E-Brakes !!
Get the forum community involved in polls and surveys.
Ebrakes
Yes
20
35%
No
33
58%
On Some of My E-Bikes ( for multi bike owners ! )
4
7%
Total votes : 57
E-Brakes !!
Postby Ypedal » Tue Sep 08, 2009 8:59 pm
On " Your " ebike ?
ES site status page:
Ypedal
Re: E-Brakes !!
Postby amberwolf » Tue Sep 08, 2009 9:19 pm
Is the question "Have already", or "want to have"?
If the latter, then yes, if the former, then no.
I have to redesign the drivetrain to put a clutch on the rear wheel first (like that off an AC compressor in a car, but operating in reverse so it's always engaged unless power is applied or the mechanical linkage is operated), move all the shifting forward of that into the frame, so that I can use regen braking on my motor and still be able to coast.
amberwolf
Re: E-Brakes !!
Postby Zoot Katz » Tue Sep 08, 2009 10:29 pm
It's going to take awhile for me to figure out how it's best done.
I want to harness that energy for charging the battery.
Being able to modulate the e-brake with the rear brake lever is my first choice.
Being able to modulate the e-brake with the throttle would be my second choice.
Garden variety e-brake levers are pot-metal crap and don't fit road bars.
le Béte would benefit most from regen braking due to its greater weight.
But, it doesn't have a regen capable controller, AFAICT, (xlyte 72V, 48A, digital)
That might get substituted for a smaller Infenion controller that is capable of regen. (but might need to get beefed up for le Béte)
I've seen informative ES articles and great photos of more than a few different ways to implement and control e-brakes.
It's near time to search the archives and bash it out. (with a little help from my friends)
Zoot Katz
Re: E-Brakes !!
Postby ngocthach1130 » Wed Sep 09, 2009 1:30 am
elaborate a little more. You mean regenerative braking, plug braking, or you mean the ebrake line on controller that cut out power when brake is applied.
Either way, i have none of them ^__^.
Worse part of waking up...is having to stay up!
Thach(Tut)
ngocthach1130
Re: E-Brakes !!
Postby Ypedal » Wed Sep 09, 2009 6:30 am
The question was geared more at the simple " E-Brake " ie: cut throttle signal, cheapie one's that come with some kits to replace your stock brake levers...
I have a box of them gathering dust !! :wink:
Ypedal
Re: E-Brakes !!
Postby amberwolf » Wed Sep 09, 2009 6:50 am
Ah. I do have my brake lever rigged to do that, but it's with a magnet and a reed switch on the outside of it. :)
What's funny is that I have that on the outside of the entirely-plastic ScootNGo brake handle, which has a normally-closed switch in it (meaning if I engage the brake, the switch is *closed*) so it turns on the brake lights when I squeeze it. It's pretty crappy, but I havent' gotten round to putting reed switches on the outside of my locking brake lever, arranged so that the magnet holds one closed and the other is open in either position, using one for the throttle cutoff and one for the brake light. :)
I wanted to use the nice brake handles off the Honda scooter that I've already got the left one of on the bars, but the stupid switches in them are worn out and corroded inside, and not easily replaced with anything else due to their custom design. Thinking about using some hall sensors out of computer case fans, since they're switching and not linear. :)
I dont' suppose the ones you have in a box are magnetic rather than cheap switches? If they are magnetic, maybe I could make a deal with you for them, if it's cheap enough (I mean, *really* cheap, unless you could wait a month or two at least).
amberwolf
Re: E-Brakes !!
Postby nineball » Wed Sep 09, 2009 7:01 am
Dust Collectors here too
48v 1000w Rear Brushless Hub(Cracked Rim)/ Switched to 36v 500w E-Bikekit 28" 9c 9x7 (performs the same)
Keywin 60/72v 45A controller/w CA(smoked big time) Replaced with Methods 100v monster
(8) Bosch 36v Fat packs 72v + 3 12sla 97v Hot off charge
30-40 mph cruise...has hit 50 (bike & trike)
Trike is done, got over 1200 miles update/2100+ miles studded snows for winter
nineball
Re: E-Brakes !!
Postby Drunkskunk » Mon Sep 14, 2009 1:09 pm
I gave my last set to a girl I know who makes sculptures out of junk. they were shiney, so she baked me cookies.
That makes them usefull for something.
Cookies..
Monster Bike:http://endless-sphere.com/forums/viewtopic.php?f=6&t=38667
Drunkskunk
Re: E-Brakes !!
Postby D-Man » Sat Sep 19, 2009 11:37 pm
I just love my E-brakes!!!! :) They have worked just fine for almost 5000 miles. For normal street use stopping, they are just fine. They look a little cheap as the housing/levers are plastic so you have to be somewhat careful with the brake adjustment screws. My old levers were plastic also. Must be darn good plastic!
408 front hub
12000+ miles on sla's.
Michelin pilot sport 2.3 tires
D-Man
Re: E-Brakes !!
Postby parajared » Fri Jun 15, 2012 5:46 pm
e-brakes would be awesome if they engaged regen according to how hard you pull the lever, but all mine do is cut power to the motor. Lame sauce.
parajared
Re: E-Brakes !!
Postby rojitor » Fri Jun 15, 2012 6:11 pm
I never had those, i love my throttle with regen button instead.
rojitor
Re: E-Brakes !!
Postby Electroglide » Sun Sep 09, 2012 3:40 pm
I retrofitted a brake lever with a ratiometric hall sensor and magnet, and created a linear feedback on the rear v-brake, but with the v-brake adjusted out to just make contact on a full pull. Gave the best proportional regen results for a smooth electrical braking experience. I don't think i would want just mechanical brakes alone, though if your controller doesn't support proportional regen option you really don't have much of a choice. Having it disconnected from the throttle makes it feel more like a traditional bike.
Electroglide
Return to Polls & Surveys
Who is online
Users browsing this forum: No registered users and 1 guest
