:What are the changes between the old 400W BMC and the 600W BMC? Are they the same casing?
Return to E-Bike Reviews & Testing
Users browsing this forum: No registered users and 4 guests
