Marin Wild Cat Trail
goatman   100 W
Post by goatman » Jan 03 2020 4:01pm
the build is
crystallite hs3540r
phaserunner
ca 2.3
13s5p- lg mh1 cells
im switching the rear tire to a duro razorback 24x3.0
goatman   100 W
Re: Marin Wild Cat Trail
Post by goatman » Jan 03 2020 4:02pm
goatman   100 W
Post by goatman » Jan 03 2020 4:03pm
goatman   100 W
goatman   100 W
Post by goatman » Jan 03 2020 4:09pm
I needed to test the hanging battery before putting it on my sons bike so I put this together, 13s5p is 65 cells so you could actually do a 16s4p battery in that case with higher amp cells. ill keep adding pics as I build this bike with a different battery and clean up the wiring
goatman   100 W
Post by goatman » Jan 04 2020 6:58pm
cutting axle to fit torque
goatman   100 W
Post by goatman » Jan 04 2020 6:59pm
goatman   100 W
Post by goatman » Jan 04 2020 7:03pm
theres actually 2 torque arms, one on each side of the motor mounted the same way. ill be making torque plates but I needed these on for testing the bike.
goatman   100 W
Post by goatman » Jan 04 2020 7:08pm
went for a ride, tried not to go over 2000 watts because the battery is fused at 40 amps. im actually surprised how the bike did at 48v and 2000 watts. ca is km/h
goatman   100 W
Post by goatman » Jan 04 2020 7:09pm
I left with 54.3v and this was after a quick trip
goatman   100 W
goatman   100 W
Post by goatman » Jan 04 2020 7:11pm
battery is 16ah
goatman   100 W
Post by goatman » Jan 04 2020 7:23pm
8volt battery sag, lg mh1 aren't made for this kind of bike. this battery is going to be used with a little 500 watt geared hub. I have 25r packs that I share between my bikes. ill post more later. a 26 inch hookworm on the front and this could be a fun city bike
goatman   100 W
Post by goatman » Jan 06 2020 11:59pm
added 3s4p to a 14s4p for 17s4p of 25r. need to get a bms for it. made a basic mold for a fiberglass shell with a 3/16 aluminum plate. just waiting for the rain to stop.
goatman   100 W
Post by goatman » Jan 12 2020 1:12pm
ive been fitting the battery case to the bike, now I just need to finish shaping and sanding and paint
goatman   100 W
Post by goatman » Jan 14 2020 3:57pm
didn't want wires running up the side of the battery, I had room for 18s so I used cell holders and filled the cavity with silicone to act as a bumper. most of the battery weight will be there.
I loaded up the silicone and will trim it later
just need to make some kind of cap/nose for the battery case.
