Hire E-Bike build thread
Hickbeard   1 mW
Post by Hickbeard » Dec 02 2019 5:54am
Cost and parts list. Cost so far £305.
£0. Obike donor bike
https://en.m.wikipedia.org/wiki/OBike
£250. 70x Sanyo 18650GA cells from http://queenbattery.com.cn/44-ncr18650ga-3500mah-10a
£0. 18650 cell holders
https://18650.lt/index.php/5p-n-e-s-e-module/
£55. 13x tab set for holders
https://18650.lt/index.php/product/n-e-s-e-tab-set/
Not much to show yet but figured would start the thread anyway.
This is my Donor bike. It was an abandoned hire bike. Nice and chunky look and feel to it.
I will eventually lace a hub motor into the existing wheel for aesthetics, assuming it will be strong enough.
I'm thinking of replacing the basket with a peli case to hold controller and battery on the front.
Thats it for now. I'll update as it progresses. Image
Sent from my CLT-L09 using Tapatalk
E-HP   10 kW
Re: Hire E-Bike build thread
Post by E-HP » Dec 02 2019 10:17am
Hickbeard wrote:
Dec 02 2019 5:54am
Front or rear? I'm guessing rear to even out the weight from placing the battery in the front. You should check the number of spokes the stock rim takes.
Any plans for brakes?
Hickbeard   1 mW
Post by Hickbeard » Dec 02 2019 10:51am
E-HP wrote:
Hickbeard wrote:
Dec 02 2019 5:54am
Yeah rear hub.
Stock rim is 36 as is hub motor.
Currently brake will be front only drum Image which is accident waiting to happen I know. Got some cable discs I'll look to fit once the rest of it is up and running.
The aim of this one is cheap as chips. Make lots of mistakes on this one to avoid making the same ones on the next lol
E-HP   10 kW
Post by E-HP » Dec 02 2019 12:37pm
Hickbeard wrote:
Dec 02 2019 10:51am
Great philosophy! Try to keep the mistakes low cost :D
SlowCo   100 kW
Post by SlowCo » Dec 02 2019 2:46pm
Doesn't an abandoned rental bike stay property of the rental company? It looks almost new. Sounds sketchy...(hope it's not)
Hickbeard   1 mW
Post by Hickbeard » Dec 02 2019 3:43pm
SlowCo wrote:Doesn't an abandoned rental bike stay property of the rental company? It looks almost new. Sounds sketchy...(hope it's not)
Contacted the company and they said they did a trial in my area but decided not to roll out and it wouldn't be viable to come and collect it so wrote it off. Told me to remove the GPS and post it back to them and I could keep it.
SlowCo   100 kW
Post by SlowCo » Dec 02 2019 4:57pm
Then I'll call them to do an unsuccessful trial in my area :lol:
Good luck building the bike up like you want.
Hickbeard   1 mW
Post by Hickbeard » Dec 02 2019 6:04pm
SlowCo wrote:Then I'll call them to do an unsuccessful trial in my area Image
I actually think they've gone bust now but...
amberwolf   100 GW
Post by amberwolf » Dec 02 2019 11:28pm
Hickbeard wrote:
Dec 02 2019 10:51am
If you use a DD hubmotor, you can use regen braking in the rear to help (though your primary brake is still the front).
If the front brake you ahve will lock up the wheel, you've already got all the braking on it you can get. No need to change the brake for something else, unless you just prefer some other type.
Hickbeard   1 mW
Post by Hickbeard » Dec 03 2019 1:59am
amberwolf wrote:
Hickbeard wrote:
Dec 02 2019 10:51am
I don't think the front will to be fair. It's the standard drum and is pretty poor.
For regen does it still use brakes external of the motor or something inside. I'll need to Google regen brakes on ebike as I know very little.
Hickbeard   1 mW
Post by Hickbeard » Dec 03 2019 4:39am
First 18650 cell holders 3d printed. My mate is doing 2 every night.
Ordering the internals from here https://18650.lt/index.php/product/n-e-s-e-tab-set/
AngryBob   100 W
Post by AngryBob » Dec 11 2019 12:53pm
Do please post on results with the battery kit. I have not yet seen a user review for Agniusm's (sp?) current kit, though his previous one for pouch cells was said to work well. Hopefully his business is going well and is very busy as he does not seem to post here as often as he used to.
He seems to do good engineering and thorough testing.
Hickbeard   1 mW
Post by Hickbeard » Dec 13 2019 12:56pm
Had a parcel delivered today from China.
My 18650 cells have arrived ImageImage
But off to France now so can't open them to check Image
All the cell holders are printed as well
Hickbeard   1 mW
Post by Hickbeard » Dec 13 2019 12:57pm
AngryBob wrote:Do please post on results with the battery kit. I have not yet seen a user review for Agniusm's (sp?) current kit, though his previous one for pouch cells was said to work well. Hopefully his business is going well and is very busy as he does not seem to post here as often as he used to.
Really nice guy.
I'll do a review next week when I've got them to hand. Couple of things to point out but no dramas really.
