What shifter do you prefer on your hybrid or mountain e-bike
Get the forum community involved in polls and surveys.
What shifter do you prefer on your hybrid or mountain e-bike?
Trigger
18
62%
Gripshift (twister)
9
31%
Downtube
0
No votes
Barend
0
No votes
Stem-mounted
0
No votes
Top Bar shifter
2
7%
Total votes : 29
Postby kmxtornado » Mon Oct 24, 2011 9:13 pm
I suppose your favorite will depend on what type of throttle you have. I'm getting a thumb throttle and wondering what type of shifter will work best with the bike. Perhaps twist grip? I'm used to it already and am leaning towards that anyway b/c:
1. Thumb throttle with trigger shifter would be weird since the thumb throttle is a similar mechanism or at least the mechanics of it is similar.
2. Not sure if there'd be enough room. I figure a twist grip shifter with a thumb throttle would be a perfect match.
Thoughts? Recommendations?
- My very first e-bike conversion ever: http://endless-sphere.com/forums/viewtopic.php?f=3&t=32668&p=474570#p474570
- Build Blog (more detailed than the above thread): http://e-bikeconversion.blogspot.com/ (20mph)
- Ultra mini folding bike upgrade (in-progress): http://endless-sphere.com/forums/viewtopic.php?f=3&t=33471 (12mph > 18mph)
- Recumbent Tadpole Trike completed Aids Life Cycle ride from SF to LA: http://kmxtornado.blogspot.com (27mph flats)
- Catrike Speed (in process)
kmxtornado
Re: What shifter do you prefer on your hybrid or mountain e-
Postby FastDemise » Mon Oct 24, 2011 10:48 pm
I'm currently using trigger shifting with a thumb throttle. It was tricky for me to get it setup between the 2 shifting levers but it works for me since the brakes and shifter are 1 unit. I only got thumb as my last bike had twist shifters so I couldn't use the twist throttle. Just a post noob so hope I help in some small way. :-)
Cheers
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
FastDemise
Postby biohazardman » Mon Oct 24, 2011 11:13 pm
Love the trigger shifters! I used the stock front derailleur shifter for a throttle as the derailleur itself was removed cuz I really don't need all the gears. It’s a Shimano rapid shift so the thumb lever works the throttle 0-30mph, it clicks and locks on at 30mph if I push it far enough. I can then control 30-40mph with the lever. I need to release the throttle with the finger lever to slow down. Or I can hit my rear brake lever and kill the motor. Werqs well for me and the few that have been on the bike never complained so it must be OK. Lots of way of doing things. I have seven gears in hte back but use only four.
So no wires on the bars and things look stock as well as the throttle stays dry where it is cuz it rains a bit here.
Just pretend that everything is OK maybe no one will notice.
Golden Motor Schwinn first build http://goldenmotor.com/SMF/index.php?topic=279.0
Giant BMC build viewtopic.php?f=6&t=235&start=390
Short ride vids viewtopic.php?f=3&t=20346&start=60#p321703
biohazardman
Postby SamTexas » Mon Oct 24, 2011 11:28 pm
biohazardman wrote:I used the stock front derailleur shifter for a throttle as the derailleur itself was removed cuz I really don't need all the gears. It’s a Shimano rapid shift so the thumb lever works the throttle 0-30mph, it clicks and locks on at 30mph if I push it far enough. I can then control 30-40mph with the lever. I need to release the throttle with the finger lever to slow down. Or I can hit my rear brake lever and kill the motor. Werqs well for me and the few that have been on the bike never complained so it must be OK. Lots of way of doing things. I have seven gears in hte back but use only four.
Very creative! Can you post additional pictures showing how the shifter cable is connected to the actual throttle?
SamTexas
Postby biohazardman » Tue Oct 25, 2011 2:24 am
It is the stock shifter cable you see in pic two going into a hole in the thumb throttle inside the bag. The throttle is mounted to a plastic rod bolted through the sidewall of the battery box you can see the nut that holds things on. Pic one is the stock Shimano Rapid shift that came on the bike when new. It's all there is to it other than the three wires going to the controller that come out the bottom out of sight.
Only problem with this type of shifter is the single pull is not long enough for full throttle. So you have to pull to click then release and do it again for full throttle. At least with the two throttles I have had anyway. Really not to bad of a deal as it's like having cruise control at whatever speed you adjust it for. Grip shifters are easier because they will give you full throttle and return to zero easy once you remove the locking spring.
biohazardman
Postby StudEbiker » Tue Oct 25, 2011 10:42 am
I like top bar shifters with thumb throttle with no LEDs. Top bar shifters are not in the poll so I didn't vote.
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby kmxtornado » Tue Oct 25, 2011 12:50 pm
Sorry, I added the top bar shifter to the poll but it reset everyone's responses. Hoping you guys wouldn't mind revoting. While I'm at it, am I missing any other types of shifters you guys use?
kmxtornado
Postby Drunkskunk » Tue Oct 25, 2011 5:43 pm
Trigger shifters and half twist throttles. Every bike I've built has had some version of this. Usualy Shimano rapidfires, because I like the extra long brake leaver they use.
Drunkskunk
Postby kmxtornado » Thu Nov 10, 2011 3:45 pm
I've installed my kit and I found that the thumb throttle (at least the ones that move sideways horizontally parallel to the ground) needs a lot of clearance. It's more ergonomic than the ones that push downwards vertically, but at the expensive of needing more space. The twist grip shifter had to be moved way over to the right to provide the clearance needed for the thumb throttle I have:
Please feel free (and I encourage you) to post pics of any conflicts you had btw different types of shifters vs throttles. This will help the newbies in their decisions in choosing stuff like this and inform them of what to expect and think about. None of this occurred to me until the day of the build. A bit disappointed that I have to slide over and regrip to change gears and engage the throttle. It should still work okay. Minor detail worth noting.
kmxtornado
Postby Toorbough ULL-Zeveigh » Fri Nov 18, 2011 12:35 pm
dude, u can't ketch a break.
where's the 'other' :?: :P
i very much doubt there's anyone else on here that's a.b. normale who actually prefers shitmano sti.
can't stand having excess crap on the bars.
guess i'll just lump it into triggr.
Shimano XT Dual Control
the pessimist engineer sees a glass that’s twice as big as it needs to be.
the optimist engineer sees that the glass has a 100% safety tolerance.
http://what-if.xkcd.com/6/
there is zero consequence to ignoring ayn rand
Postby kmxtornado » Fri Nov 18, 2011 1:25 pm
That's very cool and yes, very clean too! I love it....at least the concept of it. I'd like to try it before buying though. Just read you article. Did you write that by chance? Anyway, it's definitely something to explore. Thanks for posting it up. I'm definitely an advocate for cleaning up the handlebars with minimal components on it as possible (at least appearancewise but still have all the functions). That's another reason why I like the Gripshifters - blends right into the handlebar and no need to change grips to engage shifting.
kmxtornado
Postby amberwolf » Sat Nov 19, 2011 1:32 am
I *prefer* automatic shifting, but that's not available on very many bikes. :lol: I have one Landrider autoshifter but it needs tuning to shift at some slightly different speeds than it does by default, and I havent' sat down to figure out how to do that (add or trim the weights, probably).
I've also got the NuVinci autshifting devkit, but that's not installed yet as the bike is still in progress. Once it's done and tuned I'm sure I'll like it way better than any of the others.
I actually prefer gripshifters for manual shifting, simply because my hands are getting arthritic and using a finger to push a shifter with can be problematic especially when it is 65F or below, and I have had problems with the well-used trigger shifters I've got so far (otherwise I'd probably prefer those). Gripshifters I can at least use most of my hand to shift with, so while it stil hurts it isnt' nearly as bad.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Enpro » Sun Jan 15, 2012 8:03 am
Well with a thumb throttle i would say gripshift but i just hate the feel of a cut in half grip .
Lock on grips rule! so i just stick with my scram x 0.9 shifter with a slight modification on the triggers to fit around my thumb throttle.
Enpro
Postby Alan B » Sun Jan 15, 2012 9:56 am
Moved the grip shifters onto short bar ends. Used Magura twist grip throttle and corresponding off side grip. Don't shift often with the motor but if needed it is easy to do. Bike was originally gripshift, and triggers are problematic with hayes hydraulic front brake.
Alan B
1.21 GW
1.21 GW
Postby Kingfish » Sun Jan 15, 2012 1:26 pm
On Triggers:
With my custom 2WD, I have a Campy Chainring on the front and MtB Freewheel on the back. The front uses the Campy Derailleur and the rear uses Shimano. I created a custom mounting for the forward derailleur which adapts the road-racing design to FS MtB frame. One small problem that I did not anticipate is that the MtB Triggers used (in my case SRAM) index differently than they would for road-racing. In other words, I could dial in the correct default position for the typical chainring, however the offsets were not lining up precisely, with accumulating error so that my 3rd ring could not align without a lot of noise… which naturally reduced the utility.
For my road trip last summer, I figured out a workaround in the field: Only use the first two largest chainring settings in conjunction with the first 3 smallest freewheel gears, resulting in alignments/indexes that were never far off. Really the only time I needed to downshift was on the steepest hill climbs to reduce consumption and extend range. In theory though, the implied design was there in case of complete power failure, and that did not occur until the dark and stormy night when my second hub seized up from rust on the way home from work after I was already near the top of the last hill. :roll:
Admittedly my configuration is a rare case, though interesting nonetheless.
In gear, KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9634 miles-to-date, 4144 as 2WD.
Kingfish
1 GW
1 GW
Return to Polls & Surveys
Who is online
Users browsing this forum: No registered users and 2 guests
