John in CR
100 TW
My issue for the tank has remained the tank itself, because I want to connect it to standard pressure. I've decided to make one myself because there's nothing suitable for scrounging around here. My plan is to take a spare propane tank that I have, flush it out and cut it in half. Take an 8ft piece of sheet metal and roll it up to make a cyclinder to slide pieces of propane tank into each end, unless bolting one end on using the overlap region would work well enough. It gives me the ability to weld in whatever fitting connections I need. This will give me a nice long 50+gal tank plenty strong. With the tank long and laying at the roof's angle and the collector below the bottom end I should be able to get a good thermo syphon circulation, so no pump is needed.
Any input on what gauge steel sheet I should get, and what if any coating I should put inside the tank?
John
John
