After many, many .. MANY reliable miles over the last 2 years, my rear 406/409 needs new bearings.
So.. if i have to take the wheel of the Chaos.. i may as well try a different motor !
2nd detail : The current Lithium 72v 20ah packs are going to receive a Cerebral-Bypass .. as in BMS Bypass !!!1
The plan is this:
-Crack open both Lexan boxes holding the battery packs that i worked so hard to put together, ( if any of you followed the Box build thread )
http://endless-sphere.com/forums/viewtopic.php?t=1711&start=0
- Check pack ballance, and perform a 100 % DOD test while the cells are exposed to manually monitor the pack and BMS operation and Ballancing..
- Add 12 gauge leads to bypass the discharge portion of the BMS.
- Pray that i can re-glue the polycarb boxes without making a mess of the thing.
- Remove the 3pdt Relay setup on the bike currently for the Dual speed motor
- Mount a 72v 40 amp controller to the bike !!!
- Remove Disk brake cover from current 406/409 motor as i'm sure the thread-on adapter is on there permanently now ( not that i use my brakes hard.. but i suspect it's wedged in there )
AND THE BIG QUESTION !!!!!
What ever is most popular by Friday Morning Goes !
The plan is this:
