Ok, I’ve been lurking around these forums for about a week now and I get the impression that it’s primarily DIY oriented as it seems most of the e-bikes here are either custom built or kits. Well, I’m not that handy at fabrication and even less confident about working with electronics, but I just recently got excited about e-bikes when I found the Wikipedia article when reading up on mopeds. So I’m looking at purchasing a pre-built e-bike.
I’m looking to get an e-bike because I want a more environmentally friendly way to commute. I plan on replacing a good majority of my dirty combustion vehicle miles with cleaner, more efficient e-bike miles. Plus, it seems like a great way to get some added exercise! So I want something comfortable and reliable and I’ve widdled it down to these choices:
Tres Terra Europa $1500:
What I like - Twist-grip throttle; halogen head light & LED tail light, lighting system independently powered by a Shimano dynamo (generator) front hub; sturdy aluminium cargo rear rack; full fenders; suspension seat post & quick release seat height adjustment
What I dislike – It’s heavy: 65 lbs + battery 9 lbs = 74 lbs; & uses a brushed motor (apparently these require more maintenance?); 6 hours to recharge the battery
http://www.tresterra.com/europa.html
eZee Forza $2200:
What I like – choice of either eZee Assist Factor speed dial or pedal activate preset dial controller; Brush-less 36 Volt Servo motor peak 700 watt / continuous 350 watt with planetary gears; lighter: 49lbs, 58 lbs including Lithium-Ion battery pack; fenders, lights, & cargo rack included; aesthetically I prefer this bike over the Europa.
What I dislike – a bit pricy
http://www.ezeebike.com/products_forza.html
eZee Cadence $1700:
What I like - Brush-less 36 volt Servo motor peak 700 watt / continuous 350 watt with planetary gears; 2.5â€￾ wide balloon tires; fenders, LED lights, chain & mudguard, & cargo rack included; On & off-road capabilities
What I dislike – heavier than the Forza: 65 lbs with the NiMH & 67-1/2 lbs with the Lithium battery pack
http://www.ezeebike.com/products_cadence.htm
Schwinn any of the 2007 line $1500-$2000:
What I like – lightweight: 40-45lbs; range: 60 miles; charge time: 4 hours; they’re all very aesthetically pleasing & I would have trouble choosing between the Continental, World GSE, & Campus models
What I dislike – I can’t find them for sale anywhere online yet!
http://www.schwinnbike.com/products/intbikes_category.php?id=110
Other:
While I’ve looked into several other e-bikes & companies there might be some out there that I’ve overlooked that meet my needs. So, I’m very open to suggestions as well!
It's too bad TF discontinued their ebikes!
Thanks for your vote and/or input!
eZee Forza $2200:
eZee Cadence $1700:
Other:
