GCinDC
these two stromers were brought into the shop with issues, and stromer sent them replacement bikes. they sat in storage for 1.5 years and now that the local bike shop is closing down, they gave them to me (cause i happend to be chatting w/ a guy who works there and found out about them).
push On button, but no response whatsoever.
got 3 new chargers with them but no keys.
plugged in the chargers, light went red for 5 seconds then turned green.
lbs tech told me i could remove this bolt and slide out the pack:
ah, well there is no battery! and here's a pic after i've started taking apart the wiring:
checked the charger voltage: 42V
peeled back some of the shrink tube and hooked it up to 41V (lipo) - no pics of this exercise - but no power to system.
perhaps i need to figure out if that yellow wire is key to operation...
hmm, but digging around online, on the stromer troubleshooting page, i see this:
The control unit cannot be switched on. Replace the control unit’s battery. To replace, remove the unit from the handlebar. This requires a Phillips head screwdriver and a button battery (CR2032). The battery can also be replaced at your local dealer.
