What is your tire width?
Get the forum community involved in polls and surveys.
What is your largest or specialty tire width?
< 1.75"
6
10%
1.75
7
11%
1.9 - 1.95
6
10%
2.0
5
8%
2.1
4
6%
2.2 - 2.25
9
14%
2.3 - 2.35
6
10%
2.4
6
10%
2.5
10
16%
> 2.5
2
3%
other (explain)
2
3%
Total votes : 63
Postby Kingfish » Tue Mar 09, 2010 9:00 pm
My first survey :)
Personally, I am on the hunt for a dependable durable long-distance touring tire. I am curious what tire widths other folks are using on their rigs, and why. Select the closest width for your largest or specialty tire(s).
If you can, please comment:
  • Tire Model/Specs, MFR
  • Rim size, MFR if known
Any thing else you have to add is gravy!
Example: I run the Continental Contact Reflex 26" x 1.75 on a Champion (Chinese import) rim (mounted on my 9C 2806).
Thanks!
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9683 miles-to-date, 4193 as 2WD.
Kingfish
1.21 GW
1.21 GW
Re: What is your tire width?
Postby AussieJester » Tue Mar 09, 2010 9:03 pm
I use 24x2.95in on the front and 20x4.25in on the back...Front is a Hookworm the rear unsure of the brand
tiz a semi slick tire sold by ChoppersUS. Rear rim is double walled alloy fron some generic piece of crap that
will soon be changed for high end downhill variant.
KiM
AussieJester
Postby El_Steak » Tue Mar 09, 2010 9:05 pm
Maxxis Hookworms 26" x 2.5"
Great handling
Great comfort
Great looks
Added kevlar sleeve inside for puncture protection.
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: viewtopic.php?f=6&t=17166
El_Steak
Postby deardancer3 » Tue Mar 09, 2010 11:44 pm
Hookworms on one, big apples on the other. 2.1" rears
Chain Drive Advocate
deardancer3
Postby Gregory » Wed Mar 10, 2010 4:55 am
Maxxis Hookworms
Front 26"x2.5"
Rear 24"x2.5"
They don't look as balloony as I feared. Good quality tyre, but a bit expensive.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
Gregory
Postby alan » Wed Mar 10, 2010 7:40 am
Michelin City Pilots 26x1.75 F&R @ 80 PSI. Not the City, but City Pilot. Non-Pilot version does not have side wall puncture protection. Last set got about 3K miles without a flat, and if you don't mind riding below half the original tread, probably good for 4-5K miles.
-- Alan
alan
Postby El_Steak » Wed Mar 10, 2010 9:55 am
Gregory wrote:Maxxis Hookworms
Front 26"x2.5"
Rear 24"x2.5"
Do you have a picture of your bike, I'm really interested to see how it looks with the different size wheels.
thx
El_Steak
Postby EMF » Wed Mar 10, 2010 10:26 am
Schwalbe Fat Frank Cruiser Bicycle Tire 26x2.35 FTW. No suspension needed... 8)
EMF
Location: Curious about The Bikers Bar? Become a member to visit!
Postby Gregory » Thu Mar 11, 2010 4:28 am
thx
El Steak,
26" front, 24" rear Hookworms
It's a subtle difference. Here's a side on photo of the incomplete bike, taken straight on at knee height, it's even less noticeable standing above it.
A 20" rear is sensible for high voltage but I just don't like the look. So this is my compromise.
Once I get a black front rim to match the rear I don't think you'd spot the difference at a casual glance.
In 24" you get less tyre choices and Hookworms were one of the few I could get a matching pair of in Australia.
Oh and the OP wanted rim info - rear is Sun Ringle Mag 30, 10g spokes and 5305, front needs replacing once I can find a good rim second hand.
Gregory
Postby El_Steak » Thu Mar 11, 2010 6:36 am
Thanks for the picture, looks very nice.
I run a high voltage (88v) setup and reducing the wheel size would help a lot with efficiency (and acceleration). I have a hardtail so a 20" wheel is not an option as it brings the pedals too close to the ground and I can't adjust. That would be a good compromise.
El_Steak
Postby EDWIN » Thu Mar 11, 2010 7:28 pm
I run 1.75 shwalbe marathon plus.It is the only size I can get in 24".
EDWIN
Postby Drunkskunk » Fri Mar 12, 2010 10:14 am
26" x 2.5" Maxxis Hookworms on 34mm wide rims
Drunkskunk
Postby Kingfish » Mon Mar 15, 2010 3:56 pm
Kingfish
1.21 GW
1.21 GW
Postby torker » Sat Jul 31, 2010 5:29 pm
Kenda K-Rad 26 x 2.3 Cause they were wide and on sale for 11 dollars each at the lbs. :mrgreen: I was worried cause the sidewalls are thin. They remind me of a drag slick. But they are holding up good. But alas I am no Dogman so your mileage may vary. :mrgreen:
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
torker
Postby biohazardman » Sat Jul 31, 2010 10:19 pm
I have 1.95 on front and rear as that is all I could fit under the required fenders for the year round commute here in Portland. Having full suspension I don't need more tire for the ride. Son-in-laws bike will have some meats though. Doesn't rain much in the desert.
Just pretend that everything is OK maybe no one will notice.
Golden Motor Schwinn first build http://goldenmotor.com/SMF/index.php?topic=279.0
Giant BMC build viewtopic.php?f=6&t=235&start=390
Short ride vids viewtopic.php?f=3&t=20346&start=60#p321703
biohazardman
Postby Lock » Sat Jul 31, 2010 10:43 pm
"Other"
Front, Schwalbe Big Apple 50-305 aka 16" x 2" ... (Only `cause I'm happy w/12.5" but can't find quality rubber in this size.)
Rear Xootr 7" x 1"... cast wheel w/polyurethane "tire". (Should mean less bloody ankles plus fewer flat tires... Also believe it'll be easier to drag through snow and slush. Trolley tracks and drain covers may be interesting.)
Poll did not offer choice of mixed widths...
:wink:
LocK
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
Postby Kingfish » Sun Aug 01, 2010 2:12 am
If yer having difficulty finding tires - I just put this topic together yesterday: Rims and Tires Reference
My next ebike will have 2.5" or larger if I can get what I'm looking for in the USA :roll:
~KF
Kingfish
1.21 GW
1.21 GW
Postby moostrodamus » Sun Aug 01, 2010 5:39 am
Schwalbe Big Apple 2.1 on one bike, Schwalbe Big Apple 2.35 on the udder...
Commuter: Crystalyte HS3540
Infineon 40 amp controller
Ping V2.5 48v 20ah
moostrodamus
Postby Evoforce » Thu Aug 19, 2010 4:55 am
Panaracer Fire FR 2.4 on 26". Nice big mountainbike tire to handle my 5304.
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby Zoot Katz » Thu Aug 19, 2010 9:46 pm
I voted 2.35" because I love the ride of my Big Apples on le Béte. They're noticeably larger than the 2.1" ones.
Fender clearance is touchy but they look great.
The other ebike runs 26 X 1.75" Schwalbe Marathon Plus. I'll put the two inch apples on it when the Marathon Plus die.
(I wrapped the apples with cling wrap and stored them in a cool, dry, dark place, away from ozone sources so they don't deteriorate.
There's still lots of miles left on these Marathons so the 2" Big Apples might be stored a long time.)
Zoot Katz
Postby kevo » Wed Aug 10, 2011 10:17 pm
I'm on a road bike - so about 1" !
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Return to Polls & Surveys
Who is online
Users browsing this forum: No registered users and 1 guest
