Metallover's 9c Blackcomb Build
Re: Metallover's 9c Blackcomb Build
Postby Metallover » Wed Aug 04, 2010 9:11 pm
Hehe.. I usually ride nicely, but I wanted to push the envelope today. :D Thanks for the comments! :D
The hub offers great performance, but the second you go off of the paved road, the ride turns to crap. Even on-road you can feel all of the medium-large bumps with all of the unsprung weight. I drive on a lot of gravel roads so the suspension needs to be a lot better. I also jump my bike at a friend's quad track, which is a blast.. The weight is fine now, but I'm worried about it when I lose the hub because the batteries add a lot of weight in the front.
And the spokes,,, they've been a little creaky squeaky for awhile. I'm not motivated enough to tighten em because I suck at it; although I can do it if I have a few hours to get it right.
Using my existing batteries and controller, I am going to run an outrunner through the crank. I already have all of the parts for a freewheeling crank. I've got a thread in the non-hub section.
Add your bike to the Unofficial E-Bike Garage! - http://spreadsheets2.google.com/ccc?key ... OWcg&hl=en
Novara Buzz FS MTB- 18s 15Ah Turnigy Lipo - 12Fet controller @57A - 9C 2807 motor - 600W charging - 4500W peak - 40Mph - 20Mi range
Metallover
Postby Ypedal » Wed Aug 04, 2010 9:17 pm
Helmet
Helmet
Helmet
Helmet
Helmet
:shock:
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Metallover » Wed Aug 04, 2010 10:00 pm
I need to start wearing my helmet more.. I had it on at the start of the video and I wore it when we were driving to new locations, but I took it off when we were on non-busy residential streets/offroad. Honestly when I am in town I usually don't wear it. My city has about 8000 and the roads I am on don't have all that much traffic... But it only takes one crash...
On a different note, I just saw that I should solder up my traces on my controller when maxing out the amp limit because the solder isn't good enough without copper. I will beef up the traces next time I take out the controller.
I haven't posted this yet but awhile ago I was programming the bike and I saw I only had 40a. I upped it to 57a and I got peaks of about 70a and 4700w. :D :? I wonder if not upgrading the traces caused some problems with the shunt/current limit? Or maybe it's never too accurate? Or maybe I'm producing 850w of heat?
Metallover
Postby johnrobholmes » Wed Aug 04, 2010 10:31 pm
Helmet!
How hot is the controller getting now?
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Metallover » Thu Aug 05, 2010 12:12 am
I don't really keep track of the controller temp too often because the motor is by far the first thing that would overheat... I'll feel the controller on the FET side and it'll be warm to the touch, rarely hot to the touch. With my new build I'll put a temperature sensor/alarm in there like I have on my motor now. :D
Metallover
Postby Hyena » Thu Aug 05, 2010 4:12 am
Cool video, looks quite fast. You still running 18S lipo ?
Have you measured your top speed with GPS or some other accurate method ?
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby fizzit » Sat Oct 02, 2010 12:18 pm
Hey metallover, your bike is really, really cool. I'm going to be turning 16 soon which means I can legally have an electric bike (not that I would keep it to legal power levels though :D ) and I was actually looking at doing a bike with 9c rear, 12fet lyen, 6 * 6s 5ah lipo, and a Blackcomb or similar bike. And I just found your build log :shock: . Its funny that we also both have had scooters upgraded with brushless turnigy motors and lipo. I hope someday I will have an ebike as cool as yours, maybe I'll just have to start off with an RC drive now :twisted:
-Colin
my first ebike, a freeride mountain bike, using a turnigy 80-85, castle hv160, and turnigy lipo:
viewtopic.php?f=28&t=21953&start=180#p607020
fizzit
Postby Metallover » Sun Oct 03, 2010 9:24 am
Hyena, sorry for not responding,, I don't remember getting an email.. I am still running 18s lipo. All of my top speeds were measured with a garmin 201 GPS. On a full charge I can get over 40 with the timing boost, which kicks in at about 35mph. I found that my range goes out the window with the timing boost, I have to be careful not going over 35mph on long trips.
Fizzit, good luck with your build! I'll keep an eye out for it.
The latest setback has been my charger. My Hyperion EOS0610i bit the dust a week ago. I contacted a few people and found that I can get a 40% discount on a new EOS0615i, which is 360w compared to 250w. :)
In the mean time I spent $26 on two PC power supplies and wired em up in series to make a 1150w 24v power supply to power my new charger. A similar charger runs $225. My charger runs on either 12v or 24v, but I figured it would be more efficient at 24v.
The final unit is 13x7" and the output measures 25.2v. If I put the leads of my multimeter on each power supply, I get 12v between the two. I haven't touched it yet, and I don't know if it will shock me if I touch it. There's a guide on hooking up two power supplies in series here.
I cut some pegboard to mount the power supplies on.
Testing - The power supply on the right is wrapped in clear packaging tape.
I mounted the power supplies to the pegboard with some bolts, M3 I believe. I then used some unshrunk heat shrink (1" wide) and duct tape to try to insulate the screws.
And my awesome duct tape job.
25.2v output under no load.
Metallover
Postby deecanio » Mon Oct 04, 2010 5:34 am
hey metallover,
your ride is working sweet, very impressive :twisted:, but just to add +1, get some protection on , especially when your bike is that capable :shock:
i'll post up in your other thread, see if i can save you from any errors i've already made ;) don't dismiss your hub yet, it's always nice to have it ready to ride inbetween "build revisions".
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby Ypedal » Mon Oct 04, 2010 6:43 am
If you push these supplies to their rated amperage you might want to consider removing the duct tape !!.. ( cooling ) . :wink:
Ypedal
Postby veloman » Tue Oct 05, 2010 12:04 pm
I just came across your youtube video, didn't realize it was yours until after I asked what your voltage and battery were.
I'm not surprised now, running 18s lipo. That's a fast bike. I will likely be doing a similar setup on my dualie.
So you aren't giving up ebikes for cars? That's cool dude, I remember high school and how cars were everything (only 7 years ago).
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby johnrobholmes » Tue Oct 05, 2010 1:37 pm
I didn't give up bikes for cars in high school either. I just rode in different locations because I had a car to take me further :lol:
High school only 7 years ago? Humph, I am getting old.
Volt up, gear down!
johnrobholmes
Postby Hyena » Tue Oct 05, 2010 6:17 pm
+1 on duct tape heat thing.
Leaving highschool was 15 years ago for me now but I wish I had an ebike back then! Actually I've since gone full circle - I've got a fast, powerful car in the garage but I prefer to ride my ebike at any opportunity.
Hyena
Postby Metallover » Tue Oct 05, 2010 6:43 pm
The duct tape.. I'll keep a close eye on temps. I don't foresee any problems with heat, but it's very possible. These power supplies were made to be shoved into tight cramped servers and run for hours on end. Also I can't see myself going over half the wattage this supply can produce,, with a 360w charger I might get 500w total to my 1150w ps.
Here in SD the driving age is 14. I started driving when I was a tick under 15, and I built the bike over a year later. I built it for hobby and recreation, not for transportation, or, saving money. :roll: I love riding the bike and vehicles aren't too important to me. :)
I think the best thing about my e-bike is that I'll have it in college. That will be so convenient!! :D
Metallover
Previous
Who is online
Users browsing this forum: _Chris_ and 4 guests
