How many miles since last breakdown?
Get the forum community involved in polls and surveys.
How many miles since last battery, controller or motor breakdown?
0
11
44%
100
4
16%
250
1
4%
500
0
No votes
750
1
4%
1000
3
12%
1500
1
4%
2000
1
4%
2500
1
4%
3000
0
No votes
4000
1
4%
5000
1
4%
6000
0
No votes
7000
0
No votes
8000
0
No votes
9000
0
No votes
10000+
0
No votes
Total votes : 25
Postby swade » Sun Nov 09, 2008 3:06 pm
By breakdown, I mean something beyond your control that prevented you from using the bike for more than a day. It might have cost more than a few dollars to fix, expertise beyond an average bike owner to fix and trouble shoot, waiting for replacement parts to arrive etc. Downtime while upgrading (unless its to replace something that broke) or experimenting with modifications to your setup shouldn't be factored in to this.
I'm mainly curious to see where I stand in relation to other e-bikers. It might also help to show that e-bikes are more reliable than one would gather by just reading the board. A lot of us probably only post when faced with a difficulty, thus skewing the impression that ebikes might require a lot of technical skill to be practical.
For the record, I've been six months and about 1500 miles since my last controller had to be replaced, probably due to riding in a big rainstorm.
Tony Stark was able to build this in a cave. With a box of scraps!
swade
Re: How many miles since last breakdown?
Postby jondoh » Sun Nov 09, 2008 5:54 pm
I voted zero though I've been tripped up by a tire blowout. The resulting accident was catastrophic and required re-lacing the hub into a new rim. I have not had a single problem with the motor (though I wonder about a rough buzzing noise it makes only at 13 mph). The controller has been perfectly fine as well.
My milwaukee battery packs have a lot of redundancy. With 2s5p, i will still have 80% if one string goes. I've actually replaced like 4 packs under warranty. Only one was due to a bad cell. The rest were bms problems.
I've got almost 1600 miles on my ride now. My wife and I share one car so my bike is actually my main way of getting around.
My builds at www.JDOBikes.com
jondoh
Postby pwbset » Sun Nov 09, 2008 6:35 pm
jondoh wrote:(though I wonder about a rough buzzing noise it makes only at 13 mph)
Sure it's the motor? I get a gnarly buzzing right around 13mph also... sounds like a dying chainsaw, but I swear it's my controller and not my motor. Smooth as silk otherwise.
pwbset
Postby Link » Sun Nov 09, 2008 6:44 pm
Zero. I still need to either replace the hall sensors or get one of those PCBs that turn a controller sensorless. :?
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Link
1.21 GW
1.21 GW
Postby Zoot Katz » Sun Nov 09, 2008 8:00 pm
A frame failure is about the only thing that could keep me from using my bike for a day. There are at least three more donor bikes in the stable to take the Xtracycle/ebike conversion so I'd probably be back on the road in less than 24 hours.
A charger and a controller suffered infant mortality but were replaced under warranty by simply riding the bike to the dealer. Neither of those problems kept the bike from working.
A wheel failure on the road could stop me but it would have to be pretty bad to resist my rude boy methods for straightening tacos.
The bike won't fit on a bus rack or in a taxi so a worst case scenario means pushing it home or collecting it later with a co-op vehicle.
I'm not worried about electrical gremlins crippling my machine. It is a bicycle after all. Hills are finite so not insurmountable.
I've only had the bike up in its present configuration for 57 days/941 kilometers. The 48V 18Ah NiMH pack reliably gives the 5304 motor ~100 km range.
Zoot Katz
Postby deardancer3 » Sun Nov 09, 2008 8:32 pm
Giant Lafree Lite, never a breakdown in 5000 miles other than common flats.
Chain Drive Advocate
deardancer3
Postby BiGH » Tue Nov 11, 2008 12:20 am
BMS blew in my battery pack - waiting on replacement BMS so i can charge the headway cells.
Bike / Motor: Electric specalized rock hopper with Crystalyte 504 / 26"
Batt: Yesa 72v (36v*2) (getting 6.7ah) LiFEPO4 in a Topeak bag. OR 1x eMTB 48v 20ah pack (straps to frame) -depending on range requirements.
Controller: Unmodified 48a digital with 4110 Fets
Current Prob: Bike is in parts getting painted / drying / testing replacement BMS
Trail of Dead Parts:Avanti Frame, 408 motor *melted*, 35a controller - i broke by trying to mod it 2nd controller - blew it up.
My Ride
BiGH
Postby swbluto » Wed Nov 12, 2008 2:01 pm
Hub flange broke and I'm delaying repairs until after I move. So, I haven't been riding since making that 0 miles. :mrgreen:
(Okay, it's honestly been about 5-10 miles for those "emergency" trips.)
swbluto
Postby Drunkskunk » Fri Nov 14, 2008 4:38 pm
Battery failure, I went out to ride, and it was puffed up. new battery will have to wait a while
Drunkskunk
Postby Icewrench » Sun Nov 23, 2008 12:34 pm
I ride a sla36 volt ev global brushed 500 watt geared heinzman and it`s been reliable with no break downs. With about 500 miles use.
Just smoked a controller on the bench with a few extra volts, my fault. :roll: that`s the 0 mile rank.
The project is to add current ebike tech to an un ridden 24 volt ev global ebike. Hoping to have it go farther, quieter, and with more zip.
Lithium batteries, dewalt or milwuakee for range increase and weight reduction. Even newer bms waiting for assembly.
Brushless geared rear hubmotor , quieter, snappy acceleration, bmc v1 with supplied controller was gutless, so I overvolted and let some smoke out of that controller. Another better adjustable controller will be here soon.
Good thing I have a working spare e bike cause this project thing is moving at a snails pace. :D
Icewrench
Return to Polls & Surveys
Who is online
Users browsing this forum: No registered users and 2 guests
