http://www.facebook.com/profile.php?id=1522650768
Claims:
http://www.facebook.com/note.php?saved&¬e_id=272892219411904
Nanosolar Spray-on Technology. A Solar Powered Electric Aircraft. Velocity SE, the summary..
by Alex Tury on Wednesday, October 12, 2011 at 6:45pm
Our research group has invented a very unique nanosolar paint, which can convert visible light, infrared light, ultraviolet light, x-rays, gamma-rays, and any magnetic fields or electromagnetic fields into electric power. This nanosolar material is eight* times more efficient than regular solar cell technology. It can harvest energy on a cloudy day or even at night-time. Moreover, this nanosolar material allows to absorb static electricity from a friction of the airflow and convert it into usable energy.
The nanosolar material looks like a plastic and can be sprayed on any surface like a regular paint. The surface of an electric aircraft painted with this nanosolar material can collect enough energy to charge its batteries. Thus, the aircraft power is generated from two sources: the solar source from a very wide range of solar light and the static one.
In addition, our research group has invented a unique power saver. Installing the power saver means having at your disposal approximately twice the amount of the energy supplied by the sun and the wind combined. It acts as a catalyst to double the power generation in the embedded solar cell via a highly efficient electric motor.
This solar powered electric aircraft does not require any extra fuel to keep it flying. Because of its unique nanosolar spray-on technology, the aircraft batteries would completely self-charge.
Velocity SE, Summary:
■a very unique nanosolar technology - the material of the paint, which converts visible light, infrared light, ultraviolet light, x-rays, gamma-rays, and any magnetic fields or electromagnetic fields into electric power;
■a very unique electric circuit (scheme) - the design of wiring and radio details of the power saver, which extends distance on one charge more than two and a half times;
■a very unique power pack (energy storage) - LiFePO4 polymer batteries integrated with the power saver;
■a very unique electric motors - capability to use DC and AC in the same time that makes the motor extremely powerful and easy to control (to operate).
http://www.facebook.com/notes/alex-tury ... 9611034165
This is the future!!! I love this project very much. It will change the World. Nanosolar Spray-on Technology Our research group has invented a very unique nanosolar paint, which can convert visible light, infrared light, ultraviolet light, x-rays, gamma-rays, and any magnetic fields or electromagnetic fields into electric power. This nanosolar material is eight* times more efficient than regular solar cell technology. It can harvest energy on a cloudy day or even at night-time. Moreover, this nanosolar material allows to absorb static electricity from a friction of the airflow and convert it into usable energy. A Solar Powered Electric Aircraft, an example. The nanosolar material looks like a plastic and can be sprayed on any surface like a regular paint. The surface of an electric aircraft painted with this nanosolar material can collect enough energy to charge its batteries. Thus, the aircraft power is generated from two sources: the solar source from a very wide range of solar light and the static one. In addition, our research group has invented a unique power saver. Installing the power saver means having at your disposal approximately twice and a half the amount of the energy supplied by the sun and the airflow combined. It acts as a catalyst to double the power generation in the embedded solar cell via a highly efficient electric motor. This solar powered electric aircraft does not require any extra fuel to keep it flying. Because of its unique nanosolar spray-on technology, the aircraft batteries would completely self-charge. Velocity SE, Summary: · a very unique nanosolar technology - the material of the paint, which converts visible light, infrared light, ultraviolet light, x-rays, gamma-rays, and any magnetic fields or electromagnetic fields to (into) electric power; · a very unique electric circuit (scheme) - the design of wiring and radio details of the power saver, which extends distance on one charge more than two and a half times; · a very unique power pack (energy storage) - LiFePO4 polymer batteries integrated with the power saver; · a very unique electric motors - capability to use DC and AC in the same time that makes the motor extremely powerful and easy to control (to operate).
At the recent 2011 Green Flight Challenge
http://cafefoundation.org/v2/gfc_main.php
2nd-place finisher e-Genius produced numbers like this:
http://cafefoundation.org/v2/gfc_2011_results.html
34.7kWh consumed over a 193.7Miles 314km distance at 105.7MPH 171kmh or 111Wh/km or 66.3kWh/600km or 19kW/h
Just sayin'
Lock
