How can I get 110ac from a ZENN runs at 69-80v dc
Solar, wind, hydro and other non-fossil sources of electricity.
MitchJi   1 GW
1 GW
Post by MitchJi » Oct 30 2019 12:28pm
I can’t find an invertor that converts 70-80 volt dc to 110 ac. Lots of units that do 12-48v dc.
I need to run a snall boiler and the associated pump that supplies radiant radiators for a small house.
I’m cold due to a power outage 4th day.
M
Best Wishes!
Mitch
Buying a new Tesla? Please consider using our referral code https://ts.la/lynnem96959 to get one thousand miles of free Supercharging.
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Three examples are Chevy Volt and Nissan Leaf and Tesla Model 3 packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
TPA   10 kW
Re: How can I get 110ac from a ZENN runs at 69-80v dc
Post by TPA » Oct 30 2019 1:09pm
EDIT
Ok, so my feeble mind just realized that this is a Zenn Auto. Please disregard the comments below. Connecting a battery to the inputs of a charge controller will cause damage to the controller, and I don't know of a DC-DC buck converter that can handle large amounts of power.
Knowing the DC source and the amount of power it provides would be very useful in working out a solution.
For example a DC-DC buck converter could be used if power level is low, like maybe less than 1000W.
You could connect your dc source to an MPPT charge controller like the Midnite Classic or Schneider MPPT60-150 or even an Outback FM80. They can take up to 150V at 60A and turn it into just about anything else. You would likely have to connect the charge controller to a 12 or 24V battery and then connect the inverter to that.
I think the MPP Solar GK series inverters will take your DC source and convert it to AC without batteries and without a charge controller (just depends on what the DC source is). The MPP inverters will only output 240V, so you would need a transformer (there's always something isn't there?). Here is a link to MPP GK info https://www.mppsolar.com/v3/pip-gk-series/
Here is the 24V 3000W version on Ebay (you can find a 48V 5000W version there also) https://www.ebay.com/itm/GK-3kva-3000w- ... SwRzZcRW2x
Here is the kind of transformer that I mean for this application https://www.ebay.com/itm/2000W-Step-Up- ... SwVmNdTTZ8
Hope it helps
My Ebike is built with a hub motor purchased from www.ebikes.ca
It has performed flawlessly since it was installed. I cannot
recommend the professional folks there enough.
Balmorhea   100 W
Post by Balmorhea » Oct 30 2019 2:23pm
Any little simple space heater that uses an AC/DC motor for its fan should work on 70-90VDC, just at a lower maximum output. If you have one of those, try it. At least all the energy you use will turn into heat right where you want it.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Oct 30 2019 4:09pm
Probably not going to help your immediate situation, but they are available on AliExpress.
Here's one: https://www.aliexpress.com/item/1000001 ... 2e0evK6Xuw
M
P.S. I have had the exact same thoughts myself: during an emergency run my essentials off my EV.
Voting has ended: viewtopic.php?f=26&t=102697
Слишком мало, слишком поздно
MitchJi   1 GW
1 GW
Post by MitchJi » Nov 02 2019 3:58pm
Change of plans. I am now planning on using inexpensive EVs for DIY powerwalls. I think the cheapest way to do DC to AC conversion is to use 12v DC to 110v AC inverters.
So now I need a recommendation for an affordable 72-96v DC to 12v DC converter.
I can use the ZENNs 12 v dc output if its sufficient.
Best Wishes!
Mitch
TPA   10 kW
Post by TPA » Nov 04 2019 1:37pm
Watch this video for how this guy is trying to access the 12V system on a Tesla model S. It may give you a few ideas.
https://www.youtube.com/watch?v=2nMs_DwveqA
MitchJi   1 GW
1 GW
Post by MitchJi » Nov 07 2019 11:34am
TPA wrote:
Nov 04 2019 1:37pm
Thank you!
I’m currently planning to buy either one or two 50amp 70-80v to 12v dc/dc converters from thunderstruck motors for $125 each. If I need more than 50a they can be run in parallel. I’ll use them with 12v to 110v inverters which are available for affordable prices.
I’m planning to have thunderstruck install the converters because I can’t do anything.
Best Wishes!
Mitch
