Best Hub Motor for Very Hilly Town?
Get the forum community involved in polls and surveys.
Postby click68 » Wed Jan 02, 2008 1:18 am
I live in a small (2,200) pop. town which is VERY hilly.I wonder what the best hub motor would be for hills?Speed is not important but 15 to 20 mph would be nice.Any suggestions/opinions/experience?
click68
Re: Best Hub Motor for Very Hilly Town?
Postby BiGH » Wed Jan 02, 2008 4:46 am
Team Hybrid puma or texas electric bikes hub motor.
Bike / Motor: Electric specalized rock hopper with Crystalyte 504 / 26"
Batt: Yesa 72v (36v*2) (getting 6.7ah) LiFEPO4 in a Topeak bag. OR 1x eMTB 48v 20ah pack (straps to frame) -depending on range requirements.
Controller: Unmodified 48a digital with 4110 Fets
Current Prob: Bike is in parts getting painted / drying / testing replacement BMS
Trail of Dead Parts:Avanti Frame, 408 motor *melted*, 35a controller - i broke by trying to mod it 2nd controller - blew it up.
My Ride
BiGH
Postby fechter » Wed Jan 02, 2008 10:21 am
Another option would be a Crystalyte 5305.
fechter
Postby Johnbear » Thu Jan 03, 2008 11:46 pm
An economical solution is a golden motors hub motor. They are brushless and gearless, They are fairly torquey - not as powerful as the 5 series xlyte, but I find it a bit more powerful than a 4 series at 36 volts.
JohnBear
Johnbear
Postby Lowell » Sun Jan 06, 2008 9:31 pm
fechter wrote:Another option would be a Crystalyte 5305.
5305 in a 20" wheel will get you up any hill, batteries permitting of course. The 5304/20" is so torquey it will push my bike up overpass embankments, the only problem being that I couldn't actually stay on the bike for any length of time because the bike simply tipped over backwards.
To the original poster: How far do you need to go, and what percentage grades are you talking about? How much pedaling do you want to do?
Lowell
Postby Microbatman » Mon Jan 14, 2008 12:07 pm
Johnbear wrote:An economical solution is a golden motors hub motor. They are brushless and gearless, They are fairly torquey - not as powerful as the 5 series xlyte, but I find it a bit more powerful than a 4 series at 36 volts.
Jonbear do you have one of these motors?
Are they the same as a GL2 here?
http://www.users.bigpond.com/solarbbq/GL2.htm
This looks like a great alternaitve to the X5 as the weight is only 15lbs.
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Postby Jozzer » Mon Jan 14, 2008 2:03 pm
The Puma is lighter at around 8 lb's, pulls like a train up hills too. http://www.armybikes.com/pumahubkits.htm
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
Jozzer
Postby Johnbear » Mon Jan 14, 2008 2:39 pm
I live in Vancouver, BC where there are alot of hills, I prefer lightweight over a heavier bike, the puma or ezee motors look great from what I have been reading. The gl2 looks to be more powerful than the golden motor. From my experience the golden motor gives me more power than I need at 36v ( I need the exercise) - but people have different expectations of what is enough power from what you read here!
On my watt's up meter the motor can peak at 1800 watts (that is just the power from the battery), I do not know what exactly the motor sees. The controller is rated at 20 amps, but they run up to 40 amps with out modification, My crystalyte controller on the cycle analyst only occasionally goes above 20amps by less than 1 amp. The golden does reach 40 amps. I have 4 golden controllers (between me and a good friend actually) and all have different peak amp output. I don't know why that is. I guess quality control is not as high with these motors. However mine has worked great so far. So I guess it comes down to the size of your budget and how much power is enough. - A bit of a down side is that this motor is not compatible with the crystalyte controllers, so you are stuck with what you get. Also golden does not have great support. Hope this helps!
JohnBear
Johnbear
Postby parajared » Fri Jun 15, 2012 5:58 pm
cromotor/hubzilla ftw!
parajared
Postby SamTexas » Fri Jun 15, 2012 8:18 pm
click68 wrote:I live in a small (2,200) pop. town which is VERY hilly.
How hilly is very hilly?
Has anyone mentioned the super affordable 9C 2812? I have one on 20" wheel running on 52V. Top speed on flat is around 15mph and have no problem climbing 30% grade grass hill, no pedal assist. So much torque that it spun out of my front steel fork within a week of hard play (of course I didn't use a torque arm).
SamTexas
Postby Talons4 » Mon Jul 16, 2012 2:56 pm
Hey guys anything against the BMC v2t motor. Mine runs great and I live in very hilly country. It also should be a bit more efficient than your Crystalite options. In truth I only have about a 150 miles on my setup, but so far so good.
Talons4
Postby Kingfish » Wed Jul 18, 2012 11:36 am
Make mine a 2WD with 9C 2806 @ 63V :twisted:
MHahaha! KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9683 miles-to-date, 4193 as 2WD.
Kingfish
1.21 GW
1.21 GW
Postby ohzee » Wed Jul 18, 2012 11:41 am
lol bumping a thread from 2008 where the OP has not been on the board since.
I wouldn't expect any responses from him.
ohzee
Postby mr173 » Tue Apr 02, 2013 11:04 am
Talons4 wrote:Hey guys anything against the BMC v2t motor. Mine runs great and I live in very hilly country. It also should be a bit more efficient than your Crystalite options. In truth I only have about a 150 miles on my setup, but so far so good.
Agreed!! I'm using BMC v2t now.
With 36V minor paddle to uphill.
At 48V you don't really need to paddle to up hill at all.
mr173
Return to Polls & Surveys
