6v 300mah solar panels for individual cell balancing?
Solar, wind, hydro and other non-fossil sources of electricity.
Postby novembersierra28 » Mon Nov 08, 2010 8:04 am
Need some help figuring out how to wire these into a bms for safe high voltage cutout at 3.6v for lifepo4.
Reason I went for 6v is they work fine in the shade at above 4v... but in direct sunlight you're looking at serious problems with overcharge
Last edited by novembersierra28 on Mon Nov 08, 2010 3:18 pm, edited 1 time in total.
It is amazing how much you can accomplish when it doesn't matter who gets the credit
Harry Truman
Plasma Boy Jr.(11months ago) knew physics, several books later I built my first PCB balancer + A123 battery pack
Etek 300a Curtis 9.2ah A123 lifepo4 16s4p 59.5mph
crazy video 0-94km/h in 6 seconds http://www.youtube.com/watch?v=FEGyLBg0kDM
novembersierra28
Re: 6v 300mah solar panels for individual cell balancing?
Postby Jeremy Harris » Mon Nov 08, 2010 3:08 pm
The simple way to do this is to use a shunt regulator set for the maximum cell voltage you're looking for.
If it were me, then I'd just hook up an LM431/TL431 shunt regulator across the solar cell, with an external transistor to increase the current handling capability.
If you take a look at the original Fechter/Goodrum/McCree BMS circuit you will see exactly what you need, just use the shunt regulator part directly across the solar cell - you don't need the opto-isolator or the LED.
Jeremy
Jeremy Harris
Return to Alternative Energy
Who is online
Users browsing this forum: No registered users and 2 guests
