P R O J E C T "Y" KILLABICYCLE World record 17 june 2009
Postby Doctorbass » Thu May 14, 2009 11:42 pm
=15 may 2009=
-Begining of the project "Y"
(Y is designed on the memory of the flux capacitor " Y ")
-Goal: building a bicycle capable of reaching 60-65mph and /or under 20sec on the quater mile
-Shall be finished for 16 june 2009.
Project description:
Building a bicycle with the lowest weight as possible, the narrower as possible and the most stable as possible able to carry safely 120 A123 cells in 30s 4p seperated in two packs of 15s with a frame able to fit with a X5 motor and to be able to add some fairing on it with lowest cost.
that bicycle must have pedal and thet must stay usable.
It MUST be finished before 17 june 2009 because this date is the event of the drag racing test with the TV show team that will make an episone about my two bikes and where i'll attempt one or two World record.. Torque and Speed.
Part list:
- small low profile bicycle: found a dual suspension used X game motobike cost 80$can : http://www.walmart.com/catalog/product.do?product_id=5584942
-120 A123 cells (that i tested individually in Capacity, Ri and SOC), cost 120$ + 130 hour labor
- 18 mosfet controller ( with original IRFB4110 mosfets) tuned to 150A limit
- X5 5303 on a 20" wheel with ( Delta/Wye)
- lexan and coroplast fairing.
- cycle analyst
- low weight driver: Me 8)
Pics or vid soon.
________________________
ULTRAFAST DRAG RACING SETUP:
-Fastest electric bicycle 94.3km/h GPS certified!
-0-70km/h in 5sec !! -single X5 5302 on 20"
-104V controller using 18x 4110fets (170A peak)
-Peak power 16150W (21.5hp)
-30s4p A123 + Tppack BMS
TORQUE SETUP:
-Succeded to haul a 19200 pounds schoolbus!!!
-202km range no pedal -
- 0-50km/h in 4sec!!
-100.8V 23Ah BATTERY made of 432x 18650 cell from Lithium Makita 3Ah 18V LXT -Team Konion™ Member
-Top speed 62km/h Torque 230lbs trust !!
Doctorbass
1 GW
1 GW
Re: --- P R O J E C T "Y" --- code name: KILLABICYCLE
Postby Stevil_Knevil » Fri May 15, 2009 2:47 am
"Y" E-S!!
Ridefastakechances :wink: -S
Stevil_Knevil
Postby deecanio » Fri May 15, 2009 5:15 am
Hi Doc,
i kinda think this one looks better for speed?
18" Boys' Hyper Speed BMX Bike :mrgreen:
looks like it would be easier to fab a "full fairing"? but either way best of luck !!!!
Cheers,
D
Kona Stinky 2004
50v,8.8ah A123
Single stage MS edrive
Hv110 esc
Astro 3210
deecanio
Postby gogo » Fri May 15, 2009 5:57 am
The swingarm design looks questionable. Does your used bike have the triple clamp forks?
gogo
Postby johnrobholmes » Fri May 15, 2009 7:00 am
I certainly hope you will reinforce the headtube, fork, and rebuild some worthy wheels. At those speeds one good bump would destroy a typical walmart wheel.
awesome awesome project. Can't wait to see it come together!
Volt up, gear down
http://www.HolmesBikes.com (aka Holmes Hobbies)-- Electric Bike conversions and other electrical nonsense.
johnrobholmes
Postby Doctorbass » Fri May 15, 2009 9:05 am
johnrobholmes wrote:I certainly hope you will reinforce the headtube, fork, and rebuild some worthy wheels. At those speeds one good bump would destroy a typical walmart wheel.
Over 30mph this ebike will ONLY be used on Drag racing lane.. so the ground is near perfectly flat :wink:
The actual lenght between two wheel axel is 37" and it is too short for great stability so this sfternoon i'll meet a guy that make custon mike and ask him to add 6" lenght on the front of the bike. The head tube will be 6" more in front of the bike and that will let me more place to put battery just sat the rear of the front wheel.
I'll also choose a new head tube to fit my old RST Mongoose fork that is stronger and safer.
After examinating the killacycle, i catched alot of important details that i want to reproduce on that ebike. The lenght and height of the ebike ratio to the wheel size will be nearly the same.
I also got many lexan fairing coming from a local thermo molding shop that was made for old solar car project for the Laval University and that are no longer used... I got them for 20$ total.
Now the issue that worrie me is the problems that steveo had with the Delta mode with his X5.. I just hope this is not a fact or caracteristic of any X5 that dont allow delta... and that it is only a wiring error.
Does anyone have great suggestion for great quality 20" flat tires that could take 65mph and that are aerodynamic?
Doc
TORQUE SETUP:
Doctorbass
1 GW
1 GW
Postby TylerDurden » Fri May 15, 2009 9:07 am
Those rigs are tiny. If you can find a cx450 frame (bikeraider), it will be much better IMO.
Have a Nice Day,
TD
___________________________________________________________
Please post your Watts-at-speed in the survey.
TylerDurden
Postby Doctorbass » Fri May 15, 2009 9:08 am
gogo wrote:The swingarm design looks questionable. Does your used bike have the triple clamp forks?
Have you an exemple of a tripple clamp fork?
On a plane ground like 1/4 mile lane i'll nearly dont really need suspensions... that only add some weight to the ebike i guess no?
TORQUE SETUP:
Doctorbass
1 GW
1 GW
Postby TylerDurden » Fri May 15, 2009 9:10 am
Joepostal & Vanilla have them too.
Have a Nice Day,
TD
TylerDurden
Postby steveo » Fri May 15, 2009 10:04 am
http://www.youtube.com/user/trdfreak03
New Project 2009/12/20
Infinity Titan Bike/24 mosfet irfb4115 @ 100 amps - 14520Watts /20" x5306 New Gen Crystalite/44s 4p A123 battery pack in the works/0-80km/h in holy s|-|1T!
New Build Supercycle/18 Fet Controller IRFB4110 @ 160amps/Golden Motor Replica 16"/88.8v turnigy lipos 10ah/ Star/delta Fastest speed Recorded: 102km/h
YES, I do Repairs/modifications, pm me!
"If you can't fix it; you shouldn't buy it"
steveo
Postby gogo » Fri May 15, 2009 12:55 pm
It starts to seem more like a moped when you get away from multi-gears through the pedals. The pedal drive is there more to meet the definition of a bicycle than for actually using.
How about this moped chassis that has the pedal drive seperate from the motor? Just remove the engine and stuff that nice stiff double cradle frame full of batteries.
At some point there would need to be a weight limit along with a pedal driven chain drive requirement. You can put pedals on any motorcycle.
gogo
Postby HAL9000v2.0 » Fri May 15, 2009 1:25 pm
... for under 20 you should lay down...
... or go Safe's style...
...just thinking...
HAL9000v2.0
Postby HAL9000v2.0 » Fri May 15, 2009 1:28 pm
Even for flat ground over 100kmh you need suspension, not big, 2-3 cm is enough. It is not for pleasure just to avoid small vibration that can resonate somewhere where you do not need it...
HAL9000v2.0
Postby vanilla ice » Fri May 15, 2009 1:50 pm
I've seen an electric version of the xgames motobike. I'm not sure why its so rarely seen, maybe it got pulled for liability reasons.. I could see that. Illegal for the <16 target demographic on the street. I almost bought one since I'm (physically) over 16, IIRC they came with a small rear hub motor.
bmx*, pocketbike*, pitbike*, e300*, e-48*, tandem, cruiser.. *now running!
vanilla ice
Postby gogo » Fri May 15, 2009 2:06 pm
When I was drag racing a Yamaha RD350 most racers using wheelie bars had no rear suspension. I think this was because suspensions tended to get pegged when power was applied. It also simplified wheelie bar implementation, they just bolted into the shock mounts.
I kept my suspension and used a lightweight wheelie bar comprised of two stiff (compression) elements and four adjustable steel cable (tension) elements. My launches were butter smooth even though I was just dumping the clutch and letting all the slip happen at the tire/pavement interface.
gogo
Next
Who is online
Users browsing this forum: Alexa [Bot], BiGH, evrunna and 1 guest
